[CDO] Bug in error handling causes misleading LegacyModeNotEnabledException [message #915628] |
Mon, 17 September 2012 12:58  |
Hi CDO team,
I ran into a problem where my previously working model was getting a "Legacy mode is not enabled" message like the following:
Caused by: org.eclipse.emf.cdo.util.LegacyModeNotEnabledException: Legacy mode is not enabled
at org.eclipse.emf.spi.cdo.FSMUtil.adapt(FSMUtil.java:101)
at org.eclipse.emf.cdo.server.ocl.OCLQueryHandler.getRevision(OCLQueryHandler.java:204)
at org.eclipse.emf.cdo.server.ocl.OCLQueryHandler.addResult(OCLQueryHandler.java:195)
at org.eclipse.emf.cdo.server.ocl.OCLQueryHandler.executeQuery(OCLQueryHandler.java:175)
... 7 more
I found that the problem was not due to problems with my objects but due to the mishandling of an error object coming back from an OCL call which was being passed on for further processing as a model object. Here is the code I believe to be in error:
Object result = evaluate(query, object);
if (result instanceof Collection<?>)
for (Object element : (Collection<?>)result)
if (!addResult(element, context, view))
break;
else
addResult(result, context, view);
The result coming back from evaluate() is an OclInvalid object -- signifying that the evaluation failed -- and since the object isn't an instance of a collection it is passed to the addResult() method. FSMUtil then tries to adapt the object in order to get its revision history which fails with the LegacyModeNotEnabled exception since OclInvalid isnt in the model. Ideally the code should be checking for any of the OclStandardLibrary error objects and returning the error information to the caller.
Should I open a bugzilla defect for this?
Warwick
Re: [CDO/OCL] Bug in error handling causes misleading LegacyModeNotEnabledException [message #915932 is a reply to message #915862] |
Tue, 18 September 2012 04:36   |
Hi Eike
This seems remarkably adjacent to existing issues.
From an OCL perspective it is not clear that the OclInvalid result is
not a 'valid' result that should propagate back to the caller. Certainly
invalid is a defined OCL result.
This issue may have further ramifications if/when OCL acquires a
constructor syntax that supports object creation; such objects would
also not be in the model.
And on further reflection an OCL query involving Collection.product may
return a Tuple which is also an object that is not in the model.
So I think the problem is to do with passing OCL returns back to the
caller rather than with the OCL returns themselves.
Ed Willink
On 18/09/2012 06:18, Eike Stepper wrote:
> Am 17.09.2012 18:58, schrieb Warwick Burrows:
>> Hi CDO team,
>> at
>> at
>> at
>> ... 7 more
>> break;
>> else
> Strange that this didn't pop up earlier. Yes, please submit a bugzilla
> against EMF/cdo.core.
> Cheers
> /Eike
> http://www.esc-net.de
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
FUDForum. Page generated in 0.05083 seconds
