Home » Modeling » TMF (Xtext) » I need both ImportUriGlobalScopeProvider and TypesAwareDefaultGlobalScopeProvider in my DSL
icon5.gif  I need both ImportUriGlobalScopeProvider and TypesAwareDefaultGlobalScopeProvider in my DSL [message #917588] Thu, 20 September 2012 04:15 Go to next message
I have a DSL where I use jvmTypes (http://www.eclipse.org/xtext/common/JavaVMTypes) and importURI.
When I wire the IGlobalScopeProvider, I can't have both the ImportUriGlobalScopeProvider and TypesAwareDefaultGlobalScopeProvider, so either the JVM types work or the importURI.
Looking at the code, it doesn't seem trivial to merge the two providers.
Suggestions?
A. Digulla
Re: I need both ImportUriGlobalScopeProvider and TypesAwareDefaultGlobalScopeProvider in my DSL [message #918699 is a reply to message #917588] Fri, 21 September 2012 04:57 Go to previous messageGo to next message
> Suggestions?
> Regards,
> A. Digulla
I encountered the same problem some months ago, and did the following to solve
it. I do not know if it is the best solution, but at least it works for me.
I had to use a @SuppressWarnings("restriction") annotation because of export
restrictions, this probably means that this solution is not optimal :-)
Hope it helps.
Nicolas.
* A global scope provider that is both able to process the importURI attributes to establish cross links
* with other EMF models, and to handle references to JVM types.
* This class is a subclass of {@link ImportUriGlobalScopeProvider} in order to get the importURI behavior
* and delegates references to JVM types to an instance of AbstractTypeScopeProvider obtained through Guice.
* @see TypesAwareDefaultGlobalScopeProvider where part of is getScope() function is duplicated here.
* @see ClasspathBasedTypeScopeProvider
* @see org.eclipse.xtext.common.types.xtext.ui.JdtBasedSimpleTypeScopeProvider
public class MyDSLGlobalScopeProvider extends ImportUriGlobalScopeProvider {
* AbstractTypeScopeProvider is bound to org.eclipse.xtext.common.types.xtext.ClasspathBasedTypeScopeProvider
* in the "Standalone" setup and to org.eclipse.xtext.common.types.xtext.ui.JdtBasedSimpleTypeScopeProvider
* int the IU setup. In both cases, the class AbstractTypeScopeProvider which is the usual global
* scope provider when using the JVM types uses an AbstractTypeScopeProvider instance (through Guice) to
* handle all references to JVM types : we do the same here.
@Inject
private AbstractTypeScopeProvider typeScopeProvider;
public IScope getScope(Resource resource, EReference reference,
Predicate<IEObjectDescription> filter) {
if (EcoreUtil2.isAssignableFrom(TypesPackage.Literals.JVM_TYPE, reference.getEReferenceType())) {
IScope typeScope = typeScopeProvider.getScope(resource, reference, filter);
return typeScope;
else {
return super.getScope(resource, reference, filter);
Re: I need both ImportUriGlobalScopeProvider and TypesAwareDefaultGlobalScopeProvider in my DSL [message #918734 is a reply to message #918699] Fri, 21 September 2012 05:37 Go to previous messageGo to next message
your solution looks good to me. The warnings are present because the
referenced types are not necessarily considered to be stable API.
However, we are cautious to change them anyway.
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 21.09.12 10:57, schrieb Nicolas:
>> so either
>> Suggestions?
>> Regards,
>> A. Digulla
> Hello,
> solve
> export
> Hope it helps.
> Nicolas.
> * @see
> @Inject
> @Override
> reference, filter);
> return typeScope;
> else {
Re: I need both ImportUriGlobalScopeProvider and TypesAwareDefaultGlobalScopeProvider in my DSL [message #918833 is a reply to message #918734] Fri, 21 September 2012 07:45 Go to previous message
Nice idea. I tried to create an IGlobalScopeProvider which simply merges the results of all method calls of both scopes but of course the deciding factor is JvmType.
I created a gist to make reading and cut&paste more simple: https://gist.github.com/3761048
A. Digulla
[Updated on: Fri, 21 September 2012 07:51] by Moderator
Previous Topic:@Inject usage in Xtend files
Next Topic:Odd error using IJvmTypeProvider
Current Time: Tue Jul 29 00:08:44 EDT 2025
Powered by FUDForum. Page generated in 0.05369 seconds
