Home » Eclipse Projects » P2 » Is there a way to perform a p2 headless update(headless update)
Is there a way to perform a p2 headless update [message #917151] Wed, 19 September 2012 17:35 Go to next message
Is there a way to check for available updates and apply them without having to launch eclipse and go through the UI?
Re: Is there a way to perform a p2 headless update [message #917782 is a reply to message #917151] Thu, 20 September 2012 08:32 Go to previous messageGo to next message
The director application is here for this.
http://help.eclipse.org/juno/index.jsp?topic=%2Forg.eclipse.platform.doc.isv%2Fguide%2Fp2_director.html&resultof=%22p2.director%22
To update a component from one version to the next you will need to specify both -installIU <iuIdToAdd> and -uninstall <iuToRemove>
Re: Is there a way to perform a p2 headless update [message #918035 is a reply to message #917782] Thu, 20 September 2012 13:20 Go to previous messageGo to next message
I was looking for something similar to the "check for updates" feature; which finds all available updates and applies them.
Re: Is there a way to perform a p2 headless update [message #930838 is a reply to message #918035] Tue, 02 October 2012 13:37 Go to previous messageGo to next message
In case anybody cares I was able to write a plug-in (containing headless application ) using
p2 core API's to accomplish this.
http://help.eclipse.org/indigo/index.jsp?topic=%2Forg.eclipse.platform.doc.isv%2Fguide%2Fp2_api_overview.htm
[Updated on: Tue, 02 October 2012 13:38] by Moderator
Re: Is there a way to perform a p2 headless update [message #930898 is a reply to message #930838] Tue, 02 October 2012 14:45 Go to previous messageGo to next message
Re: Is there a way to perform a p2 headless update [message #930899 is a reply to message #917151] Tue, 02 October 2012 14:46 Go to previous message
Previous Topic:Extra repositories
Next Topic:If can filter out *nls plugins(artifacts) when installing build?
Current Time: Fri Jul 18 22:00:01 EDT 2025
Powered by FUDForum. Page generated in 0.03932 seconds
