Home » Modeling » ATL » One to many transformation
One to many transformation [message #911862] |
Wed, 12 September 2012 09:16  |
Hi All,
I have a scenario which a target model should create a sequence of classes due to the list of Strings another class holds.
The code snippet below illustrates the problem. I have FindClause which has bindingObjects whichs holds a list of aliases (EStrings).
For each Aliases I have to create a ObjectSource class which alias will be each FindClause.bindingObject.Alias of the list and className will be an String according to the type attribute of BindingObject.
I started a rule Find2From and created a helper to return the className based on FindClause.bindingObject.type, however how to fill alias attribute based on the FindClause.bindingObject.alias list ?
Many thanks in advance.
**** INModel ****
+-FindClause (clause : EString, bindingObject : BindingObject (1..*))
+-BindingObject (type : ObjectType, alias : EString (1..*))
+-ObjectType ( value : EString)
*******OUTModel*******
+-FromClause (clause : EString, objectList : ObjectSource (1.*))
+-ObjectSource(alias : EString, className : EString)
rule Find2From {
from
findClause : ajqlModel!FindClause
to
fromClause : hqlModel!FromClause (
clause <- 'From',
ObjectSource <- Sequence {source}
source : hqlModel!ObjectSource (
-- className <- thisModule.getObjectName(findClause.bindingObject.type)
-- alias <- ?[/color]??
Re: One to many transformation [message #915761 is a reply to message #915514] |
Mon, 17 September 2012 19:02   |
Hi Hugo,
Thanks for your tips.
I tried to insert flatten() into the statement, but without any success.
In order to understand what is going on, I just break down the structure into imperative statements to collect more information about it. I tried some debug statements and even debug environment, but it does not help me a lot.
This is the code I tried to change with flatten() clause.
ObjectList <- query1Clause.query.find.bindingObject -> collect (bindIt | bindIt.alias -> collect (aliasIt | thisModule.getSourceObject(bindIt.type, aliasIt ))) -> flatten()
The error remains the same : org.eclipse.m2m.atl.engine.emfvm.VMException: Operation not found: AJQL2HQL : ASMModule.including(java.util.ArrayList)
I broke down the structure like this :
1. Remove ObjectList from fromClause :
_fromClause : hqlModel!FromClause(
clause <- 'From'
2. Then I wrote a simple imperative code to figure out what's going on :
do {
'debuging...'.println();
for (it in query1Clause.query.find.bindingObject) { -- iterates over bindingObject
'bindingObj...'.println();
thisModule.getObjectName(it.type).println();
for (it2 in it.alias) { -- iterates over alias inside bindingObjects
_fromClause.ObjectList -> including(thisModule.getSourceObject (it.type, it2));
-- append ObjectSource to ObjectList (try to at least) - Here the error raises
This approach leads to a java.lang.ArrayIndexOutOfBoundsException exception
The iteration is working fine, I could see every information when traversing the model, even getSourceObject helper. The issue has been raised when trying to fill out the list property (
I'm trying different paths in order to solve this problem, unfortunately without success. Do you have any another advise or some debug tip I could use ?
Many thanks Hugo for your assistance.
Re: One to many transformation [message #916099 is a reply to message #915933] |
Tue, 18 September 2012 10:22   |
Hi Hugo,
I'll keep the original declarative issue per your recommendation. The imperative code was just to try to break down the problem.
Debugging the expression like this
-> collect (aliasIt | thisModule.getSourceObject(bindIt.type, aliasIt).debug()
I can see this result after the first iteration :
Sequence {Sequence {}}
OK, according to your previous message, since collect over collect will generate a sequence over a sequence.
Debug(), in this case, is running before trying to insert ObjectSource object into the sequence. The problem seems the Sequence expects a Sequence and not a single object returned by getSourceObject(..). Even though, I believe that the message Operation not found ASMModule.including(java.util.ArrayList) would not be appropriate in this situation since it is a Sequence anyway. But I'm not sure if this would be the problem.
I tried to flat the sequence before inserting but without success as well.
I shared a small project focused on this problem containing ecore metamodel, a simple model and atl files. This is the project I'm currently working on to try to solve the issue. If you can take a look Hugo, I'd be very very grateful.
www.defavari.com.br/public/ATLProject/
Thank you again.
Re: One to many transformation [message #916139 is a reply to message #916135] |
Tue, 18 September 2012 11:53   |
Yes, I tried flatten() at the end also. Same issue.
By the way, the stack shows something like
...(name: QueryStatement) (instanceClassName: null) ...
In my perception, this instanceClassName: null does not have any influence on that. I checked my ecore model, validate it (EMF tools) and check it visually as well. It seems OK.
Cristiano
at __applyQuery2Query#97(AJQL2HQL.atl[27:29-28:85])
local variables: self=AJQL2HQL : ASMModule, link=TransientLink {rule = Query2Query, sourceElements = {query1Clause = [email]org.eclipse.emf.ecore.impl.DynamicEObjectImpl@430636bc[/email] (eClass: [email]org.eclipse.emf.ecore.impl.EClassImpl@78993cb9[/email] (name: Query) (instanceClassName: null) (abstract: false, interface: false))}, targetElements = {_queryStatement = [email]org.eclipse.emf.ecore.impl.DynamicEObjectImpl@4cf39304[/email] (eClass: [email]org.eclipse.emf.ecore.impl.EClassImpl@40d3853d[/email] (name: QueryStatement) (instanceClassName: null) (abstract: false, interface: false)), _whereClause = [email]org.eclipse.emf.ecore.impl.DynamicEObjectImpl@b391314[/email] (eClass: [email]org.eclipse.emf.ecore.impl.EClassImpl@7ed0890a[/email] (name: WhereClause) (instanceClassName: null) (abstract: false, interface: false)), _selectClause = [email]org.eclipse.emf.ecore.impl.DynamicEObjectImpl@50138bcd[/email] (eClass: [email]org.eclipse.emf.ecore.impl.EClassImpl@60679695[/email] (name: SelectClause) (instanceClassName: null) (abstract: false, interface: false)), _fromClause = [email]org.eclipse.emf.ecore.impl.DynamicEObjectImpl@333f68cd[/email] (eClass: [email]org.eclipse.emf.ecore.impl.EClassImpl@30cf41a5[/email] (name: FromClause) (instanceClassName: null) (abstract: false, interface: false)), _expression = [email]org.eclipse.emf.ecore.impl.DynamicEObjectImpl@7f98504[/email] (eClass: [email]org.eclipse.emf.ecore.impl.EClassImpl@2cd53091[/email] (name: Expression) (instanceClassName: null) (abstract: false, interface: false)), query2Clause = [email]org.eclipse.emf.ecore.impl.DynamicEObjectImpl@e8bcdb3[/email] (eClass: [email]org.eclipse.emf.ecore.impl.EClassImpl@83fdb62[/email] (name: Query) (instanceClassName: null) (abstract: false, interface: false))}, variables = {}}, query1Clause=IN!<unnamed>, query2Clause=OUT!<unnamed>, _queryStatement=OUT!<unnamed>, _selectClause=OUT!<unnamed>, _fromClause=OUT!<unnamed>, _whereClause=OUT!<unnamed>, _expression=OUT!<unnamed>, bindIt=IN!<unnamed>, aliasIt='b'
at __exec__#8(AJQL2HQL.atl)
local variables: self=AJQL2HQL : ASMModule, e=TransientLink {rule = Query2Query, sourceElements = {query1Clause = [email]org.eclipse.emf.ecore.impl.DynamicEObjectImpl@430636bc[/email] (eClass: [email]org.eclipse.emf.ecore.impl.EClassImpl@78993cb9[/email] (name: Query) (instanceClassName: null) (abstract: false, interface: false))}, targetElements = {_queryStatement = [email]org.eclipse.emf.ecore.impl.DynamicEObjectImpl@4cf39304[/email] (eClass: [email]org.eclipse.emf.ecore.impl.EClassImpl@40d3853d[/email] (name: QueryStatement) (instanceClassName: null) (abstract: false, interface: false)), _whereClause = [email]org.eclipse.emf.ecore.impl.DynamicEObjectImpl@b391314[/email] (eClass: [email]org.eclipse.emf.ecore.impl.EClassImpl@7ed0890a[/email] (name: WhereClause) (instanceClassName: null) (abstract: false, interface: false)), _selectClause = [email]org.eclipse.emf.ecore.impl.DynamicEObjectImpl@50138bcd[/email] (eClass: [email]org.eclipse.emf.ecore.impl.EClassImpl@60679695[/email] (name: SelectClause) (instanceClassName: null) (abstract: false, interface: false)), _fromClause = [email]org.eclipse.emf.ecore.impl.DynamicEObjectImpl@333f68cd[/email] (eClass: [email]org.eclipse.emf.ecore.impl.EClassImpl@30cf41a5[/email] (name: FromClause) (instanceClassName: null) (abstract: false, interface: false)), _expression = [email]org.eclipse.emf.ecore.impl.DynamicEObjectImpl@7f98504[/email] (eClass: [email]org.eclipse.emf.ecore.impl.EClassImpl@2cd53091[/email] (name: Expression) (instanceClassName: null) (abstract: false, interface: false)), query2Clause = [email]org.eclipse.emf.ecore.impl.DynamicEObjectImpl@e8bcdb3[/email] (eClass: [email]org.eclipse.emf.ecore.impl.EClassImpl@83fdb62[/email] (name: Query) (instanceClassName: null) (abstract: false, interface: false))}, variables = {}}
at main#24(AJQL2HQL.atl)
[Updated on: Tue, 18 September 2012 11:54] by Moderator
Current Time: Fri Jul 25 06:55:02 EDT 2025
Powered by FUDForum. Page generated in 0.62129 seconds
