Home » Archived » M2M (model-to-model transformation) » [ATL] how to realize a simple loop
[ATL] how to realize a simple loop [message #91605] Wed, 08 October 2008 04:54 Go to next message
Originally posted by: robert.meyer.campus.lmu.de
I am very new to ATL and functional programming - that´s why I have a
little problem:
I want to realize something like a for-loop in a matched rule (that´s
what I would do normally) - I would be very thankful for a
best-practice-example how to realize this in ATL:
My Model:
RootObject
-Object 1 (some properties)
-Object 2 (some properties)
-- Literal Unlimted Natural (Value = 5)
-- Literal Integer (Value = 5)
-Object 3 (some properties)
I want to match the Objects and create some instances in the target
model. At the moment I match the RootObject with a matched rule and
create the instances by iterating through the Objects with distinct.
That works fine - except if I want to create more than one Instance of
the same Object (like Object 2 in the example).
I tried to created a nested forEach, but I don´t know how...
So my question: How to interate from 1 to 5 and create 5 instances of
Object 2? What would you do?
Thanks for your help, i would really like to learn ATL, but the
beginning is hard sometimes...
Rob
Re: [ATL] how to realize a simple loop [message #91632 is a reply to message #91605] Wed, 08 October 2008 05:18 Go to previous messageGo to next message
--------------000509060606010609090203
Hi Rob,
Maybe the following link could help you (especially by using lazy
rules):
http://www.eclipse.org/m2m/atl/basicExamples_Patterns/articl e.php?file=Port/index.html
There are others basic examples available here:
HTH
Freddy.
exquisitus a écrit :
> little problem:
> My Model:
> RootObject
> Rob
name="freddy_allilaire.vcf"
filename="freddy_allilaire.vcf"
YmVnaW46dmNhcmQNCmZuOkZyZWRkeSBBbGxpbGFpcmUNCm46QWxsaWxhaXJl O0ZyZWRkeQ0K
b3JnOk9CRU8NCmFkcjo7OzIgcnVlIFJvYmVydCBTY2h1bWFubjtOQU5URVM7 OzQ0NDA4O0Zy
YW5jZQ0KZW1haWw7aW50ZXJuZXQ6ZnJlZGR5LmFsbGlsYWlyZUBvYmVvLmZy DQp0aXRsZTpS
JkQgRW5naW5lZXINCnVybDp3d3cub2Jlby5mcg0KdmVyc2lvbjoyLjENCmVu ZDp2Y2FyZA0K
DQo=
--------------000509060606010609090203--
Re: [ATL] how to realize a simple loop [message #91709 is a reply to message #91605] Wed, 08 October 2008 06:08 Go to previous messageGo to next message
Originally posted by: jihed.touzi.enstimac.fr
Hi Robert
Actually you can't use a while pattern with ATL because simpy it doesn't
exist.
But you can use an equivalent to that according to algorithmics
principles. your problem is not only an ATL problem
: You have to use a recursive call of an ATL called rule joined to If
pattern use.
Below an example.
Supposes that you want do that
x=1
While x< 5
do { x<-x+1 }
with ATL you do that:
x<-1
thisModule.Calcul (x);
rule Calcul (x: integer)
do{
if (x<5)
{x<-x+1;
thisModule.Calcul (x);}}
Jihed
> little problem:
> My Model:
> RootObject
> Rob
Re: [ATL] how to realize a simple loop [message #91754 is a reply to message #91709] Wed, 08 October 2008 06:47 Go to previous message
Hi Jihed,
thank you very much, I think that this is exactly what I was looking for!
It´s really a clever way to get the standard-imperative-things with a
recursive algorithm!
Rob
jihed touzi schrieb:
> Hi Robert
> exist.
> pattern use.
> Below an example.
> x=1
> While x< 5
> do { x<-x+1 }
> x<-1
> do{
> if (x<5)
> {x<-x+1;
> Jihed
>> Hi,
>> little problem:
>> My Model:
>> RootObject
>> Rob
Previous Topic:[QVTO] Problems occurred when invoking code from plug-in: "org.eclipse.jface".
Next Topic:[QVTO] Text2Model
Current Time: Sun Aug 31 20:16:14 EDT 2025
Powered by FUDForum. Page generated in 0.04383 seconds
