Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] StoreValidationException
[Teneo] StoreValidationException [message #91626] Tue, 24 July 2007 09:14 Go to next message
Originally posted by: fc_supercanard.yahoo.fr
I wrote a simple class to create tables using DB2.
Then I would like to fulfill tables from an xml file.
So I take what I want from the file, into an EList, and I make this :
eListDatabase.addAll(eListFile)
This 'modus operandi' works well for different xml files, but it throws
a StoreValidationException for another one.
Exception in thread "main"
org.eclipse.emf.teneo.StoreValidationException: Diagnosis of
package.impl.ClassNameImpl1@77407740{jpox://?dsname=MyPMF&am p;query1=select
from package.impl.ClassNameImpl2#package.ClassNamePortlets}
The required feature 'title' of
' package.impl.ClassNameImpl1@77407740{jpox://?dsname=MyPMF&am p;query1=select
from package.impl.ClassName2#package.ISCAdminPortlets}' must be set
at
org.eclipse.emf.teneo.resource.StoreResource.validateContent s(StoreResource.java:426)
at
org.eclipse.emf.teneo.resource.StoreResource.save(StoreResou rce.java:360)
at DatastoreInstall.importModule(DatastoreInstall.java:280)
at DatastoreInstall.importContents(DatastoreInstall.java:128)
at DatastoreInstall.init(DatastoreInstall.java:55)
at DatastoreInstall.main(DatastoreInstall.java:320)
This 'title' is an element which is in a sequence of ClassNameImpl1 type
in the XML schema. But I do not understand why it is considered as a
'required feature' by Teneo.
In DB2, there is a Nullable=yes field TEXT_TITLE in the corresponding table.
Furthermore, if I add this title element in the XML file, it throws this
other Exception :
Exception in thread "main" javax.jdo.JDOFatalUserException: An object of
class "package.impl.TextImpl" uses SingleFieldIdentity using the field
"uniqueName" yet this field has not had its value set! Either set the
field manually, or set a value-strategy for that field.
at org.jpox.state.StateManagerImpl.setIdentity(StateManagerImpl .java:874)
at org.jpox.state.StateManagerImpl.<init>(StateManagerImpl.java:625)
at
org.jpox.state.StateManagerFactory.newStateManager(StateMana gerFactory.java:105)
at
org.jpox.AbstractPersistenceManager.internalMakePersistent(A bstractPersistenceManager.java:1205)
at
org.jpox.AbstractPersistenceManager.makePersistentInternal(A bstractPersistenceManager.java:1259)
at org.jpox.store.mapping.MultiMapping.setObject(MultiMapping.j ava:181)
at
org.jpox.store.rdbms.fieldmanager.ParameterSetter.storeObjec tField(ParameterSetter.java:144)
at
org.jpox.state.StateManagerImpl.providedObjectField(StateMan agerImpl.java:2771)
at
com.ibm.isclite.wccm.portletentities.impl.ApplicationDefinit ionImpl.jdoProvideField(ApplicationDefinitionImpl.java)
at
com.ibm.isclite.wccm.portletentities.impl.ApplicationDefinit ionImpl.jdoProvideFields(ApplicationDefinitionImpl.java)
at
org.jpox.state.StateManagerImpl.provideFields(StateManagerIm pl.java:3115)
at
org.jpox.store.rdbms.request.InsertRequest.execute(InsertReq uest.java:252)
at org.jpox.store.rdbms.table.ClassTable.insert(ClassTable.java :2519)
at org.jpox.store.StoreManager.insert(StoreManager.java:938)
at
org.jpox.state.StateManagerImpl.internalMakePersistent(State ManagerImpl.java:3667)
at
org.jpox.state.StateManagerImpl.makePersistent(StateManagerI mpl.java:3646)
at
org.jpox.AbstractPersistenceManager.internalMakePersistent(A bstractPersistenceManager.java:1206)
at
at
org.jpox.store.rdbms.scostore.FKListStore.validateElementFor Writing(FKListStore.java:1231)
at
org.jpox.store.rdbms.scostore.FKListStore.internalAdd(FKList Store.java:772)
at
org.jpox.store.rdbms.scostore.AbstractListStore.add(Abstract ListStore.java:352)
at org.jpox.sco.ArrayList.add(ArrayList.java:780)
at
org.eclipse.emf.teneo.jpox.elist.EListWrapper.didAdd(EListWr apper.java:594)
at
org.eclipse.emf.common.util.DelegatingEList.addAllUnique(Del egatingEList.java:652)
at
org.eclipse.emf.common.notify.impl.DelegatingNotifyingListIm pl.doAddAllUnique(DelegatingNotifyingListImpl.java:486)
at
org.eclipse.emf.common.notify.impl.DelegatingNotifyingListIm pl.addAllUnique(DelegatingNotifyingListImpl.java:459)
at
org.eclipse.emf.common.notify.impl.DelegatingNotifyingListIm pl.addAllUnique(DelegatingNotifyingListImpl.java:388)
at
org.eclipse.emf.common.util.DelegatingEList.addAll(Delegatin gEList.java:573)
at DatastoreInstall.importModule(DatastoreInstall.java:275)
In the XML schema, the "uniqueName" attribute of module is :
<xs:attribute name="uniqueName" type="xs:ID" use="optional"/> (it is an
attribute of Text type which is a table also).
It is required because in DB2 database, uniqueName is the primary key of
the Text table so it can not be null. But why this attribute is the
primary key of the table ? How could I change it ?
Note : everything works well if I add manually title elements with
uniqueName attribute in the XML file.
Quentin
Re: [Teneo] StoreValidationException [message #91675 is a reply to message #91626] Tue, 24 July 2007 23:44 Go to previous message
The StoreValidationException is not thrown by Teneo but by EMF when validating the content of the
resource you are saving. So in your model the minOccurs of the title feature is probably 1 or
required is true.
Regarding the second exception, the xsd:ID type is automatically considered to be the primary key
(the id) of the class. You can disable this by setting the option ID_FEATURE_AS_PRIMARY_KEY to false.
gr. Martin
french.cancan wrote:
> Hello,
> at
> at
> table.
> other Exception :
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Regards,
> Quentin
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] StoreValidationException [message #608889 is a reply to message #91626] Tue, 24 July 2007 23:44 Go to previous message
required is true.
gr. Martin
> Hello,
> at
> at
> table.
> other Exception :
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Regards,
> Quentin
The Netherlands
Previous Topic:Writing a DiffModel as .uml
Next Topic:SQLCaseStrategy
Current Time: Wed Jul 23 06:09:34 EDT 2025
Powered by FUDForum. Page generated in 0.48903 seconds
