Home » Eclipse Projects » Equinox » JNDI and Equinox
JNDI and Equinox [message #91777] Mon, 09 July 2007 05:16 Go to next message
Originally posted by: marcel.ryser.gmx.ch
We're migrating our tomcat web-application to eclipse equinox bundles and
the ServletBridge.
In one of our bundles we use jndi resources defined in the per-context
configuration located at
$TOMCAT_HOME/conf/Catalina/localhost/myapplication.xml. All resources are
DataSources (databases).
This is the code we get our datasources by the InitialContext:
String lookup = "java:/comp/env";
Context initContext = new InitialContext();
Context envContext = (Context) initContext.lookup(lookup);
DataSource ds = (DataSource) envContext.lookup(profile);
But it seems that there aren't any resources defined when it tries to
lookup. I think this is a
classloader problem. The InitialContext is created by the bundle
classloader and not the tomcat-classloader.
I've surfed around to get some ideas how to fix it. One of those said to
set the classloader like this:
Thread current = Thread.currentThread();
ClassLoader old = current.getContextClassLoader();
try {
current.setContextClassLoader(BridgeServlet.class.getClassLo ader());
InitialContext context = new InitialContext();
DataSource jtaDatasourceInst =
(DataSource)context.lookup("java:/jdbc/WAFPATTERNSDATA");
if(jtaDatasourceInst ==null)
System.out.println("Could not find DataSource");
} catch (Throwable e) {
} finally {
current.setContextClassLoader(old);
But it doesn't work for me. How i get this to work?
Re: JNDI and Equinox [message #91975 is a reply to message #91777] Wed, 11 July 2007 13:34 Go to previous message
Hi Marcel,
That looks like it should work.
If you explicitly set the TCCL on an incoming request thread then your JNDI
request should just be a regular webapp JNDI call.
Some suggestions....
Are you doing the JNDI lookup on an incoming request thread?
On some appservers there's additional thread local information required in
order to access the directory.
Could you try accessing another value in you comp/env? Preferably something
really simple like a String.
I'm wonder if perhaps there's a factory class visibility problem when
creating an instance of the DataSource (?).
-Simon
"Marcel Ryser" <marcel.ryser@gmx.ch> wrote in message
news:87cac9876e1438a9ff32f0faa404dcc1$1@www.eclipse.org...
> the ServletBridge. In one of our bundles we use jndi resources defined in
> the per-context configuration located at
> DataSources (databases). This is the code we get our datasources by the
> InitialContext:
> lookup. I think this is a classloader problem. The InitialContext is
> created by the bundle classloader and not the tomcat-classloader.
> Thread current = Thread.currentThread(); ClassLoader old =
> current.getContextClassLoader(); try {
> InitialContext context = new InitialContext(); DataSource
> jtaDatasourceInst =
> if(jtaDatasourceInst ==null) System.out.println("Could not find
> DataSource"); } catch (Throwable e) { System.out.println("Could not find
> DataSource"); } finally { current.setContextClassLoader(old); }
Previous Topic:Best practices for dependency management
Next Topic:Location of OSGi classes
Current Time: Mon Nov 03 10:48:00 EST 2025
Powered by FUDForum. Page generated in 0.03490 seconds
