Home » Newcomers » Newcomers » Password Required Query(Continuous password required window)
Password Required Query [message #916002] Tue, 18 September 2012 07:39 Go to next message
I am fairly new to Eclipse and Java so require some guidance on a question.
Recently when I start Eclipse each day a small window appears title "Password Required", and can be seen in the attached file.
I have tried my organisation network login a number of times but it continouously appears about 6 or 7 times then stops. Can anyone tell me what this is for please?
Is it to do with an addin from the Eclipse Marketplace perhaps?
Thanks in advance
AJF
[Updated on: Tue, 18 September 2012 07:40] by Moderator
Re: Password Required Query [message #916188 is a reply to message #916002] Tue, 18 September 2012 13:17 Go to previous messageGo to next message
That looks bogus. Check to see if you have the Datatools plugins installed. Remove them if you don't need them.
Re: Password Required Query [message #916649 is a reply to message #916188] Wed, 19 September 2012 05:23 Go to previous messageGo to next message
Hi Denis,
Thanks for your reply. What exactly do you mean when you say "bogus"?
I have checked through the Eclipse Marketplace interface to see what plugins I have installed and there are only 3. Those being FindBugs, Subclipse and Spring
Hope this helps you bring light to this question
Thanks again
A Farroll
Re: Password Required Query [message #916808 is a reply to message #916649] Wed, 19 September 2012 09:49 Go to previous message
I say "bogus" because that dialog is not telling you what the credentials are used for. I would not type anything in there.
If you go to Help > About Eclipse there should be a button called Installation Details. That would reveal other plugins that may be responsible for the dialog.
Previous Topic:Icon glossary?
Next Topic:Error: Could not find or load main class
Current Time: Sat Jul 26 03:28:33 EDT 2025
Powered by FUDForum. Page generated in 0.29680 seconds
