Home » Modeling » EMF » Problem with cross references
Problem with cross references [message #916167] Tue, 18 September 2012 12:37 Go to next message
I have implemented a simple drag and drop from the navigator into my editor.
I want to validate the dropped file before adding, so I used the Diagnostician, but there is always a unresolved proxy.
I know which files missing so I added all to the ResourceSet. Here is my problem I think, because I use the absolute path (projectfolder/folder/file) from the workspace the resolve doesn't work.
I have tried it with EcoreUtil.resolve(object, resourceSet).
In the file the reference is like (folder/file).
Thanks for any advices.
Re: Problem with cross references [message #916204 is a reply to message #916167] Tue, 18 September 2012 14:09 Go to previous messageGo to next message
John,
Comments below.
On 18/09/2012 6:37 PM, John M. wrote:
> Hello,
> editor.
It's important that when you load a resource into a resource set you do
so with a proper absolute URI so that relative URIs within the
serialization are properly resolved to absolute URIs.
It should be demand loaded.
For accessing workspace resources, you should use a URI as created by
URI.createPlatformResourceURI
* 2.44 How do I map between an EMF Resource and an Eclipse IFile?
<http://wiki.eclipse.org/index.php/EMF-FAQ#How_do_I_map_between_an_EMF_Resource_and_an_Eclipse_IFile.3F>
Re: Problem with cross references [message #918709 is a reply to message #916204] Fri, 21 September 2012 05:13 Go to previous message
Thanks for the advice to use URI.createPlatformResourceURI, that solved the problem.
Previous Topic:Problem with with mutually referencing ELists
Next Topic:[CDO] Error while committing the transaction
Current Time: Fri Jul 25 23:40:53 EDT 2025
Powered by FUDForum. Page generated in 0.04838 seconds
