Home » Eclipse Projects » Equinox » Equinox shuts down after 30 seconds of inactivity
Equinox shuts down after 30 seconds of inactivity [message #916039] Tue, 18 September 2012 08:50 Go to next message
Hello
I have an 'application' (not an eclipse application, hence the noshutdown and ignoreApp arguments below) that runs in an equinox osgi container. It is a sort of a server and if doesn't get any incoming message it shuts down exactly after 30 seconds. It's definitely not the socket's fault, I've already checked it.
Also, if I start the app with the -console argument the framework doesn't shut down, but leaving it that way is not a good idea for production...
These are the standard args I use:
-consoleLog
-clean
-vmargs
-Declipse.ignoreApp=true
-Dosgi.noShutdown=true
-XX:+UnlockDiagnosticVMOptions
-XX:+UnsyncloadClass
What might cause this automatic shutdown despite the (I think) proper arguments?
Re: Equinox shuts down after 30 seconds of inactivity [message #916087 is a reply to message #916039] Tue, 18 September 2012 10:01 Go to previous messageGo to next message
This looks to be bug 310426. What version of Equinox are you using. If it is earlier than 3.7 then try setting the following property:
osgi.framework.activeThreadType=normal
HTH
Tom
Re: Equinox shuts down after 30 seconds of inactivity [message #916093 is a reply to message #916087] Tue, 18 September 2012 10:14 Go to previous message
Hello
Based on the org.eclipse.osgi bundle's version we're using 3.5.1 (org.eclipse.osgi_3.5.1.R35x_v20090827.jar).
I inserted the property:
-Dosgi.framework.activeThreadType=normal
and it seems to be working now.
thanks!
david
Previous Topic:Import-Package version matching
Next Topic:Show consumed Application Arguments
Current Time: Wed Jul 23 12:11:37 EDT 2025
Powered by FUDForum. Page generated in 0.08040 seconds
