Home » Modeling » EMF » Create ItemPropertyDescriptor for editing Map
Create ItemPropertyDescriptor for editing Map [message #912959] Fri, 14 September 2012 09:36 Go to next message
is there any possibility to create an ItemPropertyDescriptor for a map, which values are shown up with a table?
[Updated on: Fri, 21 September 2012 06:52] by Moderator
Re: Create ItemPropertyDescriptor with table [message #912972 is a reply to message #912959] Fri, 14 September 2012 09:57 Go to previous messageGo to next message
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
You mean like this, which someone else just asked about:<br>
<blockquote><a class="moz-txt-link-freetext" href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=220843#c3">https://bugs.eclipse.org/bugs/show_bug.cgi?id=220843#c3</a><br>
</blockquote>
Somehow this "Missing name Mising name" thing is annoying.  Don't
you have a name?<br>
<br>
<div class="moz-cite-prefix">On 14/09/2012 3:36 PM, Missing name
Mising name wrote:<br>
</div>
<blockquote cite="mid:k2vbt6$j9v$1@xxxxxxxxe.org" type="cite">Hello,
<br>
<br>
is there any possibility to create an ItemPropertyDescriptor,
<br>
</blockquote>
<br>
</body>
</html>
Re: Create ItemPropertyDescriptor with table [message #912992 is a reply to message #912972] Fri, 14 September 2012 10:53 Go to previous messageGo to next message
> You mean like this, which someone else just asked about: https://bugs.eclipse.org/bugs/show_bug.cgi?id=220843#c3
I can't find anything, which is related to my question.
I mean I want to select an object in the editor. The object contains for example a list, which shall be shown as a extra table in the property sheet.
Uhm ... I never really noticed it. I will check it soon.
Re: Create ItemPropertyDescriptor with table [message #912998 is a reply to message #912992] Fri, 14 September 2012 11:05 Go to previous messageGo to next message
Sorry, but I won't answer questions coming from "Missing name Mising
name" for at least a week.
> property sheet.
Re: Create ItemPropertyDescriptor with table [message #918741 is a reply to message #912998] Fri, 21 September 2012 05:46 Go to previous messageGo to next message
Re: Create ItemPropertyDescriptor with table [message #918752 is a reply to message #918741] Fri, 21 September 2012 05:59 Go to previous messageGo to next message
I don't know what "an extra table in the property sheet" means.
> property sheet.
Re: Create ItemPropertyDescriptor with table [message #918791 is a reply to message #918752] Fri, 21 September 2012 06:50 Go to previous messageGo to next message
I mean something like a category. You open the category and all keys and values of the map are listed.
I think a specialized ItemPropertyDescriptor could help. If I implement some tree interface, but I am not sure.
Re: Create ItemPropertyDescriptor with table [message #918868 is a reply to message #918791] Fri, 21 September 2012 08:25 Go to previous messageGo to next message
John,
You can have a look at
org.eclipse.emf.codegen.ecore.genmodel.provider.GenBaseItemProvider.GenItemPropertyDescriptor.
It's used to create a wrapper object that in turn can act as a property
source of nested properties. If you look in the Generator's properties
view for Ecore properties, e.g., GenPackage's Ecore Package property,
that's what results in there being a "+" that can be expanded to show
the properties of the decorated Ecore model. With this type of
approach, you can have properties that are expandable to show nested
content.
Re: Create ItemPropertyDescriptor with table [message #921615 is a reply to message #918868] Mon, 24 September 2012 05:24 Go to previous messageGo to next message
Thanks so far. Using the right literal and overwriting the method createPropertyValueWrapper in my own ItemPropertyDescriptor works for the first step:
protected Object createPropertyValueWrapper(Object object, Object propertyValue) {
	if (object instanceof CommandImpl) {
		return new PropertyValueWrapper(adapterFactory, object,
				((CommandImpl) object).getCommandData().getValues(), ((CommandImpl) object).getCommandData()
						.getValues());
	} else {
		return super.createPropertyValueWrapper(object, propertyValue);
Now I want to show them in a table form with direct edit instead of a comma seperated field with extra dialog.
Re: Create ItemPropertyDescriptor with table [message #921627 is a reply to message #921615] Mon, 24 September 2012 05:34 Go to previous messageGo to next message
John,
Comments below.
> the first step:
> @Override
> propertyValue) {
You can't seem to resist using the implementation classes instead of the
API...
> .getValues());
You'll want to specialize this wrapper so that when it's asked for
property descriptors you produce a list for the property items you want
to have appear as children.
> } else {
Re: Create ItemPropertyDescriptor with table [message #922806 is a reply to message #921627] Tue, 25 September 2012 07:00 Go to previous messageGo to next message
I want to use my own IItemPropertySource, but the object is an EcoreEMap and I don't know how to combine that.
Or just simply overwrite getPropertyDescriptors?
Re: Create ItemPropertyDescriptor with table [message #922888 is a reply to message #922806] Tue, 25 September 2012 08:31 Go to previous messageGo to next message
Try it.
Re: Create ItemPropertyDescriptor with table [message #925271 is a reply to message #922888] Thu, 27 September 2012 10:58 Go to previous messageGo to next message
Thanks so far. I have understood the system of the descriptor, but there is one question open.
Is there any possibility to create an ItemPropertyDescriptor pointing on a special entry in a map?
The system using the EStructuralFeature, but for a special entry there is no.
I don't hope the only way is to implement IItemPropertyDescriptor on my own.
Re: Create ItemPropertyDescriptor with table [message #925402 is a reply to message #925271] Thu, 27 September 2012 13:28 Go to previous messageGo to next message
John,
Comments below.
Not sure what that means.
> is no.
If it's not modeled then you need to implement the APIs some other way.
> my own.
Re: Create ItemPropertyDescriptor with table [message #930519 is a reply to message #925402] Tue, 02 October 2012 07:47 Go to previous messageGo to next message
I mean I want to see the entrys of a map in a list, which appears when I expand the parent element.
That is the first step. Smile
Re: Create ItemPropertyDescriptor with table [message #945982 is a reply to message #930519] Mon, 15 October 2012 16:52 Go to previous messageGo to next message
Got it running. Here is my implementation:
public class MapEntryItemPropertyDescriptor extends ItemPropertyDescriptor {
	public MapEntryItemPropertyDescriptor(AdapterFactory adapterFactory, String displayName, String description,
			EStructuralFeature feature) {
		super(adapterFactory, displayName, description, feature);
	public MapEntryItemPropertyDescriptor(AdapterFactory adapterFactory, ResourceLocator resourceLocator,
			String displayName, String description, EStructuralFeature feature, boolean isSettable, boolean multiLine,
			boolean sortChoices, Object staticImage, String category, String[] filterFlags) {
		super(adapterFactory, resourceLocator, displayName, description, feature, isSettable, multiLine, sortChoices,
				staticImage, category, filterFlags);
	public Object getPropertyValue(Object object) {
		return ((BasicEMap.Entry<?, ?>) ((EObject) object).eContainer()).getKey();
	public void setPropertyValue(Object object, Object value) {
		super.setPropertyValue(((EObject) object).eContainer(), value);
Re: Create ItemPropertyDescriptor with table [message #945993 is a reply to message #945982] Mon, 15 October 2012 17:06 Go to previous messageGo to next message
My only problem is the refreshing of the child element. The child uses the key as label element.
I tried to change the labelUpdate argument of the ViewerNotification in method notifyChanged to true. But it seems it doesn't change anything.
In the editor I have to run manual refresh and the value is shown. What did I forgot?
Re: Create ItemPropertyDescriptor with table [message #946236 is a reply to message #945993] Mon, 15 October 2012 23:25 Go to previous messageGo to next message
John,
The properties view normally updates because the command stack listener
tells it to update.
> What did I forgot?
Re: Create ItemPropertyDescriptor for editing Map [message #949280 is a reply to message #912959] Thu, 18 October 2012 17:42 Go to previous messageGo to next message
Adding a CommandStackListener to the CommandStack and firing the event PROP_INPUT solved the problem.
Is there any possibility to find out, who created the change?
In my case for example the property page. So I only fire the event if there is really a change from propery page and not in the editor itself to prevent firing to much events.
Re: Create ItemPropertyDescriptor for editing Map [message #949615 is a reply to message #949280] Fri, 19 October 2012 01:52 Go to previous messageGo to next message
John,
Comments below.
No.
How can you know whether some arbitrary change affects the value of a
property?
Re: Create ItemPropertyDescriptor for editing Map [message #950041 is a reply to message #912959] Fri, 19 October 2012 11:16 Go to previous messageGo to next message
> property?
I can't know that I think.
I want to prevent if I change for example something with the editor, that my listener is activated and firing an event. Because there is already an integrated one and I don't want to fire multiple events for the same change.
Only if I make a change with the property sheet the listener shall be activated.
Re: Create ItemPropertyDescriptor for editing Map [message #950064 is a reply to message #950041] Fri, 19 October 2012 11:50 Go to previous message
John,
There's no way to know where the command came from.
>> property?
> the same change.
> activated.
Previous Topic:isModified() returns true on undo though reverting to saved state
Next Topic:Decoration layer over EMF
Current Time: Sat Jul 26 09:03:42 EDT 2025
Powered by FUDForum. Page generated in 0.07735 seconds
