Home » Eclipse Projects » Eclipse Scout » DataSourceSecurityFilter ClassNotFoundException
DataSourceSecurityFilter ClassNotFoundException [message #915505] Mon, 17 September 2012 08:31 Go to next message
I have an application up and running and it works fine (it loads data from the database). So I think everything works OK with the database driver.
When I turn the DataSourceSecurityFilter on, and try to login, I get an ClassNotFoundException on com.microsoft.sqlserver.jdbc.SQLServerDriver.
My config file looks like
org.eclipse.scout.http.servletfilter.security.DataSourceSecurityFilter#active=true
org.eclipse.scout.http.servletfilter.security.DataSourceSecurityFilter#jdbcDriverName=com.microsoft.sqlserver.jdbc.SQLServerDriver
org.eclipse.scout.http.servletfilter.security.DataSourceSecurityFilter#jdbcMappingName=jdbc:sqlserver://xxxx;databaseName=xxx
org.eclipse.scout.http.servletfilter.security.DataSourceSecurityFilter#jdbcUsername=xxxx
org.eclipse.scout.http.servletfilter.security.DataSourceSecurityFilter#jdbcPassword=xxxx
org.eclipse.scout.http.servletfilter.security.DataSourceSecurityFilter#selectUserPass=SELECT name FROM con_account WHERE name=? and password=?
It picks-up this configuartion so I think it is OK.
So what else do I have to do to make it find the class SQLServerDriver for the authentication process
Regards Bertin
Re: DataSourceSecurityFilter ClassNotFoundException [message #915572 is a reply to message #915505] Mon, 17 September 2012 10:52 Go to previous messageGo to next message
This should work. I do the same thing with an Oracle Database.
1.
Are you sure that your fragment/plugin containing com.microsoft.sqlserver.jdbc.SQLServerDriver is loaded when the server is running (-> OSGi). You can configure this with your *.product file.
2.
Are you sure that org.eclipse.scout.http.servletfilter.security.DataSourceSecurityFilter is correct (it has changed with 3.7.2. See Bug 361256 or migrate from 3.7 to 3.8)
I have no other idea.
Re: DataSourceSecurityFilter ClassNotFoundException [message #930620 is a reply to message #915572] Tue, 02 October 2012 09:46 Go to previous messageGo to next message
we still don't have it running with security enabled.
What do you mean with:
Regards Bertin
Re: DataSourceSecurityFilter ClassNotFoundException [message #931495 is a reply to message #930620] Wed, 03 October 2012 05:02 Go to previous messageGo to next message
you want to use com.microsoft.sqlserver.jdbc.SQLServerDriver as jdbc driver.
Where is this class?
With "Open Type" window (CTR-Shift-T), when you enter "SQLServerDriver" do you see it?
The corresponding Plugin or Fragment needs to be available in your Scout Application (As you would do for any RCP Application - this is not something specific to Eclipse Scout. In the JavaSE world, this correspond to adding a Jar on the classpath).
=> Add JDBC Drivers for Eclipse Scout (So far I know, there is no support for microsoft SQL Server on the marketplace)
=> Write a jdbc connection bundle
icon7.gif  Re: DataSourceSecurityFilter ClassNotFoundException [message #932659 is a reply to message #915505] Thu, 04 October 2012 05:58 Go to previous message
Hi, it finally works on my development environment with security enabled.
Thanks for the help because your tip : Where is this class?
Did not gave any results.
So what exactly the problem was I don't know but what I did was:
Changed eclipse settings to make eclipse work on 1.7.0_06 (was 1.6 version)
Followed the tutorial "Providing JDBC Connector in a Fragment Bundle"
And now I could see the class with (CTR-Shift-T). But it still not worked (class not found exception at runtime).
So I tried to use the Driver directly in my code which did not work. The compiler gave a quick fix to export the class form the fragment. After that it worked.
Regards Bertin
Previous Topic:Problem with Scout Tutorials
Next Topic:Wizard test
Current Time: Mon Jul 21 08:21:10 EDT 2025
Powered by FUDForum. Page generated in 0.24881 seconds
