[Compare] Minor buglet [message #91347] |
Mon, 23 July 2007 10:23  |
Originally posted by: user.domain.invalid
I have been creating examples in order to demo to ppl here &....
If I have 2 models & they are called different things then the order of
selection makes no difference as the left hand side/right hand side
appears to be determined by alphabetical filename.
Adam
Re: [Compare] Minor buglet [message #91488 is a reply to message #91432] |
Tue, 24 July 2007 05:07  |
Laurent Goubet wrote:
> I think the comparison order isn't determined on filename alone, but on
> the resource's full path (Two files called exactly the same name cannot
> coexist in the same directory). If you would like the behavior to be
> different, I think you'll have to ask this on the platform newsgroup for
> the compare component as we make use of their API and, thus, inherit
> from their behavior.
> Laurent Goubet
> Obeo
Oh & BTW it would appear from this that my original [Compare] was
correct <G>
Adam
Re: [Compare] Minor buglet [message #608852 is a reply to message #91347] |
Mon, 23 July 2007 10:52  |
--------------080503060101030507040201
Adam,
If this is about EMF Compare (never seen the tag [Compare] before but
you're talking about models so I'll assume this is), we do not take the
order of selection into account for model comparison. As does the
file/text/source/... generic comparison, the left and right hand side of
model comparison will be determined alphabetically.
Laurent Goubet
Obeo
AdamF a
Re: [Compare] Minor buglet [message #608853 is a reply to message #91379] |
Mon, 23 July 2007 11:17  |
> Adam,
> Laurent Goubet
> Obeo
>> of selection makes no difference as the left hand side/right hand side
>> Adam
Yes it's [EMF Compare].
I simply assumed that the order of selection was what determined the
left/right etc.
What happens where there are 2 files in different projects etc called
the same thing? File date?
Adam
Re: [Compare] Minor buglet [message #608855 is a reply to message #91394] |
Mon, 23 July 2007 11:27  |
--------------050706010606080306070600
Laurent Goubet
Obeo
AdamF a
Re: [Compare] Minor buglet [message #608858 is a reply to message #91432] |
Tue, 24 July 2007 05:05  |
Oh OK will do.
Adam
> Laurent Goubet
> Obeo
>>> Adam,
>>> the order of selection into account for model comparison. As does the
>>> of model comparison will be determined alphabetically.
>>> Laurent Goubet
>>> Obeo
>>>> side appears to be determined by alphabetical filename.
>>>> Adam
>> left/right etc.
>> Adam
Re: [Compare] Minor buglet [message #608859 is a reply to message #91432] |
> Laurent Goubet
> Obeo
correct <G>
Adam
FUDForum. Page generated in 0.05374 seconds
