Home » Archived » BIRT » Dynamic "italics"?
Dynamic "italics"? [message #91637] Wed, 16 November 2005 10:55 Go to next message
I have a column value in a table that I'd like to dynamically change to
"italics" based on the value. In the following example, I'd like the
"null" value to be italics. Is this possible with BIRT?
if ( row["value"] == null ) {
"null"
} else {
row["value"]
Re: Dynamic "italics"? [message #91710 is a reply to message #91637] Wed, 16 November 2005 15:32 Go to previous message
Absolutely. With BIRT, you can format values based on conditions. Use the
Highlights page on the Property Editor. The UI walks you through specifying
formatting rules, so you don't need to write any code. For more information,
see the online documentation: Help-->Help Contents-->BIRT Developer
Guide-->Field Guide to BIRT-->Formatting report content-->Formatting data
"Owen Funkhouser" <eclipse@dafunks.com> wrote in message
news:dlfkqg$a2k$2@news.eclipse.org...
> "null"
> } else {
> row["value"]
Previous Topic:Nested lists advice, part deux
Next Topic:BIRT 2.0 IDEReportEditor.getFile() class cast exception
Current Time: Thu Nov 20 18:09:54 EST 2025
Powered by FUDForum. Page generated in 0.03974 seconds
