Home » Eclipse Projects » Virgo » duplicated spring bundles
duplicated spring bundles [message #911737] Wed, 12 September 2012 04:06 Go to next message
I am using virgo 3.0.1 and I am having problems with Uses violation, it happens because virgo starts 2 identical spring bundles.
One in lib/kernel:
Bundle Location 	file:lib/kernel/org.springframework.asm-3.0.5.RELEASE.jar
And the other in repository/ext:
Bundle Location 	org.eclipse.virgo.region.user@file:/C:/virgo-web-server/repository/ext/org.springframework.asm-3.0.5.RELEASE.jar.
If I try to remove on of the bundles virgo doesnt start.
Why does virgo need these duplicated bundles ?
Re: duplicated spring bundles [message #911992 is a reply to message #911737] Wed, 12 September 2012 14:36 Go to previous messageGo to next message
This is a trade off between duplication and performance. The lib directory contains the bundles that Virgo needs to start, Equinox can just launch all the bundles in the folder quickly without worrying about repository indexing, deployer pipelines and so on. If we don't use the lib directory approach then starting Virgo gets slower.
Hope that explains it, it would be nice to get the performance without duplicating bundles but we couldn't figure out how to do so when designing that part of the system
Chris
Re: duplicated spring bundles [message #912003 is a reply to message #911992] Wed, 12 September 2012 15:05 Go to previous message
but this duplication is causing me conflicts, how can I tell a bundle ( not one of mine rather a third party ) which of the duplicated bundles to use ?
Previous Topic:Import packages in spring dependant bundle question
Next Topic:default web.xml in virgo 3.5.0
Current Time: Fri Jul 18 15:52:14 EDT 2025
Powered by FUDForum. Page generated in 0.26983 seconds
