JavaFX Panel makes WindowBuilder Crash [message #916164] |
Tue, 18 September 2012 12:33  |
Hello!
Im new to developing with Swing and JavaFX and I have a problem when using WindowBuilder.
Im using Ubuntu 12.04 x64 and Oracle Java 7.
If I create a new instance of JFXPanel and then open the Designer view, the JVM would crash. Is this a common problem? any workaround?
This is the class im wrote:
package view;
import java.awt.EventQueue;
import javafx.embed.swing.JFXPanel;
import javax.swing.JFrame;
import net.miginfocom.swing.MigLayout;
public class Start {
private JFrame frame;
* Launch the application.
EventQueue.invokeLater(new Runnable() {
public void run() {
try {
Start window = new Start();
window.frame.setVisible(true);
} catch (Exception e) {
e.printStackTrace();
* Create the application.
public Start() {
initialize();
* Initialize the contents of the frame.
private void initialize() {
frame = new JFrame();
frame.setBounds(100, 100, 450, 300);
frame.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
frame.getContentPane().setLayout(new MigLayout("", "[grow]", "[][grow][]"));
JFXPanel myFXPanel = new JFXPanel();
frame.add(myFXPanel);
And this is the message Eclipse gives me:
JVM terminated. Exit code=1
/usr/bin/java
-Xms40m
-Xmx384m
-Dorg.eclipse.equinox.p2.reconciler.dropins.directory=/usr/share/eclipse/dropins
-XX:MaxPermSize=256m
-jar /usr/lib/eclipse//plugins/org.eclipse.equinox.launcher_1.3.0.dist.jar
-os linux
-ws gtk
-arch x86_64
-showsplash /usr/lib/eclipse//plugins/org.eclipse.platform_3.8.0.dist/splash.bmp
-launcher /usr/lib/eclipse/eclipse
-name Eclipse
--launcher.library /usr/lib/eclipse//plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.200.dist/eclipse_1503.so
-startup /usr/lib/eclipse//plugins/org.eclipse.equinox.launcher_1.3.0.dist.jar
--launcher.overrideVmargs
-exitdata 292c0004
-vm /usr/bin/java
-vmargs
-Xms40m
-Xmx384m
Thank you
Edit: The same happens in Windows 7 X64 using Oracle Java 7
[Updated on: Wed, 19 September 2012 10:54] by Moderator
FUDForum. Page generated in 0.04751 seconds
