Home » Eclipse Projects » Eclipse Platform » JDK of Eclipse building
JDK of Eclipse building [message #91788] Fri, 11 July 2003 10:59 Go to next message
Can anybody tell me, if eclipse is
buildung with JDK 1.3.1 or with JDK 1.4?
Thanks a lot.
Best Regards,
Thomas
Re: JDK of Eclipse building [message #91834 is a reply to message #91788] Fri, 11 July 2003 11:50 Go to previous messageGo to next message
Thomas you can configure the Eclipse compiler to compile against either 1.3
or 1.4.
This can be done a global and on a per project basis.
See the Installed JREs preference page for global setting and to set locally
for a project see the project Properties>Java Build Path>Libraries
Please check out the Eclipse help under Compile, Java Builder, build
classpath etc.
HTH
Darins
"Thomas H
Re: JDK of Eclipse building [message #92460 is a reply to message #91834] Sat, 12 July 2003 03:27 Go to previous messageGo to next message
> or 1.4.
Just to clarify - it doesn't really build "against" either 1.3 or 1.4,
ie it doesn't use the 1.3 or 1.4 compiler. It still uses the internal
compiler either way, but compiles to be *compatible* with 1.3 or 1.4
(ie some of the compiler bugs are reproduced, assertions are in 1.4,
etc).
Jon Skeet - <skeet@pobox.com>
http://www.pobox.com/~skeet/
If replying to the group, please do not mail me too
Re: JDK of Eclipse building [message #92490 is a reply to message #92460] Sat, 12 July 2003 07:18 Go to previous messageGo to next message
Originally posted by: purplehayz.earthlink.net
Really? I just spent some quality time playing with the launching plugin,
and it looks like that's used for building (based upon the design as I
understand it - since I was working with system properties and, on MacOS X,
they differ between 1.3 and 1.4, I know the launcher launches the desired
version). The information required to use a JRE is the whole directory
she-bang for a JRE, so I'd be really surprised if its not run in a separate
thread by Eclipse....
It would be hard to make a 1.4 compatible build using a 1.3 compiler, since
1.4 didn't necessarily exist "back then."
Can someone working on the compiler interface answer this question?
Thanks and have fun! - Bob
On 7/12/03 2:27 AM, in article MPG.1979c8d5828f4b809897ff@news.eclipse.org,
>> or 1.4.
> etc).
Bob Hays, Computer Geek
http://www.alephnaught.com
"Once you've outsourced something to some big IT company, you can write it
off as a source of competitive advantage."
-- Gary Hamel
Re: JDK of Eclipse building [message #92646 is a reply to message #92460] Sat, 12 July 2003 18:52 Go to previous messageGo to next message
By "against" I meant that the internal compiler uses the 1.3 or the 1.4
class libraries.
The compatibility/compliance is set under the preferences. See
Window>Preferences>Java>Compiler>Compliance and Classfiles
HTH
Darins
"Jon Skeet" <skeet@pobox.com> wrote in message
news:MPG.1979c8d5828f4b809897ff@news.eclipse.org...
1.3
> > or 1.4.
> etc).
Re: JDK of Eclipse building [message #92703 is a reply to message #92646] Sun, 13 July 2003 04:08 Go to previous messageGo to next message
> class libraries.
Ah right - yes indeed. Hopefully between us we've now answered the OP's
question :)
Re: JDK of Eclipse building [message #92718 is a reply to message #92490] Sun, 13 July 2003 04:11 Go to previous messageGo to next message
> version).
Oh Eclipse itself will certainly run in whatever JRE you tell it to,
and will also launch your application for run/debug in whatever JRE you
tell it to (separate decision). That doesn't mean it uses the JDK's
compiler, which I believe is what the OP was asking.
The compiler uses the JRE's library to compile against, but it doesn't
use a JDK's compiler - so you could actually use Eclipse without having
a JDK installed, as far as I know.
Re: JDK of Eclipse building [message #94554 is a reply to message #91834] Wed, 16 July 2003 02:53 Go to previous messageGo to next message
> or 1.4.
> classpath etc.
> HTH
> Darins
I didn't mean with which compiler I can compile my projects.
My question is:
With which compiler the "Eclipse classes", that are downloadable from your
server, are builded?
Or with other words: Which compiler (JDK) do you use for your nightly
build?
Best Regards,
Thomas
Re: JDK of Eclipse building [message #94859 is a reply to message #94554] Wed, 16 July 2003 10:18 Go to previous message
Originally posted by: olivier_thomann.ca.ibm.comNOSPAM
Le Wed, 16 Jul 2003 06:53:39 +0000 (UTC), th.huebner@sap.com (Thomas
>build?
We don't use javac. We use the Eclipse compiler inside an ant javac
task.
Olivier
Previous Topic:How to listen for Editor Maximize/Restore
Next Topic:Renaming of a resource
Current Time: Tue Nov 04 22:13:14 EST 2025
Powered by FUDForum. Page generated in 0.06478 seconds
