Eclipse suddenly failing to load projects [message #910072] |
Sat, 08 September 2012 11:05  |
I don't think it's an ADT plugin problem because I've removed my projects, reinstalled ADT, and added them again. I have a main project and separate projects for PC and Android platform-specific code. They're very nearly empty so I don't know why I'm getting these errors.
This is an overview of the errors and the .log in the spoiler.
It appears to me that 'space2d.eclipse.android/res' does exist.
Thanks!
> (Blank error message)
---> Resource 'space2d.eclipse.android/res' does not exist
> Problems occurred while trying to save the state of the workbench
---> Could not write metadata for 'space2d.eclipse.main'
· Problems saving workspace
---> Could not write metadata for 'space2d.eclipse.android'
· Parsing Data for android-15 failed
Toggle Spoiler[code]
!SESSION 2012-09-08 03:32:48.625 -----------------------------------------------
eclipse.buildId=I20120608-1400
java.version=1.6.0_26
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.java.product
!ENTRY com.android.ide.eclipse.adt 4 0 2012-09-08 03:33:03.255
!MESSAGE Parsing Data for android-15 failed
!STACK 0
at com.android.ide.eclipse.adt.AdtPlugin.getDisplay(AdtPlugin.java:334)
at com.android.ide.eclipse.adt.AdtPlugin.updateTargetListeners(AdtPlugin.java:1699)
at com.android.ide.eclipse.adt.internal.sdk.Sdk$5.run(Sdk.java:578)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
!SESSION 2012-09-08 03:33:03.495 -----------------------------------------------
!ENTRY org.eclipse.ui.ide 4 4 2012-09-08 03:36:17.549
!MESSAGE Problems saving workspace
!ENTRY org.eclipse.ui.ide 4 1 2012-09-08 03:36:17.559
!MESSAGE Problems occurred while trying to save the state of the workbench.
!SUBENTRY 1 org.eclipse.core.resources 4 568 2012-09-08 03:36:17.559
!MESSAGE Could not write metadata for '/space2d.eclipse.android'.
!STACK 0
java.io.FileNotFoundException: X:\_Workspace\.metadata\.plugins\org.eclipse.core.resources\.projects\space2d.eclipse.android\.markers (The system cannot find the path specified)
at java.io.FileOutputStream.open(Native Method)
at java.io.FileOutputStream.<init>(Unknown Source)
at org.eclipse.core.internal.localstore.SafeFileOutputStream.<init>(SafeFileOutputStream.java:51)
at org.eclipse.core.internal.resources.SaveManager.visitAndSave(SaveManager.java:1576)
at org.eclipse.core.internal.resources.SaveManager.visitAndSave(SaveManager.java:1656)
at org.eclipse.core.internal.resources.SaveManager.save(SaveManager.java:1142)
at org.eclipse.core.internal.resources.Workspace.save(Workspace.java:2375)
at org.eclipse.ui.internal.ide.application.IDEWorkbenchAdvisor$5.run(IDEWorkbenchAdvisor.java:508)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
!SESSION 2012-09-08 03:36:19.900 -----------------------------------------------
!ENTRY org.eclipse.ui.ide 4 4 2012-09-08 03:36:34.795
!ENTRY org.eclipse.ui.ide 4 1 2012-09-08 03:36:34.805
!SUBENTRY 1 org.eclipse.core.resources 4 568 2012-09-08 03:36:34.805
!MESSAGE Could not write metadata for '/space2d.eclipse.main'.
!STACK 0
java.io.FileNotFoundException: X:\_Workspace\.metadata\.plugins\org.eclipse.core.resources\.projects\space2d.eclipse.main\.markers (The system cannot find the path specified)
!SESSION 2012-09-08 03:39:26.541 -----------------------------------------------
!ENTRY com.android.ide.eclipse.adt 4 0 2012-09-08 03:46:05.981
!MESSAGE
!STACK 1
org.eclipse.core.internal.resources.ResourceException: Resource '/space2d.eclipse.android/res' does not exist.
at org.eclipse.core.internal.resources.Resource.checkExists(Resource.java:341)
at org.eclipse.core.internal.resources.Resource.checkAccessible(Resource.java:215)
at org.eclipse.core.internal.resources.Container.members(Container.java:266)
at org.eclipse.core.internal.resources.Container.members(Container.java:249)
at com.android.ide.eclipse.adt.internal.sdk.Sdk$6.run(Sdk.java:1307)
!SUBENTRY 1 org.eclipse.core.resources 4 368 2012-09-08 03:46:05.981
!MESSAGE Resource '/space2d.eclipse.android/res' does not exist.
[/pre] [/align]
[Updated on: Sat, 08 September 2012 11:07] by Moderator
FUDForum. Page generated in 0.07349 seconds
