Home » Language IDEs » C / C++ IDE (CDT) » cdt do not open C/C++ perspective / ubuntu (perspectiveless perspective)
cdt do not open C/C++ perspective / ubuntu [message #911867] Wed, 12 September 2012 09:30 Go to next message
Always get "Problems opening perspective 'org.eclipse.cdt.ui.CPerspective" trying to change perspective to C/C++.
.log:
!ENTRY org.eclipse.osgi 4 0 2012-09-12 17:23:07.509
!MESSAGE An error occurred while automatically activating bundle org.eclipse.cdt.core (163).
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.cdt.core.CCorePlugin.start() of bundle org.eclipse.cdt.core.
!ENTRY org.eclipse.osgi 4 0 2012-09-12 17:23:07.514
!MESSAGE An error occurred while automatically activating bundle org.eclipse.cdt.ui (186).
org.osgi.framework.BundleException: The activator org.eclipse.cdt.ui.CUIPlugin for bundle org.eclipse.cdt.ui is invalid
!ENTRY org.eclipse.ui 4 0 2012-09-12 17:23:07.517
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NoClassDefFoundError: org/eclipse/cdt/internal/ui/text/ICReconcilingListener)
seems started after core update
[Updated on: Wed, 12 September 2012 10:49] by Moderator
Re: cdt do not open C/C++ perspective / ubuntu [message #912160 is a reply to message #911867] Wed, 12 September 2012 23:49 Go to previous messageGo to next message
Most annoying -- I'm getting Problems opening perspective 'org.eclipse.cdt.ui.CPerspective' -- with several versions of Eclipse, using several different workspaces, is that the same thing?
Running Ubuntu 12.04, and all was working fine until I updated the system this morning. Might be related.
Re: cdt do not open C/C++ perspective / ubuntu [message #912186 is a reply to message #911867] Thu, 13 September 2012 01:23 Go to previous messageGo to next message
I am able to use the Java and Python perspectives just fine but I am getting the same error (Problems opening perspective 'org.eclipse.cdt.ui.CPerspective') along with the error:
The selected wizard could not be started.
Plug-in org.eclipse.cdt.ui was unable to load class org.eclipse.cdt.ui.wizards.CCProjectWizard.
An error occurred while automatically activating bundle org.eclipse.cdt.ui (514).
These errors happen on both the Indigo and Helios versions of Eclipse even after clean installs with both versions. Seems to be a common problem. Anyone out there with a fix?
Re: cdt do not open C/C++ perspective / ubuntu [message #912361 is a reply to message #911867] Thu, 13 September 2012 08:31 Go to previous messageGo to next message
the same here..
in my old workspace:
Plug-in org.eclipse.cdt.ui was unable to load class org.eclipse.cdt.internal.ui.editor.CEditor.
when i change my workspace :
An error occurred while automatically activating bundle org.eclipse.cdt.ui (295).
it started after a system update.
Re: cdt do not open C/C++ perspective / ubuntu [message #912440 is a reply to message #912361] Thu, 13 September 2012 11:38 Go to previous messageGo to next message
Did you install Eclipse using the package manager on Ubuntu or did you download the zip file from the eclipse.org site?
If you installed using the package manager, uninstall and download directly from eclipse.org.
Re: cdt do not open C/C++ perspective / ubuntu [message #912486 is a reply to message #912440] Thu, 13 September 2012 12:53 Go to previous messageGo to next message
Both of these errors have happened on installs directly from eclipse.org and from the package manager. It happens whenever I try to use c or c++ at this point, no matter how I install or what other plugins I have.
Re: cdt do not open C/C++ perspective / ubuntu [message #912544 is a reply to message #912486] Thu, 13 September 2012 14:42 Go to previous messageGo to next message
Same problem here. While I was working CDT crashed (I used ubuntu 12.04 based eclipse+cdt). Workspace changed, same problem. Removed ~/.eclipse/$thecorrectone, same problem. Uninstalled eclipsed, downloaded Juno classic, installed CDT 8.2 from upate site, used a new workspace... still the same problem.
In the traceback I found a hint that lead me to (not allowed to post links?)
geloest-could-not-initialize-class-com-ibm-icu-impl-java-timezone
which showed me that appending this line to eclipse.ini
-Dcom.ibm.icu.util.TimeZone.DefaultTimeZoneType=ICU
circumvented (I would not say solved Twisted Evil ) my problem. WTF changed that this problem ocurred?
[Updated on: Thu, 13 September 2012 15:19] by Moderator
Re: cdt do not open C/C++ perspective / ubuntu [message #912601 is a reply to message #912544] Thu, 13 September 2012 16:48 Go to previous messageGo to next message
There was a recent upgrade of open-jdk in Ubuntu. This link references a problem relating to a missing file in time zone mappings.
http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=600288
A re-install of tzdata-java may fix your problem.
Re: cdt do not open C/C++ perspective / ubuntu [message #912754 is a reply to message #912601] Fri, 14 September 2012 01:45 Go to previous messageGo to next message
It did! Thanks a lot
Re: cdt do not open C/C++ perspective / ubuntu [message #913029 is a reply to message #912160] Fri, 14 September 2012 12:21 Go to previous messageGo to next message
same here , sometimes i really wonder why do I even bother upgrading !!!
Any luck getting it to work ?
Edit: reinstalling tzdata-java just did it . most appreciated Smile
[Updated on: Fri, 14 September 2012 12:26] by Moderator
Re: cdt do not open C/C++ perspective / ubuntu [message #913472 is a reply to message #911867] Sat, 15 September 2012 14:49 Go to previous messageGo to next message
Thanks for posting, was having the same problems today. For anyone who wants some command line help :
First shut down Eclipse if open. Open a command prompt.
sudo apt-get purge tzdata-java
Then after everything is removed, run this
sudo apt-get install tzdata-java
Now reopen eclipse and you should be good to go!
Re: cdt do not open C/C++ perspective / ubuntu [message #1747477 is a reply to message #911867] Tue, 15 November 2016 05:13 Go to previous message
Same problem after Ubuntu 16.04 update
solved the problem doing:
- close eclipse
then
#sudo dpkg-reconfigure tzdata
Previous Topic:[Mac] Eclipse debugging with GDB
Next Topic:GraphicsMagick on Eclipse
Current Time: Sat Jul 26 02:57:13 EDT 2025
Powered by FUDForum. Page generated in 0.09629 seconds
