Home » Eclipse Projects » P2 » If can filter out *nls plugins(artifacts) when installing build?
icon10.gif  If can filter out *nls plugins(artifacts) when installing build? [message #912203] Thu, 13 September 2012 02:12 Go to next message
I want to use equinox p2 to install build, with unit definitions and its corresponding plugins from feature.xml. All plugins with nls plugins are installed, but in our actual testing, we don't need to install *nls plugins, is there any way to filter out those *nls plugins in installation process?
Using such command outside of p2:
java -jar *.launcher.jar -application org.eclipse.ant.core.antRunner -buildfile build.xml -Drepository https://<...>/dev-offering -Ddestination=<dir>
build.xml:
<p2.repo2runnable destination="${destination}">
<source location="${repository}">
<p2.repo2runnable>
Re: If can filter out *nls plugins(artifacts) when installing build? [message #912903 is a reply to message #912203] Fri, 14 September 2012 07:32 Go to previous messageGo to next message
Any update? Thanks!
Re: If can filter out *nls plugins(artifacts) when installing build? [message #936589 is a reply to message #912903] Mon, 08 October 2012 02:12 Go to previous messageGo to next message
any help there? Thanks!
Re: If can filter out *nls plugins(artifacts) when installing build? [message #937872 is a reply to message #936589] Tue, 09 October 2012 06:43 Go to previous messageGo to next message
Did you try setting language to something non existing like
"gibbrish" ?
- henrik
Re: If can filter out *nls plugins(artifacts) when installing build? [message #938117 is a reply to message #937872] Tue, 09 October 2012 11:00 Go to previous messageGo to next message
"gibbrish" ?
Sorry, I am not sure what's the meaning of 'gibbrish'? Can you help to provide a clear example? Thanks!
Re: If can filter out *nls plugins(artifacts) when installing build? [message #938124 is a reply to message #938117] Tue, 09 October 2012 11:10 Go to previous messageGo to next message
> "gibbrish" ?
This word has no special meaning, it is just a non-sense word and the
question was whether you might have written a similar non-sense language
setting, presumably by a typo.
Greetings from Bremen,
Daniel Krügler
Re: If can filter out *nls plugins(artifacts) when installing build? [message #938129 is a reply to message #938124] Tue, 09 October 2012 11:19 Go to previous messageGo to next message
No, I haven't set any language parameters in my command.
Re: If can filter out *nls plugins(artifacts) when installing build? [message #938449 is a reply to message #938129] Tue, 09 October 2012 18:22 Go to previous messageGo to next message
Since you did not want any language, I suggested that you could try to
specify that you want a language that does not exist and I used
"gibberish" as an example - it is an english word:
gibberish |ˈjibəriSH|
noun
unintelligible or meaningless speech or writing; nonsense: he talks
gibberish.
ORIGIN early 16th cent.: perhaps from gibber (but recorded earlier) +
the suffix -ish1 (denoting a language as in Spanish, Swedish, etc).
- henrik
Re: If can filter out *nls plugins(artifacts) when installing build? [message #938613 is a reply to message #938449] Tue, 09 October 2012 22:30 Go to previous messageGo to next message
I see.
But as I use 'p2.repo2runnable', I haven't found any parameters to set any pointed language...
If I misunderstand, pls help to correct me. Thanks.
Re: If can filter out *nls plugins(artifacts) when installing build? [message #939933 is a reply to message #938613] Thu, 11 October 2012 02:41 Go to previous message
Find out a defect - https://bugs.eclipse.org/bugs/show_bug.cgi?id=284899, which related with nl fragments...
I have tried add osgi.nl = en_US in 'config.ini',but it don't works...
Any suggestion? Thanks!
Previous Topic:Is there a way to perform a p2 headless update
Next Topic:Updating fragments with p2
Current Time: Wed Nov 05 16:50:11 EST 2025
Powered by FUDForum. Page generated in 0.05282 seconds
