Home » Modeling » Papyrus » Automatic Generation of Diagrams.
Automatic Generation of Diagrams. [message #916833] Wed, 19 September 2012 10:25 Go to next message
It happens I have quite big UML models generated from QVT transformation. I'd like to automatically get some diagrams for these models (i.e. one class diagram for each package showing the contained class, on diagram for each class depicting the class' relationships, etc.). Is there a way to automatically generate such diagrams (i.e. a QVT transformation from the UML model to the .di model, provided there is a meta-model for the .di file) ?
Re: Automatic Generation of Diagrams. [message #916872 is a reply to message #916833] Wed, 19 September 2012 11:20 Go to previous messageGo to next message
Hello Andrea,
A QVT transformation from UML to Notation+Di is technically possible, although very (very, very, very) complex to implement.
The best way is to programatically use "DropObjectsRequests" to simulate a drop of a semantic element to a diagram (Which results in displaying the element graphically). There's a tool in the Papyrus extra plug-ins which relies on this strategy to generate diagrams from a predefined template. See "Diagram generation" in the Papyrus additional components, or "extraplugins/diagramtemplate/oep.diagramtemplates.*" on the SVN repository if you're only interested in the implementation.
Here's the basic java code to drop an element in a diagram:
Element elementToShow = getElementToShow(); //The UML Element to drop
EditPart targetEditPart = getTargetEditPart(); //The GMF EditPart which is the drop target (e.g. diagram root)
DropObjectsRequest dropObjectsRequest = new DropObjectsRequest();
ArrayList<Element> list = new ArrayList<Element>();
list.add(elementToShow);
dropObjectsRequest.setObjects(list);
dropObjectsRequest.setLocation(new Point(20, 100 * position));
Command commandDrop = editPart.getCommand(dropObjectsRequest); //The command is now ready to be executed
Camille
Re: Automatic Generation of Diagrams. [message #918547 is a reply to message #916872] Fri, 21 September 2012 01:36 Go to previous messageGo to next message
Hai Camille,
thank you for your kind support. I have just installed the Diagram generator additional component and I am trying to use the diagram template. I have created a new template for a chosen model, selected class diagram from the model king box, selected Class and Package from the For box and Operation and Property from the What box (under the Class meta-class). When I execute the template it just creates a diagram for each class and package without actually filling its contents. It seems I am missing something of the diagram generation process. Is there any tutorial for that?
Re: Automatic Generation of Diagrams. [message #918622 is a reply to message #918547] Fri, 21 September 2012 03:18 Go to previous messageGo to next message
Andrea,
The diagram generation documentation is available on the Papyrus SVN repository:
http://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.papyrus/branches/0.9.X/extraplugins/diagramtemplate/org.eclipse.papyrus.diagramtemplate.doc/resources/template-diaGen.pdf
Camille
Re: Automatic Generation of Diagrams. [message #919249 is a reply to message #918622] Fri, 21 September 2012 16:53 Go to previous messageGo to next message
Thank you Camille, It works fine and the pdf is clear.
Re: Automatic Generation of Diagrams. [message #963043 is a reply to message #918622] Mon, 29 October 2012 10:29 Go to previous message
thank you so much Camille
Previous Topic:how to create a sequence diagram with time modeling
Next Topic:Papyrus and FUML
Current Time: Wed Jul 23 05:23:17 EDT 2025
Powered by FUDForum. Page generated in 0.05308 seconds
