Home » Modeling » EMF » [CDO/Teneo] EMF Specific Extra Columns in DDL
[CDO/Teneo] EMF Specific Extra Columns in DDL [message #917557] Thu, 20 September 2012 03:40 Go to next message
Hi Everyone,
Environment: Teneo /Hibernate
When I use Teneo to store EObjects it is generating extra columns in database
(E_CONTAINER,E_CONTAINER_FEATURE_NAME,..) is there any way to avoid those?
or generate as a seperate table?
I want only columns specific to my ECORE model to be created in the DDL.
Thanks.
Appasamy
Re: [CDO/Teneo] EMF Specific Extra Columns in DDL [message #917584 is a reply to message #917557] Thu, 20 September 2012 04:10 Go to previous messageGo to next message
Hi Appasamy,
See here:
http://wiki.eclipse.org/Teneo/Hibernate/ModelRelational/Association_Mapping#Storing_container_relation
Also checkout several configuration options in this page to prevent specific columns or to control naming etc.:
http://wiki.eclipse.org/Teneo/Hibernate/Configuration_Options
gr. Martin
On 09/20/2012 09:40 AM, Appasamy Thirugnana wrote:
> Hi Everyone,
> Thanks.
> Appasamy
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [CDO/Teneo] EMF Specific Extra Columns in DDL [message #917614 is a reply to message #917584] Thu, 20 September 2012 04:50 Go to previous messageGo to next message
Thanks Martin. This helped me.
~Appasamy
Re: [CDO/Teneo] EMF Specific Extra Columns in DDL [message #917615 is a reply to message #917584] Thu, 20 September 2012 04:51 Go to previous messageGo to next message
Hi Martin
that is interessting.
How does Teneo evaluate the container, when container relations are disabled?
Are there any drawbacks, when this option is used?
Christoph
Re: [CDO/Teneo] EMF Specific Extra Columns in DDL [message #917833 is a reply to message #917615] Thu, 20 September 2012 09:31 Go to previous messageGo to next message
Hi Christophe,
Without these econtainer columns the econtainer association is only set if first the parent is read and then the
children are accessed through the parent. So if A is a child of B. When you read A directly from the database the
container association is not set (is null). If you would read first B and then do getA then the container association
from A to B would be set.
gr. Martin
On 09/20/2012 10:51 AM, Christoph Keimel wrote:
> Hi Martin
> that is interessting. How does Teneo evaluate the container, when container relations are disabled? Are there any
> Thanks
> Christoph
The Netherlands
Re: [CDO/Teneo] EMF Specific Extra Columns in DDL [message #917929 is a reply to message #917833] Thu, 20 September 2012 11:15 Go to previous messageGo to next message
Hi Martin
Thank you for the information.
So if A is a child of B and has an opposite reference to B
class B {
	contains A[] a opposite b
class A {
	container B[1] b opposite a
and I read A directly, the call to getB() would return null, since this internally uses the eContainer attribute. Correct?
What if the reference from A to B is non-containment?
class B {
	refers A[] a opposite b
class A {
	refers B[1] b opposite a
Would A.getB() lazy-load its reference to B in this situation?
I ask, because I am currently thinking about whether to use containment references at all. I get the feeling that, when working with the database, the concept of containment vs. reference is unnecessarily complex. Opinions on this statement are very welcome Smile
Greetings
Christoph
Re: [CDO/Teneo] EMF Specific Extra Columns in DDL [message #918253 is a reply to message #917929] Thu, 20 September 2012 18:05 Go to previous message
Hi Christoph,
In this specific case the container column is not needed even if you do containment like this. Mainly because you model
the bidirectional side of the containment association explicitly in the model.
Containment in itself makes sense for certain structures like order and orderlines. But as you touch upon, for a xml
document it is important that everything is contained in something (except for the root), this is less relevant for data
persisted in databases. There is no overall containing root type necessary then.
gr. Martin
On 09/20/2012 05:15 PM, Christoph Keimel wrote:
> Hi Martin
> So if A is a child of B and has an opposite reference to B class B {
> class A {
> }and I read A directly, the call to getB() would return null, since this internally uses the eContainer attribute. Correct?
> class B {
> class A {
> }Would A.getB() lazy-load its reference to B in this situation?
> are very welcome :)
> Greetings
> Christoph
The Netherlands
Previous Topic:[CDO] Sharing a resource set amongst views
Next Topic:Problem with with mutually referencing ELists
Current Time: Sat Jul 26 11:49:18 EDT 2025
Powered by FUDForum. Page generated in 0.09493 seconds
