Home » Modeling » EMF » Docs and examples for EMF Fragment Paths?
Docs and examples for EMF Fragment Paths? [message #916578] Wed, 19 September 2012 03:32 Go to next message
Hi all,
is there some documentation (and/or examples) of what kinds of EMF
Fragment Path expressions might show up when serializing an EMF model
using XMIResources?
If not, here're my current concrete questions:
1. In Ecore models, you have EMF Fragment Expressions like #//Foo/bar.
Do I interpret it correctly as selection based on the value of the
name-attribute? E.g., from the root element, select the child
element with name = "Foo" and from that the child element with name =
"bar".
2. In instance models serialized to XMI, you have fragments like
//@foo.bars.17. Do I interpret it correctly as selection based on
XML element name? E.g., from the root element take the single <foo>
element, then select the 17th <bars> child of it.
3. If I'm correct above, can those forms occur in a mixed form, e.g.,
something like #//Foo/baz//@bars.17? And are there other expression
kinds that can occur when saving a model to XMI?
Bye,
Tassilo
Dipl.-Inform. Tassilo Horn | Room: B015
University of Koblenz-Landau, Campus Koblenz | Phone: +49 (261) 287-2745
Institute for Software Technology | Mail: horn@xxxxxxxx
Universitätsstr. 1, 56070 Koblenz, Germany |
Re: Docs and examples for EMF Fragment Paths? [message #916590 is a reply to message #916578] Wed, 19 September 2012 03:51 Go to previous messageGo to next message
Tassilo,
Comments below.
On 19/09/2012 9:32 AM, Tassilo Horn wrote:
> Hi all,
> using XMIResources?
Just a bit of Javadoc. In general a resource implementation
(ResourceImpl.getURIFragment) can produce pretty much anything...
> name-attribute?
Yes, you can see how this is specialized in
org.eclipse.emf.ecore.impl.EModelElementImpl.eURIFragmentSegment(EStructuralFeature,
EObject) and how its interpreted in
org.eclipse.emf.ecore.impl.EModelElementImpl.eObjectForURIFragmentSegment(String).
> "bar".
Exactly.
> XML element name?
Yes, but it's on the feature name, which in the presence of extended
metadata annotations could be different from the XML element name.
Exactly.
In theory, yes (but the double // in front of @bars is wrong; that would
imply there is an empty segment). But note that the Foo and the baz are
specific specializations in the Ecore model.
Often the fragments will be an ID not a fragment path; that's recognized
by the absence of a leading / in the fragment. With the use of
EReference.eKeys, you would also expect to see
@<feature-name>[<key1>='<value1>'{,<key-n>='<value-n'>}*]
> Bye,
> Tassilo
Re: Docs and examples for EMF Fragment Paths? [message #916639 is a reply to message #916590] Wed, 19 September 2012 05:02 Go to previous messageGo to next message
Ed Merks <ed.merks@xxxxxxxx> writes:
Hi Ed,
>> XML element name?
Ok.
>> And are there other expression kinds that can occur when saving a
>> model to XMI?
> recognized by the absence of a leading / in the fragment.
Ok, I've found another example:
/0/@classifiers.0/@typeParameters.0
So that means, take the 0th child element of root, then the 0th
classifiers child, and from that the 0th typeParameters element?
So I guess my previous example //@foo.bars.17 was wrong and it should
have been //@foo/@bars.17, right?
> With the use of EReference.eKeys, you would also expect to see
Do you have an XMI file handy that contains such an expression? If so,
it'll be cool if you could send it to me (as private mail if you want).
So to sum up:
// == the root element
/17/ == the 17th child element of root
/@feature == access by feature name (which is usually the xml element
name, but not always)
/@feature.17 == positional selection
/@feature[x = '17', y = '18'] == selection by keys
Still, I'm a bit unsure what the # mark means in
#//SomeEClass/someFeature
which occurs in eOpposite-attributes in ecore models. As said, // is
the root element, /Foo is access by name-attribute equality, but what
does the # mean?
Thanks a lot,
Tassilo
Re: Docs and examples for EMF Fragment Paths? [message #916799 is a reply to message #916639] Wed, 19 September 2012 09:29 Go to previous message
Tasslio,
I'd suggest looking closely at ResourceImpl, e.g.,
getEObject/getURIFragment and at BasicEObjectImpl's implementations of
eURIFragmentSegment and eObjectForURIFragmentSegment. This will make it
clear that the first segment is interpreted and create by the resource
implementation for locating an object within Resource.getContents() and
the remaining fragments are interpreted by the EObjects themselves for
navigating to their references.
In general an EObject is located by a URI containing a fragment. The
thing before the fragment locates the resource, and the resource uses
the fragment to locate the object within that resource. The
deserializer looks at references and if there is a #, it knows to
interpret it as a URI, if there is no #, it interprets it as only the
fragment and that the reference must be in the current resource.
> Hi Ed,
>>> XML element name?
> Ok.
>>> model to XMI?
> So to sum up:
> does the # mean?
> Thanks a lot,
> Tassilo
Previous Topic:[Teneo] Error when storing EAttribute
Next Topic:[Teneo] Recommended way to override Java to DB Type Mapping for various databases
Current Time: Sat Jul 26 21:33:46 EDT 2025
Powered by FUDForum. Page generated in 0.09759 seconds
