Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Compare] Updated XSLT
[EMF Compare] Updated XSLT [message #91414] Mon, 23 July 2007 11:19 Go to next message
Originally posted by: user.domain.invalid
--------------040608010400030607010508
Gets the details for Associations e.g. target/source, association name etc.
Works for both navigable & non-navigable (ownedEnd) Associations
Adam
Content-Type: text/xml;
name="EMF-DIFF2HTML.xslt"
Content-Disposition: inline;
filename="EMF-DIFF2HTML.xslt"
<xsl:stylesheet version="1.0"
xmlns:xsl="http://www.w3.org/1999/XSL/Transform"
xmlns:xmi="http://schema.omg.org/spec/XMI/2.1"
xmlns:diff="http://www.eclipse.org/emf/compare/diff/1.0"
xmlns:match="http://www.eclipse.org/emf/compare/match/1.0"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
xmlns:notation="http://www.ibm.com/xtools/1.5.0/Notation"
xmlns:uml="http://www.eclipse.org/uml2/2.1.0/UML"
xmlns:umlnotation="http://www.ibm.com/xtools/1.5.0/Umlnotation">
<xsl:output method="html" version="1.0" encoding="utf-8"
indent="yes" />
<xsl:template match="/">
<xsl:apply-templates />
</xsl:template>
<xsl:template match="diff:ModelInputSnapshot">
<xsl:variable name="date">
<xsl:value-of select="@date" />
</xsl:variable>
<xsl:variable name="SME" select="//subMatchElements[1]" />
<xsl:variable name="LHE" select="$SME/leftElement/@href" />
<xsl:variable name="LHR" select="$SME/rightElement/@href" />
<xsl:variable name="LHD">
<xsl:call-template name="getFN">
<xsl:with-param name="f_string" select="$LHE" />
</xsl:call-template>
</xsl:variable>
<xsl:variable name="RHD">
<xsl:with-param name="f_string" select="$LHR" />
</xsl:variable>
<!-- <xsl:message>
p_file = <xsl:value-of select="$p_file"/>
docFn = <xsl:value-of select="$docFn"/>
xmi_id = <xsl:value-of select="$xmi_id"/>
</xsl:message> -->
<!-- <xsl:message>
date =
<xsl:value-of select="$date" />
</xsl:message> -->
<xsl:call-template name="processDiff">
<xsl:with-param name="p_node" select="diff/ownedElements" />
<xsl:with-param name="date" select="$date" />
<xsl:with-param name="LHD" select="$LHD" />
<xsl:with-param name="RHD" select="$RHD" />
</xsl:template>
<xsl:template name="processDiff">
<xsl:param name="p_node" />
<xsl:param name="date" />
<xsl:param name="LHD">LHD</xsl:param>
<xsl:param name="RHD">RHD</xsl:param>
<xsl:variable name="Model_Name">
<xsl:call-template name="getname">
<xsl:with-param name="p_file"
select="$p_node/subDiffElements[1]/leftParent/@href" />
</xsl:variable>
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta content="text/html; charset=UTF-8"
http-equiv="content-type" />
<title>View of EMF-DIFF</title>
<style type="text/css">
<xsl:comment><![CDATA[
..docTitle{font-size:18.0pt;font-family:Arial;color:darkblue ;font-weight: bold;text-align:center;}
..docSubTitle{font-size:14.0pt;font-family:Arial;color:darkb lue;font-weight: bold;text-align:center;}
..docSubSubTitle{font-size:12.0pt;color:darkblue;font-weight : bold;text-align:left;}
..docBoldBlue{color:darkblue;font-weight: bold;text-align:left;}
..docBlue{color:darkblue;text-align:left;}
..divCenter{text-align:center;}
h1 {
font-size: 24px;
line-height: normal;
font-weight: bold;
background-color: #f0f0f0;
color: #003366;
border-bottom: 1px solid #3c78b5;
padding: 2px;
margin: 36px 0px 4px 0px;
td.tableheader{
text-align: left;color:darkblue;
font-weight: normal;
background:#f0f0f0;
padding:0cm 5.4pt 0cm 5.4pt;
font-size:12.0pt;
td.W10{width: 10%;text-align:left;font-size:12.0pt;}
td.W20{width: 20%;text-align:left;font-size:12.0pt;}
td.W80{width: 80%;text-align:left;font-size:12.0pt;}
..filler_td{background-color:lightyellow}
body{font-family:Arial;font-size:12.0pt;}
..StdDiv{font-size:12.0pt;}
..Model{color:darkblue;font-weight: bold}
</xsl:comment>
</style>
</head>
<body>
<div class="divCenter">
<span class="docTitle">XMI Model Comparison</span>
</div>
<h1>
<span class="docSubTitle">Model Information</span>
</h1>
<table style="text-align: left; width: 100%;" border="0"
cellpadding="2" cellspacing="2">
<tbody>
<tr>
<td class="docBoldBlue">Model :</td>
<td class="Model">
<xsl:value-of select="$Model_Name" />
select="$p_node/leftParent/@href" />
</xsl:call-template>-->
</td>
</tr>
<tr>
<td class="docBoldBlue">Compared on :</td>
<td>
</td>
</tr>
<tr>
<xsl:value-of
select="'Left hand Document :'" />
</td>
<td>
<xsl:value-of select="$LHD" />
</td>
</tr>
<tr>
<xsl:value-of
select="'Right hand Document :'" />
</td>
<td>
<xsl:value-of select="$RHD" />
</td>
</tr>
</tbody>
</table>
<h1>
<span class="docSubTitle">Comparison</span>
</h1>
<tbody>
<tr>
<th>
</th>
<!-- <th>Sub Model Element</th>-->
</tr>
<xsl:for-each
select="$p_node/subDiffElements[@xsi:type != 'diff:DiffGroup']">
<xsl:message>
xsi:type 1 =
<xsl:value-of select="@xsi:type" />
</xsl:message>
<tr>
<xsl:call-template name="subdiff">
select="." />
<xsl:with-param name="counter"
select="'0'" />
</tr>
</xsl:for-each>
<xsl:for-each
select="$p_node/subDiffElements[@xsi:type = 'diff:DiffGroup']">
<!-- <xsl:message>
xsi:type 2 = <xsl:value-of select="@xsi:type" />
</xsl:message> -->
select="." />
select="'1'" />
</xsl:for-each>
<!-- <xsl:for-each select="//subDiffElements[@xsi:type='diff:RemoveModelElement'] ">
<tr>
<td ><xsl:value-of select="rightParent/@href"/></td>
<td ><xsl:value-of select="leftElement/@href"/></td>
</tr>
</xsl:for-each> -->
</tbody>
</table>
</body>
</html>
</xsl:template>
<xsl:template name="subdiff">
<xsl:param name="counter">0</xsl:param>
<!-- <xsl:message>
type =<xsl:value-of select="$p_node/@xsi:type" />
</xsl:message> -->
<xsl:variable name="diffType">
</xsl:variable>
<xsl:variable name="v_count">
<xsl:value-of select="$counter +1" />
</xsl:variable>
<xsl:choose>
<!-- DiffGroup -->
<xsl:when test="$diffType ='diff:DiffGroup'">
<!-- <xsl:message>
V_count = <xsl:value-of select="$v_count" />
count = <xsl:value-of select="$counter" />
</xsl:message> -->
<tr>
<xsl:if test="$counter > 0">
<xsl:call-template name="print-td">
<xsl:with-param name="count"
</xsl:if>
<td class="DiffGroup">
<xsl:call-template name="changeCounter">
select="$p_node" />
<xsl:value-of select="' changes in : '" />
</td>
</tr>
<xsl:for-each select="$p_node/subDiffElements">
<xsl:with-param name="p_node" select="." />
</xsl:for-each>
</xsl:when>
<!-- Model Element Changes -->
<xsl:when test="$diffType ='diff:RemoveModelElement'">
<tr>
</xsl:if>
<td class="RemoveModelElement">
<xsl:text> Model Element </xsl:text>
select="$p_node/leftElement/@href" />
<xsl:text> has been removed </xsl:text>
</td>
</tr>
</xsl:when>
<xsl:when test="$diffType ='diff:AddModelElement'">
<tr>
</xsl:if>
<td class="AddModelElement">
select="$p_node/rightElement/@href" />
<xsl:text> has been added </xsl:text>
</td>
</tr>
</xsl:when>
<xsl:when test="$diffType ='diff:MoveModelElement'">
<tr>
</xsl:if>
<td class="MoveModelElement">
<xsl:text> has been moved </xsl:text>
</td>
</tr>
</xsl:when>
<xsl:when test="$diffType ='diff:UpdateModelElement'">
<tr>
</xsl:if>
<td class="UpdateModelElement">
<xsl:text> Model Element has been changed from </xsl:text>
<xsl:text> to </xsl:text>
</td>
</tr>
</xsl:when>
<!-- Attribute Changes -->
<xsl:when test="$diffType ='diff:AddAttribute'">
<tr>
</xsl:if>
<td class="AddAttribute">
<xsl:text> Attribute </xsl:text>
</td>
</tr>
</xsl:when>
<xsl:when test="$diffType ='diff:RemoveAttribute'">
<tr>
</xsl:if>
<td class="RemoveAttribute">
</td>
</tr>
</xsl:when>
<xsl:when test="$diffType ='diff:UpdateAttribute'">
<tr>
</xsl:if>
<td class="UpdateAttribute">
<xsl:text> Attribute has been changed from </xsl:text>
</td>
</tr>
</xsl:when>
<!-- Reference Changes -->
<xsl:when test="$diffType ='diff:AddReferenceValue'">
<tr>
</xsl:if>
<td class="AddReferenceValue">
<xsl:text> Reference </xsl:text>
select="$p_node/rightAddedTarget/@href" />
</td>
</tr>
</xsl:when>
<xsl:when test="$diffType ='diff:RemoveReferenceValue'">
<tr>
</xsl:if>
<td class="RemoveReferenceValue">
select="$p_node/leftRemovedTarget/@href" />
</td>
</tr>
</xsl:when>
<xsl:when test="$diffType ='diff:UpdateReference'">
<tr>
</xsl:if>
<td class="UpdateReference">
<xsl:text> Reference has been changed from </xsl:text>
</td>
</tr>
</xsl:when>
<xsl:when
test="$diffType ='diff:UpdateUniqueReferenceValue'">
<tr>
</xsl:if>
<td class="UpdateUniqueReferenceValue">
<xsl:text> Reference has been changed from an </xsl:text>
<xsl:call-template name="getUpdatedRef">
<xsl:text> to an </xsl:text>
</td>
</tr>
</xsl:when>
</xsl:choose>
<tr>
</tr>
</xsl:for-each> -->
</xsl:template>
<xsl:template name="getUpdatedRef">
<xsl:param name="p_file"></xsl:param>
<xsl:variable name="docFn">
<xsl:value-of select="substring-before($p_file,'#')" />
</xsl:variable>
<xsl:variable name="xmi_id">
<xsl:value-of select="substring-after($p_file,'#')" />
</xsl:variable>
<!-- <xsl:message>
</xsl:message> -->
<xsl:variable name="doc" select="document($docFn)" />
<xsl:variable name="id_El" select="$doc//*[@xmi:id=$xmi_id][1]" />
<xsl:if test="$id_El">
<!-- <xsl:element name="span">
<xsl:attribute name="class">
<xsl:choose>
<xsl:when test="$id_El/@xmi:type">
<xsl:value-of select="$id_El/@xmi:type" />
</xsl:when>
<xsl:otherwise>
<xsl:value-of select="name($id_El)" />
</xsl:otherwise>
</xsl:choose>
</xsl:attribute>
</xsl:element> -->
<xsl:choose>
<xsl:when test="$id_El/@type">
<!-- Internal -->
<xsl:variable name="intType" select="$id_El/@type" />
<xsl:variable name="id_El1"
select="$doc//*[@xmi:id=$intType][1]" />
<!-- <xsl:value-of select="concat('Internal Reference : ',$id_El1/@xmi:type,' ', $id_El1/@name)" /> -->
select="'InternalReference'" />
<xsl:value-of select="'Internal Reference :'" />
</xsl:element>
select="$id_El1/@xmi:type" />
<xsl:value-of
select="concat(' ',$id_El1/@xmi:type)" />
</xsl:element>
<xsl:attribute name="class" select="'name'" />
<xsl:value-of
select="concat(' ',$id_El1/@name)" />
</xsl:element>
</xsl:when>
<xsl:otherwise>
<xsl:choose>
<xsl:when test="$id_El/type">
<!-- External -->
<xsl:variable name="extType"
select="$id_El/type" />
<!-- <xsl:value-of select="concat('External Reference : ',$extType/@xmi:type,' ', $extType/@href)" /> -->
select="'ExternalReference'" />
<xsl:value-of
select="'External Reference :'" />
</xsl:element>
select="$extType/@xmi:type" />
<xsl:value-of
select="concat(' ',$extType/@xmi:type)" />
</xsl:element>
select="'href'" />
<xsl:value-of
select="concat(' ',$extType/@href)" />
</xsl:element>
</xsl:when>
<xsl:otherwise>
<!-- <xsl:value-of select="$id_El/@name" /> -->
</xsl:otherwise>
</xsl:choose>
</xsl:otherwise>
</xsl:choose>
</xsl:if>
</xsl:template>
<xsl:template name="getname">
</xsl:variable>
</xsl:variable>
<!-- <xsl:message>
</xsl:message> -->
<xsl:choose>
<xsl:when test="contains($docFn,'pathmap')">
<xsl:message>
Pathmap found docFn how to handle? = <xsl:value-of select="$docFn"/>
</xsl:message>
</xsl:when>
<xsl:otherwise>
<!-- <xsl:message>
PackagedElement type = <xsl:value-of select="$id_El/@xmi:type" />
</xsl:message> -->
<xsl:choose>
</xsl:when>
<xsl:otherwise>
</xsl:otherwise>
</xsl:choose>
</xsl:attribute>
<xsl:choose>
<xsl:when test="name($id_El) = 'ownedComment'">
<xsl:value-of
select="concat('Comment : ',$id_El/body)" />
</xsl:when>
<xsl:when test="name($id_El) = 'packagedElement'">
<xsl:choose>
<xsl:when test="$id_El/@name">
</xsl:when>
<xsl:when
test="$id_El/@xmi:type = 'uml:Association'">
<xsl:value-of
select="'uml:Association '"/>
<xsl:call-template
name="getAssociation">
select="$id_El" />
<xsl:with-param name="doc"
select="$doc" />
</xsl:when>
<xsl:otherwise>
<!-- <xsl:value-of select="$id_El/@xmi:type" /> -->
<xsl:value-of
select="concat($id_El/@xmi:type,' id = ',$xmi_id)" />
<!-- <xsl:value-of select="concat('PE ',$xmi_id)" /> -->
</xsl:otherwise>
</xsl:choose>
</xsl:when>
<xsl:otherwise>
<xsl:choose>
<!-- <xsl:message>
name = <xsl:value-of select="$id_El/@name" />
</xsl:message>-->
</xsl:when>
<xsl:otherwise>
<!-- <xsl:message>
name of element =<xsl:value-of select="name($id_El)" />
</xsl:message>-->
</xsl:otherwise>
</xsl:choose>
</xsl:otherwise>
</xsl:choose>
</xsl:element>
</xsl:if>
</xsl:otherwise>
</xsl:choose>
</xsl:template>
<xsl:template name="getAssociation">
<xsl:param name="doc" />
<xsl:variable name="member1">
<xsl:value-of
select="substring-before($p_node/@memberEnd,' ')" />
</xsl:variable>
<xsl:variable name="member2">
<xsl:value-of
select="substring-after($p_node/@memberEnd,' ')" />
</xsl:variable>
<!-- <xsl:message>
memberEnd =
<xsl:value-of select="$p_node/@memberEnd" />
member1 =
<xsl:value-of select="$member1" />
member2 =
<xsl:value-of select="$member2" />
</xsl:message> -->
<!-- <xsl:variable name="OA_1" select="$doc//ownedAttribute[@xmi:id=$member1][1]"/>
<xsl:variable name="OA_2" select="$doc//*[@xmi:id=$member2][1]"/>
<xsl:message>
OA_1 name = <xsl:value-of select="$OA_1/@name" />
OA_2 name = <xsl:value-of select="$OA_2/@name" />
</xsl:message> -->
<xsl:choose>
<xsl:when test="$p_node/ownedEnd">
<!-- <xsl:message>OwnedAssoc</xsl:message> -->
<xsl:call-template name="getOwnedAssociation">
<xsl:with-param name="p_node" select="$p_node" />
<xsl:with-param name="doc" select="$doc" />
<xsl:with-param name="member1" select="$member1" />
<xsl:with-param name="member2" select="$member2" />
</xsl:when>
<xsl:otherwise>
<!-- <xsl:message>Navigable Assoc</xsl:message> -->
<xsl:call-template name="getNavigableAssociation">
<!-- <xsl:with-param name="p_node" select="$p_node" /> -->
</xsl:otherwise>
</xsl:choose>
</xsl:template>
<xsl:template name="getNavigableAssociation">
<xsl:param name="member1" />
<xsl:param name="member2" />
<!-- <ownedAttribute xmi:id="_KeCiVjj2Edy0_uRL9hZ33w" name="testclass2" -->
select="$doc//ownedAttribute[@xmi:id=$member1][1]" />
select="$doc//ownedAttribute[@xmi:id=$member2][1]" />
<!-- <xsl:message>
Navigable Association OA_1 name =
Navigable Association OA_2 name =
</xsl:message> -->
<xsl:value-of select="'Navigable Association'"/>
<xsl:element name="br"/>
<xsl:value-of select="concat(' Source : ',$OA_1/@name)"/>
<xsl:value-of select="concat(' Target : ',$OA_2/@name)" />
<!-- <xsl:value-of
select="concat('Navigable Association joining ',$OA_1/@name, ' with ',$OA_2/@name)" /> -->
</xsl:template>
<xsl:template name="getOwnedAssociation">
<xsl:variable name="OE" select="$p_node/ownedEnd" />
<xsl:variable name="OE_name" select="$OE/@name" />
<xsl:variable name="OE_type" select="$OE/@type" />
<xsl:variable name="OA_1_name" select="$OA_1/@name" />
<xsl:variable name="OA_1_type" select="$OA_1/@type" />
<xsl:variable name="OA_1_Target" select="$doc//packagedElement[@xmi:id=$OA_1_type][1]" />
<!-- <xsl:message> name of pnode = <xsl:value-of select="name($p_node)" />
type of pnode = <xsl:value-of select="$p_node/@xmi:type"/>
</xsl:message> -->
<!-- <xsl:message>
OA_1 = <xsl:value-of select="name($OA_1)"/>
OA_1_type = <xsl:value-of select="$OA_1_type" />
OA_1_Target = <xsl:value-of select="name($OA_1_Target)"/>
</xsl:message> -->
<!-- <xsl:message> name of OE = <xsl:value-of select="name($OE)" />
nameAtt of OE = <xsl:value-of select="$p_node/ownedEnd/@name" />
id of OE = <xsl:value-of select="$p_node/ownedEnd/@xmi:id" />
</xsl:message> -->
<!-- <xsl:message> OE_Type = <xsl:value-of select="$OE_type" />
</xsl:message>
<xsl:message>
</xsl:message> -->
<xsl:variable name="OA_1_Parent" select="../$OA_1" />
<xsl:variable name="OA_1_Parent_name" select="../$OA_1/@name" />
<xsl:variable name="OA_1_LinkedByType"
select="$doc//packagedElement[@xmi:id=$OE_type][1]" />
<xsl:variable name="OA_1_LinkedByType_name"
select="$OA_1_LinkedByType/@name" />
<!-- <xsl:message>
Owned Association OE_name name =
<xsl:value-of select="$OE_name" />
Owned Association OA_1_Parent_name name =
<xsl:value-of select="$OA_1_Parent_name" />
Owned Association OA_1_LinkedByType_name name =
<xsl:value-of select="$OA_1_LinkedByType_name" />
</xsl:message> -->
<xsl:if test="$OA_1_Parent_name">
<xsl:value-of select="concat(' Role : ',$OA_1_Parent_name)" />
</xsl:if>
<xsl:choose>
<xsl:when test="$OA_1_Target">
<xsl:value-of select="concat(' Source : ',$OA_1_LinkedByType_name)"/>
<xsl:value-of select="concat(' Target : ',$OA_1_Target/@name)" />
</xsl:when>
<xsl:otherwise>
<xsl:if test="$OA_1_LinkedByType_name">
</xsl:if>
</xsl:otherwise>
</xsl:choose>
</xsl:template>
<xsl:template name="print-td">
<xsl:param name="count" />
<xsl:if test="$count"><!-- print the td for this iteration -->
<td class="filler_td"><!-- <xsl:value-of select="$count" /> -->
</td>
<xsl:with-param name="count" select="$count -1" />
</xsl:if>
</xsl:template>
<xsl:template name="getFN">
<xsl:param name="f_string" />
<xsl:value-of select="substring-before($f_string,'#')" />
</xsl:variable>
<xsl:variable name="docFn1">
<xsl:value-of select="substring-after($docFn,'file:/')" />
</xsl:variable>
<xsl:value-of select="$docFn1" />
</xsl:template>
<xsl:template name="changeCounter">
<xsl:value-of
select=" count($p_node//descendant::subDiffElements[not(@xsi:type='di ff:DiffGroup')]) " />
</xsl:template>
</xsl:stylesheet>
--------------040608010400030607010508--
Re: [EMF Compare] Updated XSLT [message #91506 is a reply to message #91414] Tue, 24 July 2007 05:13 Go to previous messageGo to next message
--------------070400020204000703060409
> Adam
Updated once more to get more information out of the relevant model
elements (e.g. what xmi:type they are etc).
BTW given I have created a bug report on the eclipse bugzilla for the
XSLT sheet, would it be better if I attach the updated files to that?
Adam
indent="yes" />
</xsl:template>
</xsl:variable>
</xsl:variable>
</xsl:variable>
<!-- <xsl:message>
</xsl:message> -->
<!-- <xsl:message>
date =
</xsl:message> -->
</xsl:template>
</xsl:variable>
<head>
h1 {
font-size: 24px;
font-weight: bold;
color: #003366;
padding: 2px;
td.tableheader{
background:#f0f0f0;
font-size:12.0pt;
</xsl:comment>
</style>
</head>
<body>
</div>
<h1>
</h1>
<tbody>
<tr>
<td class="Model">
</td>
</tr>
<tr>
<td>
</td>
</tr>
<tr>
<xsl:value-of
</td>
<td>
</td>
</tr>
<tr>
<xsl:value-of
</td>
<td>
</td>
</tr>
</tbody>
</table>
<h1>
</h1>
<tbody>
<tr>
<th>
</th>
</tr>
<xsl:for-each
<xsl:message>
xsi:type 1 =
</xsl:message>
<tr>
select="." />
select="'0'" />
</tr>
</xsl:for-each>
<xsl:for-each
<!-- <xsl:message>
</xsl:message> -->
select="." />
select="'1'" />
</xsl:for-each>
<tr>
</tr>
</xsl:for-each> -->
</tbody>
</table>
</body>
</html>
</xsl:template>
<!-- <xsl:message>
</xsl:message> -->
</xsl:variable>
</xsl:variable>
<xsl:choose>
<!-- DiffGroup -->
<!-- <xsl:message>
</xsl:message> -->
<tr>
</xsl:if>
select="$p_node" />
</td>
</tr>
</xsl:for-each>
</xsl:when>
<tr>
</xsl:if>
</td>
</tr>
</xsl:when>
<tr>
</xsl:if>
</td>
</tr>
</xsl:when>
<tr>
</xsl:if>
</td>
</tr>
</xsl:when>
<tr>
</xsl:if>
</td>
</tr>
</xsl:when>
<tr>
</xsl:if>
</td>
</tr>
</xsl:when>
<tr>
</xsl:if>
</td>
</tr>
</xsl:when>
<tr>
</xsl:if>
</td>
</tr>
</xsl:when>
<tr>
</xsl:if>
</td>
</tr>
</xsl:when>
<tr>
</xsl:if>
</td>
</tr>
</xsl:when>
<tr>
</xsl:if>
</td>
</tr>
</xsl:when>
<xsl:when
<tr>
</xsl:if>
</td>
</tr>
</xsl:when>
</xsl:choose>
<tr>
</tr>
</xsl:for-each> -->
</xsl:template>
</xsl:variable>
</xsl:variable>
<!-- <xsl:message>
</xsl:message> -->
<xsl:choose>
</xsl:when>
<xsl:otherwise>
</xsl:otherwise>
</xsl:choose>
</xsl:attribute>
</xsl:element> -->
<xsl:choose>
<!-- Internal -->
</xsl:element>
<xsl:value-of
</xsl:element>
<xsl:value-of
</xsl:element>
</xsl:when>
<xsl:otherwise>
<xsl:choose>
<!-- External -->
<xsl:value-of
</xsl:element>
<xsl:value-of
</xsl:element>
select="'href'" />
<xsl:value-of
</xsl:element>
</xsl:when>
<xsl:otherwise>
</xsl:otherwise>
</xsl:choose>
</xsl:otherwise>
</xsl:choose>
</xsl:if>
</xsl:template>
</xsl:variable>
</xsl:variable>
<!-- <xsl:message>
</xsl:message> -->
<xsl:choose>
<xsl:message>
<xsl:value-of select="$docFn" />
</xsl:message>
</xsl:when>
<xsl:otherwise>
<!-- <xsl:message>
</xsl:message> -->
<xsl:choose>
</xsl:when>
<xsl:otherwise>
</xsl:otherwise>
</xsl:choose>
</xsl:attribute>
<xsl:choose>
<xsl:when
<xsl:value-of
</xsl:when>
<xsl:when
<!-- <xsl:message>
name = <xsl:value-of select="name($id_El)" />
nameatt = <xsl:value-of select="$id_El/@name" />
</xsl:message> -->
<xsl:choose>
<xsl:if
<xsl:value-of
select="concat($id_El/@xmi:type,' ')" />
</xsl:if>
<xsl:if
test="$id_El/type">
<xsl:message>
type = <xsl:value-of select="$id_El/type" />
</xsl:message>
</xsl:if>
<xsl:value-of
</xsl:when>
<xsl:when
<xsl:value-of
select="'uml:Association '" />
<xsl:call-template
<xsl:with-param
name="p_node" select="$id_El" />
select="$doc" />
</xsl:when>
<xsl:otherwise>
<xsl:value-of
</xsl:otherwise>
</xsl:choose>
</xsl:when>
<xsl:otherwise>
<xsl:choose>
<xsl:choose>
<xsl:variable name="id_El_type"
select="$doc//*[@xmi:id=$id_El/@type][1]" />
<xsl:value-of
select="concat($id_El/@name,' (',$id_El_type/@xmi:type,$id_El_type/@name,') ')" />
</xsl:when>
<xsl:otherwise>
<xsl:if test="name($id_El) = 'ownedAttribute'">
<xsl:value-of select="'Attribute '" />
</xsl:if>
<xsl:value-of
</xsl:otherwise>
</xsl:choose>
<!-- <xsl:message>
</xsl:message>-->
</xsl:when>
<xsl:otherwise>
<!-- <xsl:message>
</xsl:message>-->
<xsl:value-of
</xsl:otherwise>
</xsl:choose>
</xsl:otherwise>
</xsl:choose>
</xsl:element>
</xsl:if>
</xsl:otherwise>
</xsl:choose>
</xsl:template>
<xsl:value-of
</xsl:variable>
<xsl:value-of
</xsl:variable>
<!-- <xsl:message>
memberEnd =
member1 =
member2 =
</xsl:message> -->
<xsl:message>
</xsl:message> -->
<xsl:choose>
</xsl:when>
<xsl:otherwise>
</xsl:otherwise>
</xsl:choose>
</xsl:template>
<!-- <xsl:message>
</xsl:message> -->
<xsl:value-of select="'Navigable Association'" />
<xsl:element name="br" />
<xsl:value-of select="concat(' Source : ',$OA_1/@name)" />
<!-- <xsl:value-of
</xsl:template>
</xsl:message> -->
<!-- <xsl:message>
</xsl:message> -->
</xsl:message> -->
</xsl:message>
<xsl:message>
</xsl:message> -->
<!-- <xsl:message>
</xsl:message> -->
</xsl:if>
<xsl:choose>
<xsl:value-of
select="concat(' Source : ',$OA_1_LinkedByType_name)" />
<xsl:value-of
</xsl:when>
<xsl:otherwise>
<xsl:value-of
</xsl:if>
</xsl:otherwise>
</xsl:choose>
</xsl:template>
</td>
</xsl:if>
</xsl:template>
</xsl:variable>
</xsl:variable>
</xsl:template>
<xsl:value-of
</xsl:template>
</xsl:stylesheet>
--------------070400020204000703060409--
Re: [EMF Compare] Updated XSLT [message #91538 is a reply to message #91506] Tue, 24 July 2007 05:19 Go to previous message
--------------090600070705050800020900
Adam,
Thanks for the update and yes, it would be easier to find the updated
versions of your XSLT on the bugzilla since you did attach the first
version with this bug report.
Laurent Goubet
Obeo
AdamF a
Re: [EMF Compare] Updated XSLT [message #608860 is a reply to message #91414] Tue, 24 July 2007 05:13 Go to previous message
> Adam
Adam
indent="yes" />
</xsl:template>
</xsl:variable>
</xsl:variable>
</xsl:variable>
<!-- <xsl:message>
</xsl:message> -->
<!-- <xsl:message>
date =
</xsl:message> -->
</xsl:template>
</xsl:variable>
<head>
h1 {
font-size: 24px;
font-weight: bold;
color: #003366;
padding: 2px;
td.tableheader{
background:#f0f0f0;
font-size:12.0pt;
</xsl:comment>
</style>
</head>
<body>
</div>
<h1>
</h1>
<tbody>
<tr>
<td class="Model">
</td>
</tr>
<tr>
<td>
</td>
</tr>
<tr>
<xsl:value-of
</td>
<td>
</td>
</tr>
<tr>
<xsl:value-of
</td>
<td>
</td>
</tr>
</tbody>
</table>
<h1>
</h1>
<tbody>
<tr>
<th>
</th>
</tr>
<xsl:for-each
<xsl:message>
xsi:type 1 =
</xsl:message>
<tr>
select="." />
select="'0'" />
</tr>
</xsl:for-each>
<xsl:for-each
<!-- <xsl:message>
</xsl:message> -->
select="." />
select="'1'" />
</xsl:for-each>
<tr>
</tr>
</xsl:for-each> -->
</tbody>
</table>
</body>
</html>
</xsl:template>
<!-- <xsl:message>
</xsl:message> -->
</xsl:variable>
</xsl:variable>
<xsl:choose>
<!-- DiffGroup -->
<!-- <xsl:message>
</xsl:message> -->
<tr>
</xsl:if>
select="$p_node" />
</td>
</tr>
</xsl:for-each>
</xsl:when>
<tr>
</xsl:if>
</td>
</tr>
</xsl:when>
<tr>
</xsl:if>
</td>
</tr>
</xsl:when>
<tr>
</xsl:if>
</td>
</tr>
</xsl:when>
<tr>
</xsl:if>
</td>
</tr>
</xsl:when>
<tr>
</xsl:if>
</td>
</tr>
</xsl:when>
<tr>
</xsl:if>
</td>
</tr>
</xsl:when>
<tr>
</xsl:if>
</td>
</tr>
</xsl:when>
<tr>
</xsl:if>
</td>
</tr>
</xsl:when>
<tr>
</xsl:if>
</td>
</tr>
</xsl:when>
<tr>
</xsl:if>
</td>
</tr>
</xsl:when>
<xsl:when
<tr>
</xsl:if>
</td>
</tr>
</xsl:when>
</xsl:choose>
<tr>
</tr>
</xsl:for-each> -->
</xsl:template>
</xsl:variable>
</xsl:variable>
<!-- <xsl:message>
</xsl:message> -->
<xsl:choose>
</xsl:when>
<xsl:otherwise>
</xsl:otherwise>
</xsl:choose>
</xsl:attribute>
</xsl:element> -->
<xsl:choose>
<!-- Internal -->
</xsl:element>
<xsl:value-of
</xsl:element>
<xsl:value-of
</xsl:element>
</xsl:when>
<xsl:otherwise>
<xsl:choose>
<!-- External -->
<xsl:value-of
</xsl:element>
<xsl:value-of
</xsl:element>
select="'href'" />
<xsl:value-of
</xsl:element>
</xsl:when>
<xsl:otherwise>
</xsl:otherwise>
</xsl:choose>
</xsl:otherwise>
</xsl:choose>
</xsl:if>
</xsl:template>
</xsl:variable>
</xsl:variable>
<!-- <xsl:message>
</xsl:message> -->
<xsl:choose>
<xsl:message>
</xsl:message>
</xsl:when>
<xsl:otherwise>
<!-- <xsl:message>
</xsl:message> -->
<xsl:choose>
</xsl:when>
<xsl:otherwise>
</xsl:otherwise>
</xsl:choose>
</xsl:attribute>
<xsl:choose>
<xsl:when
<xsl:value-of
</xsl:when>
<xsl:when
<!-- <xsl:message>
</xsl:message> -->
<xsl:choose>
<xsl:if
<xsl:value-of
</xsl:if>
<xsl:if
test="$id_El/type">
<xsl:message>
</xsl:message>
</xsl:if>
<xsl:value-of
</xsl:when>
<xsl:when
<xsl:value-of
<xsl:call-template
<xsl:with-param
select="$doc" />
</xsl:when>
<xsl:otherwise>
<xsl:value-of
</xsl:otherwise>
</xsl:choose>
</xsl:when>
<xsl:otherwise>
<xsl:choose>
<xsl:choose>
<xsl:value-of
</xsl:when>
<xsl:otherwise>
</xsl:if>
<xsl:value-of
</xsl:otherwise>
</xsl:choose>
<!-- <xsl:message>
</xsl:message>-->
</xsl:when>
<xsl:otherwise>
<!-- <xsl:message>
</xsl:message>-->
<xsl:value-of
</xsl:otherwise>
</xsl:choose>
</xsl:otherwise>
</xsl:choose>
</xsl:element>
</xsl:if>
</xsl:otherwise>
</xsl:choose>
</xsl:template>
<xsl:value-of
</xsl:variable>
<xsl:value-of
</xsl:variable>
<!-- <xsl:message>
memberEnd =
member1 =
member2 =
</xsl:message> -->
<xsl:message>
</xsl:message> -->
<xsl:choose>
</xsl:when>
<xsl:otherwise>
</xsl:otherwise>
</xsl:choose>
</xsl:template>
<!-- <xsl:message>
</xsl:message> -->
<!-- <xsl:value-of
</xsl:template>
</xsl:message> -->
<!-- <xsl:message>
</xsl:message> -->
</xsl:message> -->
</xsl:message>
<xsl:message>
</xsl:message> -->
<!-- <xsl:message>
</xsl:message> -->
</xsl:if>
<xsl:choose>
<xsl:value-of
<xsl:value-of
</xsl:when>
<xsl:otherwise>
<xsl:value-of
</xsl:if>
</xsl:otherwise>
</xsl:choose>
</xsl:template>
</td>
</xsl:if>
</xsl:template>
</xsl:variable>
</xsl:variable>
</xsl:template>
<xsl:value-of
</xsl:template>
</xsl:stylesheet>
Re: [EMF Compare] Updated XSLT [message #608862 is a reply to message #91506] Tue, 24 July 2007 05:19 Go to previous message
Adam,
Laurent Goubet
Obeo
AdamF a
Previous Topic:[Compare] Minor buglet
Next Topic:[EMF Compare]ConnectorEnds have changes in "false"
Current Time: Sun Jul 27 07:53:56 EDT 2025
Powered by FUDForum. Page generated in 0.05207 seconds
