Home » Eclipse Projects » Remote Application Platform (RAP) » Bundle not starting automatically
Bundle not starting automatically [message #90291] Tue, 27 May 2008 10:06 Go to next message
Originally posted by: mike.xmos.com
I've run into a problem deploying my RAP application - when I run "ss"
from the console I'm getting the following:
Framework is launched.
id State Bundle
0 ACTIVE org.eclipse.osgi_3.4.0.v20080427-0830
1 ACTIVE org.eclipse.equinox.common_3.4.0.v20080421-2006
2 ACTIVE org.eclipse.update.configurator_3.2.200.v20080417
3 ACTIVE org.eclipse.rap.ui_1.1.0.20080520-1049
4 ACTIVE org.eclipse.equinox.http.jetty_1.1.0.v20080425
5 ACTIVE org.eclipse.equinox.app_1.1.0.v20080421-2006
6 RESOLVED org.apache.commons.logging_1.0.4.v200803061811
8 RESOLVED org.mortbay.jetty_5.1.14.v200804221617
9 <<LAZY>> com.ibm.icu_3.8.1.v20080402
10 <<LAZY>> org.eclipse.rap.ui.views_1.1.0.20080520-1049
11 ACTIVE org.eclipse.core.jobs_3.4.0.v20080310
12 RESOLVED javax.servlet_2.4.0.v200803061910
13 RESOLVED org.eclipse.equinox.http.registry_1.0.100.v20080427-0830
14 ACTIVE org.eclipse.equinox.http.servlet_1.0.100.v20080427-0830
16 RESOLVED org.eclipse.rap.jface.databinding_1.1.0.20080520-1049
18 RESOLVED org.eclipse.core.commands_3.4.0.v20080408-0800
19 RESOLVED com.xmos.ide_1.0.0
20 RESOLVED org.eclipse.equinox.launcher_1.0.100.v20080509-1800
Fragments=31
21 RESOLVED org.eclipse.rap.rwt.q07_1.1.0.20080520-1049
Master=26
22 <<LAZY>> org.eclipse.core.contenttype_3.3.0.v20080414
23 ACTIVE org.eclipse.core.runtime_3.4.0.v20080421-1805
24 <<LAZY>> org.eclipse.core.databinding_1.1.0.I20080425-1551
25 <<LAZY>> org.eclipse.core.expressions_3.4.0.v20080430-0100
26 RESOLVED org.eclipse.rap.rwt_1.1.0.20080520-1049
Fragments=21
27 ACTIVE org.eclipse.equinox.registry_3.4.0.v20080421-2006
28 RESOLVED com.xmos.ide.utils_1.0.0
29 ACTIVE org.eclipse.rap.jface_1.1.0.20080520-1049
31 RESOLVED
org.eclipse.equinox.launcher.gtk.linux.x86_64_1.0.100.v20080 509-1800
Master=20
32 RESOLVED com.xmos.ide.simulator_widget_1.1.0.200805271452
33 ACTIVE org.eclipse.rap.ui.workbench_1.1.0.20080520-1049
35 RESOLVED org.eclipse.osgi.services_3.1.200.v20071203
36 ACTIVE
Then I'm having to run "start 13" (org.eclipse.equinox.http.registry
bundle) before the server actually begins. After that it seems to run
fine but it's not starting automatically. Any ideas? My config.ini file is:
#bundles to start
osgi.bundles=org.eclipse.equinox.common@2:start,org.eclipse.update.configurator@3:start,org.eclipse.rap.ui@4:start,org.eclipse.equinox.http.jetty@4:start
# options for the equinox launcher
# do not run an eclipse application
eclipse.ignoreApp=true
# don't shutdown osgi after exiting (or not running) the application
osgi.noShutdown=true
# incoming port for the server
org.osgi.service.http.port=7070
And my plugins directory contains:
com.ibm.icu_3.8.1.v20080402.jar
com.xmos.ide_1.0.0.jar
com.xmos.ide.simulator_widget_1.1.0.200805271452.jar
com.xmos.ide.utils_1.0.0.jar
javax.servlet_2.4.0.v200803061910.jar
org.apache.commons.logging_1.0.4.v200803061811.jar
org.eclipse.core.commands_3.4.0.v20080408-0800.jar
org.eclipse.core.contenttype_3.3.0.v20080414.jar
org.eclipse.core.databinding_1.1.0.I20080425-1551.jar
org.eclipse.core.expressions_3.4.0.v20080430-0100.jar
org.eclipse.core.jobs_3.4.0.v20080310.jar
org.eclipse.core.runtime_3.4.0.v20080421-1805.jar
org.eclipse.equinox.app_1.1.0.v20080421-2006.jar
org.eclipse.equinox.common_3.4.0.v20080421-2006.jar
org.eclipse.equinox.http.jetty_1.1.0.v20080425.jar
org.eclipse.equinox.http.registry_1.0.100.v20080427-0830.jar
org.eclipse.equinox.http.servlet_1.0.100.v20080427-0830.jar
org.eclipse.equinox.launcher_1.0.100.v20080509-1800.jar
org.eclipse.equinox.preferences_3.2.200.v20080421-2006.jar
org.eclipse.equinox.registry_3.4.0.v20080421-2006.jar
org.eclipse.osgi_3.4.0.v20080427-0830.jar
org.eclipse.osgi.services_3.1.200.v20071203.jar
org.eclipse.rap.jface_1.1.0.20080520-1049.jar
org.eclipse.rap.jface.databinding_1.1.0.20080520-1049.jar
org.eclipse.rap.rwt_1.1.0.20080520-1049.jar
org.eclipse.rap.ui_1.1.0.20080520-1049.jar
org.eclipse.rap.ui.views_1.1.0.20080520-1049.jar
org.eclipse.rap.ui.workbench_1.1.0.20080520-1049.jar
org.eclipse.update.configurator_3.2.200.v20080417.jar
org.mortbay.jetty_5.1.14.v200804221617.jar
Any ideas?
Mike
Re: Bundle not starting automatically [message #90593 is a reply to message #90291] Wed, 28 May 2008 18:31 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
Hi Mike,
puh, these are the most difficult ones. To possibly get more
details, did run with -consolelog?
Just to be clear about this, I assume you are running an Equinox
server, not a WAR deployment.
Mike Wrighton wrote:
> id State Bundle
> 13 RESOLVED
> Fragments=31
> Master=26
> Fragments=21
> 31 RESOLVED
> Master=20
> 36 ACTIVE
> #bundles to start
> Any ideas?
> Mike
Re: Bundle not starting automatically [message #90716 is a reply to message #90593] Thu, 29 May 2008 05:07 Go to previous messageGo to next message
I've just run with consoleLog but didn't get anything extra:
$ ./eclipse -console -consoleLog
osgi> May 29, 2008 10:00:19 AM org.mortbay.http.HttpServer doStart
INFO: Version Jetty/5.1.x
May 29, 2008 10:00:19 AM org.mortbay.util.Container start
INFO: Started
org.eclipse.equinox.http.jetty.internal.Servlet25Handler@7e9ffe3f
INFO: Started HttpContext[/,/]
May 29, 2008 10:00:19 AM org.mortbay.http.SocketListener start
INFO: Started SocketListener on 0.0.0.0:7070
INFO: Started org.mortbay.http.HttpServer@4ab122a1
osgi>
Yeah I'm just using the Jetty deployment instructions from the RAP
Insights blog. Also, I'm using the extra plugins (launcher,
update.configurator etc) from eclipse 3.4RC2 - don't know if that makes
any difference?
Mike
Rüdiger Herrmann wrote:
> Hi Mike,
> puh, these are the most difficult ones. To possibly get more details,
> Just to be clear about this, I assume you are running an Equinox server,
>> Hi,
>> id State Bundle
>> 13 RESOLVED
>> 14 ACTIVE
>> Fragments=31
>> Master=26
>> Fragments=21
>> 31 RESOLVED
>> Master=20
>> 36 ACTIVE
>> file is:
>> #bundles to start
>> Any ideas?
>> Thanks,
>> Mike
Re: Bundle not starting automatically [message #90898 is a reply to message #90716] Thu, 29 May 2008 13:35 Go to previous messageGo to next message
see my comments below.
Rüdiger
> INFO: Started
> osgi>
> any difference?
What version of RAP are you using? RAP 1.1 RC2 comes with the
Eclipse 3.4 RC2 base bundels, but with older versions of RAP, this
mixture of versions could cause trouble.
> Mike
>> Hi Mike,
>>> Hi,
>>> "ss" from the console I'm getting the following:
>>> id State Bundle
>>> 13 RESOLVED
>>> 14 ACTIVE
>>> 16 RESOLVED
>>> Fragments=31
>>> Master=26
>>> Fragments=21
>>> 31 RESOLVED
>>> Master=20
>>> 36 ACTIVE
>>> file is:
>>> #bundles to start
>>> Any ideas?
>>> Thanks,
>>> Mike
Re: Bundle not starting automatically [message #90990 is a reply to message #90898] Fri, 30 May 2008 10:43 Go to previous messageGo to next message
> Cheers,
> Rüdiger
>> INFO: Started
>> osgi>
>> makes any difference?
> What version of RAP are you using? RAP 1.1 RC2 comes with the Eclipse
> 3.4 RC2 base bundels, but with older versions of RAP, this mixture of
>> Mike
>>> Hi Mike,
>>>> Hi,
>>>> id State Bundle
>>>> 13 RESOLVED
>>>> 14 ACTIVE
>>>> 16 RESOLVED
>>>> Fragments=31
>>>> Master=26
>>>> Fragments=21
>>>> 31 RESOLVED
>>>> Master=20
>>>> 36 ACTIVE
>>>> run fine but it's not starting automatically. Any ideas? My
>>>> config.ini file is:
>>>> #bundles to start
>>>> Any ideas?
>>>> Thanks,
>>>> Mike
I downloaded the latest version of RAP via software update yesterday
(1.1.0.20080527-1123) so I guess this uses RC2 base bundles.
Is there a way I can modify my config.ini to start the
org.eclipse.equinox.http.registry automatically?
Mike
Re: Bundle not starting automatically [message #91283 is a reply to message #90990] Tue, 03 June 2008 00:32 Go to previous message
Originally posted by: fappel.innoopract.com
don't use the update configurator. Create your own config.ini to start
every bundle. How to do this is described in the deployment tutorial of
the latest RC 2 Tooling release (regarding the config.ini it doesn't
matter that the tutorial describes the deployment to a servlet
container). You can use and adapt the ConfigIniCreator class of the
org.eclipse.rap.demo.feature available in CVS to create your config.ini.
It is a little bit rudimentary so if you are using fragments besides the
q07 fragment for example, you have to remove the start flag.
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Mike Wrighton [mailto:mike@xmos.com]
Bereitgestellt: Freitag, 30. Mai 2008 16:43
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: Bundle not starting automatically
Betreff: Re: Bundle not starting automatically
> Cheers,
> Rüdiger
>> INFO: Started
>> INFO: Started SocketListener on 0.0.0.0:7070 May 29, 2008 10:00:19 AM
>> osgi>
>> Mike
>>> Hi Mike,
>>>> Hi,
>>>> id State Bundle
>>>> 2 ACTIVE
>>>> 13 RESOLVED
>>>> 14 ACTIVE
>>>> 16 RESOLVED
>>>> 20 RESOLVED
>>>> Fragments=31
>>>> Master=26
>>>> 24 <<LAZY>>
>>>> 25 <<LAZY>>
>>>> Fragments=21
>>>> 27 ACTIVE
>>>> 31 RESOLVED
>>>> Master=20
>>>> 32 RESOLVED
>>>> 33 ACTIVE
>>>> 36 ACTIVE
>>>> config.ini file is:
>>>> #bundles to start
>>>> .http.jetty@4:start
>>>> # do not run an eclipse application eclipse.ignoreApp=true # don't
>>>> osgi.noShutdown=true # incoming port for the server
>>>> 0 org.eclipse.equinox.preferences_3.2.200.v20080421-2006.jar
>>>> Any ideas?
>>>> Thanks,
>>>> Mike
Mike
Previous Topic:exchanging data via http requests
Next Topic:[ANN] RAP 1.1 RC2 released
Current Time: Mon Oct 27 08:57:47 EDT 2025
Powered by FUDForum. Page generated in 0.09623 seconds
