Home » Modeling » GMF (Graphical Modeling Framework) » creating a image from a diagram file
creating a image from a diagram file [message #91717] Thu, 11 January 2007 15:53 Go to next message
Originally posted by: martin.tauber.t-online.de
I would like to create an image file from a given .diagram file. This
means I don't have the diagram open in an editor. The java application
should jast read the .diagram file and the write it as a gif to disk. I
found the CopyToImageUtil class, but how do I fill the DiagramEditPart
parameter?
Martin
Re: creating a image from a diagram file [message #91757 is a reply to message #91717] Thu, 11 January 2007 16:11 Go to previous messageGo to next message
Originally posted by: vcciubot.uwaterloo.ca
There's another method in that class that uses only the Diagram object.
> parameter?
> Thanks
> Martin
Re: creating a image from a diagram file [message #91929 is a reply to message #91757] Fri, 12 January 2007 06:33 Go to previous messageGo to next message
and how do I fill the Diagram object with my .diagram file?
Martin
>> parameter?
>> Thanks
>> Martin
Re: creating a image from a diagram file [message #92245 is a reply to message #91929] Fri, 12 January 2007 14:07 Go to previous message
Look in the generated XXXEditorUtil for starting.
I guess you need to create an Editing domain and create two resources for
your diagram file and its model file.
Resource.getContents() for the diagram resource should give you the
diagram.
I haven't done myself, but if it works, please confirm it.
vlad
On Fri, 12 Jan 2007 12:33:39 +0100, Martin Tauber wrote:
> Hi
> Regards
> Martin
>>> parameter?
>>> Thanks
>>> Martin
Previous Topic:Getting M3 error, elements don't appear on Canvas
Next Topic:Final/Stable Release of GMF-sdk-2.0
Current Time: Wed Sep 03 06:41:19 EDT 2025
Powered by FUDForum. Page generated in 0.08406 seconds
