Home » Archived » Buckminster » org.eclipse.core.runtime bundle Problem
Re: org.eclipse.core.runtime bundle Problem [message #925005 is a reply to message #916548] |
Thu, 27 September 2012 05:58   |
These are some draft notes on how to solve the dreaded "java returned 13" when using Buckminster to build an Eclipse product. I'll publish them once they are tidied up.
The problem
You have successfully checked out your source code, and you workspace builds without error. However, when you attempt to create a stand-alone product (typically, via "Buckminster --> Invoke Action --> create.product" or similar), you get "java returned 13".
The cause
This error is actually nothing to do with Buckminster, but instead is issued by Eclipse's underlying PDE build. The problem can be illustrated by a simple example:
We have 3 features and 4 plugins:
base.feature = plugins: plugin.1, plugin.2
plotting.feature = plugins: plugin.3, plugin.4
product.feature = feature: base.feature, plotting.feature
The workspace will build successfully, and the product will be created successfully.
Now imaging we write a new plugin, plugin.5, and make plug.4 depend on it.
The workspace will build successfully, but the product will not be created, but instead give "java returned 13".
What happens is that when we create the product.feature, it constructs a list of feature and plugins that will make up the product. This is done by starting at the parent feature (product.feature in our example), and following all the features it points to, and then all the features they point to, etc etc. From each feature it includes all plugins listed in that feature. However, it does NOT include plugsin listed in other plugins, even if they are in the workspace. So, every plugin you need for your product must be listed in each some feature that is reachable from the parent feature.
In the example above, the new "plugin.5" needs to be added as a dependency of some feature. If we added it to product.feature, that would work, but it's not actually the correct place to add it. I should really be added to plotting.feature, since any other consumer of that will need plugin.5 (since plotting.feature includes plugin.4, and that requires plugin.5).
How to diagnose
If you get "java returned 13", then the first step is to work out what plugin is missing. Go to Window --> Preferences --> Buckminster, and increase the "Ant logger level:" to INFO. Then rerun the product create action. In the console window, near the bottom, you will see what plugin is missing, and why. Simply add it in to the correct feature, and then rerun the product create. Either the problem will be solved, or another dependency will be identified.
Matthew Webber
Re: org.eclipse.core.runtime bundle Problem [message #933684 is a reply to message #933619] |
Fri, 05 October 2012 04:37   |
I think it would be worth trying to follow the layout of the example projects from the Bucky-book, I normally do and don't have the problems you're having.
Have a top level feature project, which is the 'Buckminster' project or 'releng' project, containing rmaps, cquery, target-platform definitions etc.
Have a top-level feature project which is the 'application' project, containing all the sub-features and/or plug-ins you need in your application.
I usually have the .product file in the 'application' project, and it includes just the application feature.
Add the application feature as a component to your 'Buckminster' project's feature.xml.
When you select site.p2 on the 'releng' project, Buckminster will build the p2 site for the content of the 'releng' project, i.e. a p2 site for the 'application' feature.
The dependencies on org.eclipse.rcp etc are all very well, but you also need to make sure that either your top-level application feature includes the org.eclipse.rcp feature, or one of its sub-features does.
In order for director to build the product, you need to have all the component plugins, including org.eclipse.rcp, in the p2 site that you created, or you need to point director to multiple repositories so it can find the 'depended-on' plug-ins elsewhere.
I'm not sure what you mean when you describe you Product Project as a plug-in, but it has dependecies on features...how did you manage that? Plug-ins can only have dependencies on other plug-ins (or java packages). Features can include other features or plug-ins.
Finally, I haven't done any p2 updating stuff with my projects, so I don't understand exactly what you need to do the updating...
Hope that helps...
Alan
Re: org.eclipse.core.runtime bundle Problem [message #934821 is a reply to message #933684] |
Sat, 06 October 2012 06:32   |
sorry if I use this thread for asking the question, but it's strictly
related to the above paragraph, and on the original problem (I can start
a new thread if required).
I found the above issue a quite recurrent problem when building a
product with Bucky, by problem I mean that it is something not clear to
most people I talked with (though I think it's related to p2, not to
Bucky itself :)
I was wondering which is the best way of achieving "to build the
component plugins in the p2 site that you created";
these are the alternative solutions I usually use
1. as a first solution I add additional repositories URL in the ant file
to build the product, e.g., by changing
<arg value="-repository"/>
<arg value="${repository}"/>
to
<arg value="${repository},http://download.eclipse.org/juno,...and
others..."/>
this is a quick solution, but it requires to contact all the additional
remote update sites each time the product is built...
while all the available plugins and features would be already available
in the local target platform (otherwise my own bundles wouldn't have
built themselves)
2. for creating the p2 site for building the product, I have a feature
(I mean, in the releng project) which basically contains all the
features (and possibly single plugins) I use in my local target
platform... this usually works apart from some features which make Bucky
search for source features which are not there (this is related to this
thread http://www.eclipse.org/forums/index.php/m/927264/ which still did
not provide replies...)
this second solution still looks strange to me, since I have to
duplicate effort anyway... unless there's a direct way of generating a
p2 site from the current target platform.
so I was wondering which the best practice is...
the tutorials I found around did not help me much, since they are
typically based on very simple products which besides org.eclipse.rcp do
not need many other features...
thanks in advance
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: org.eclipse.core.runtime bundle Problem [message #938907 is a reply to message #934821] |
Wed, 10 October 2012 05:04  |
Lorenzo
I look at it this way:
If I wanted my feature to include target platform features and plug-ins because it makes sense to do so, then I add those target platform features as part of my feature. This means that if I publish the p2 site for my feature it will include those target features and plug-ins. If I want to produce a product from my feature then I only point director at my p2 site.
If I don't want to to include target platform features and plug-ins, then I don't; but if I depend on them for a product I produce from my feature then I will need to point director at the p2 sites that contain those target platform features and plug-ins as well as the p2 site for my feature.
Therefore I think it depends on what you are making your feature and product for. I think most eclipse features do not include the target platform f's & p's because they are to be consumed as p2 sites for installing into a p2 product. However, if you are making your feature for use mainly to generate a product, it may make sense to include the dependencies from the target platform in your feature so everything is in one p2 site. This makes it slightly easier to create the product, as you only have to specify one p2 repository to director, but it also means you have to make sure you don't miss any dependencies from your features or they won't be in the p2 site and director will fail.
Another area to consider is p2 updating. What site or sites do you want to update your application from and how do you configure it?
Not sure if that helps...
Alan
Current Time: Sat Jul 19 02:06:27 EDT 2025
Powered by FUDForum. Page generated in 0.06560 seconds
