| eclipse debugger throws URLClassLoader Error [message #913063] |
Fri, 14 September 2012 13:34  |
I clicked run -> debug configurations and added main class and project and vm arguments.
The main class is in a jar file and same has been in class path and reference libraries.
and clicked on debug button on that window. It throws me the following error.
I am using eclipse indigo version. The picture of the error has been attached.
I removed all break points from eclipse. How do I make sure no break points are in eclipse. i went to break point view and removed all of them , now its empty.
ArchiveExtractorProcessor [Java Application]
com.telus.framework.batch.JobController at localhost:2976
Thread [main] (Suspended (exception ClassNotFoundException))
URLClassLoader$1.run() line: 202
AccessController.doPrivileged(PrivilegedExceptionAction<T>, AccessControlContext) line: not available [native method]
Launcher$AppClassLoader(URLClassLoader).findClass(String) line: 190
Launcher$AppClassLoader(ClassLoader).loadClass(String, boolean) line: 307
Launcher$AppClassLoader.loadClass(String, boolean) line: 301
Launcher$AppClassLoader(ClassLoader).loadClass(String) line: 248
C:\bea10\jdk160_18\bin\javaw.exe (2012-09-14 10:21:31 AM)
| Re: eclipse debugger throws URLClassLoader Error [message #916138 is a reply to message #916124] |
Tue, 18 September 2012 11:47  |
Feritz,
I see the screen capture, but I don't have the message you spell out in
text. Looking back at the history, an earlier one did. Here you have
AccessControlException selected. I tried that dialog and it shows all
classes, though the filter starts out as *Exception*. If you pick
something that doesn't extend Throwable (as in your previous example),
it will give the message that the selection isn't an exception. That
makes sense. You can only set exception breakpoints for things that can
be thrown. I'm not sure why you're still asking about this dialog. Are
you trying to set an exception breakpoint? Are you trying to get rid of
all of them so you don't have any?
On your other points, yes, apparently you have more than one jar with
the same classes in it. That's probably not a good thing, but one of
them will be ahead of the other in the classpath and that's likely the
one that will be used at runtime. It could be a source of problems if
they're not binary compatible.
This thread is quite long. It seems to be focused on debugger problems
but previous comments lead me to believe your application doesn't run at
all, regardless of the debugger. If that's the case, you ought to focus
on getting it to run, which is primarily an issue of setting up a
correct classpath.
On 18/09/2012 5:20 PM, feritz davies wrote:
> if you see screenshot attached, it says Quote:
>> "AND SELECTED ITEM IS NOT AN EXCEPTION"
> @ j! view for java security. You will see two jdks in the J! View panel.
> are you able to see the screenshot attached ? if you are not able to , i have to find some other way to explain?
FUDForum. Page generated in 0.25783 seconds
