Home » Modeling » OCL » Using OCL MDT sources from git
Using OCL MDT sources from git [message #911898] Wed, 12 September 2012 10:46 Go to next message
Dear all,
I try to reuse MDT OCL sources from
https://github.com/eclipse/ocl.git
I try to resolve all dependencies and errors.
I managed to solve many dependencies and errors.
However, some ones are still not solved like for example
Description	Resource	Path	Location	Type
Name clash: The method getPivotOf(MetaModelManager, Class<T>, EObject) of type CompleteOCLCS2Pivot.Factory has the same erasure as getPivotOf(MetaModelManager, Class, EObject) of type MetaModelManager.Factory but does not override it	CompleteOCLCS2Pivot.java	/org.eclipse.ocl.examples.xtext.completeocl/src/org/eclipse/ocl/examples/xtext/completeocl/cs2pivot	line 59	Java Problem
Package 'org.eclipse.imp.editor' does not exist in this plug-in	MANIFEST.MF	/org.eclipse.ocl.examples.editor.ui/META-INF	line 24	Plug-in Problem
and many of
The annotation @NonNull is disallowed for this location	AbstractBaseCSVisitor.java	/org.eclipse.ocl.examples.xtext.base/emf-gen/org/eclipse/ocl/examples/xtext/base/util	line 38	Java Problem
I use the master branch and I don't know if it is the good one to use.
Can you please tell me what is the required configurations of Eclipse, java, and EMF
and the required branch to use.
Please Help me
Re: Using OCL MDT sources from git [message #911974 is a reply to message #911898] Wed, 12 September 2012 13:22 Go to previous messageGo to next message
You need to install from
http://www.eclipse.org/jdt/core/beta-null-annotations-for-fields as
described in http://wiki.eclipse.org/JDT_Core/Null_Analysis/Beta.
Ed Willink
On 12/09/2012 15:47, Fy Za wrote:
> Dear all,
> I try to reuse MDT OCL sources from https://github.com/eclipse/ocl.git
> Plug-in Problem
> and many of
> java, and EMF
> Please Help me
> Thanks
Re: Using OCL MDT sources from git [message #912314 is a reply to message #911974] Thu, 13 September 2012 06:25 Go to previous messageGo to next message
Ed...
Thank you very much.
The problem is solved.
However, I have a problem about installing
org.eclipse.emf.examples.
Using EMF update site http://download.eclipse.org/modeling/emf/updates/releases/
I try to install EMF Examples in the EMF SDK 2.5.0 (EMF+SDK),
So I have this message
Cannot complete the install because one or more required items could not be found.
  Software being installed: EMF Examples 2.5.0.v200906151043 (org.eclipse.emf.examples.feature.group 2.5.0.v200906151043)
  Missing requirement: EMF Examples 2.5.0.v200906151043 (org.eclipse.emf.examples.feature.group 2.5.0.v200906151043) requires 'org.eclipse.platform.feature.group [3.3.0.v20061208-Fj22sCYGm0XDWm3,4.0.0)' but it could not be found
NB: I find that all the others packages in EMF SDK 2.5.0 was installed automatically
Can you please help me.
[Updated on: Thu, 13 September 2012 06:28] by Moderator
Re: Using OCL MDT sources from git [message #912431 is a reply to message #912314] Thu, 13 September 2012 11:15 Go to previous messageGo to next message
Try http://download.eclipse.org/modeling/emf/emf/updates and please
raise a bug against wherever you found
http://download.eclipse.org/modeling/emf/updates/releases/ which is the
old repo before composuitrs came into fashion.
Ed Willink
On 13/09/2012 11:25, Fy Za wrote:
> Ed...
> However, I have a problem about installing org.eclipse.emf.examples.
> not be found.
> Thanks
Re: Using OCL MDT sources from git [message #915496 is a reply to message #912431] Mon, 17 September 2012 08:10 Go to previous messageGo to next message
Dear all,
Using Git, I downloaded OCL sources (maintenance/R4_0 branch) in Eclipse Juno.
I can resolve dependencies but 3 errors still:
1) 'src' folder doesn't finded in the org.eclipse.ocl.examples.xtext2lpg
2) Unsatisfied version constraint: 'org.eclipse.ocl.uml: [3.0.0,4.0.0)' in /org.eclipse.ocl.standalone.tests/META-INF
3) Unsatisfied version constraint: 'org.eclipse.uml2.uml: [3.0.0,4.0.0)' MANIFEST.MF /org.eclipse.ocl.standalone.tests/META-INF
Please help me
Re: Using OCL MDT sources from git [message #915522 is a reply to message #915496] Mon, 17 September 2012 08:57 Go to previous messageGo to next message
As a result of your earlier difficulties I added a missing
http://wiki.eclipse.org/MDT/OCL/Dev/Setup#Getting_the_Sources_from_GIT
section to the wiki.
All three problems should be covered by the final "If you get build
errors ... close any projects that do not seem interesting to you."
comment.
Additionally org.eclipse.ocl.standalone.tests is covered by the only use
"archive" projects for historical research.
org.eclipse.ocl.examples.xtext2lpg is experimental work on using the LPG
parser for enhanced compilation speed and footprint. It is not yet in
use; just close it. I've fixed the src folder warning in a working
branch. Or just delete the src line in the .classpath.
Ed Willink
On 17/09/2012 13:10, Fy Za wrote:
> Dear all, Using Git, I downloaded OCL sources (maintenance/R4_0
> Please help me
> Thanks
Re: Using OCL MDT sources from git [message #915527 is a reply to message #915522] Mon, 17 September 2012 09:15 Go to previous messageGo to next message
Thank you Ed,
I resolve all dependencies
Now, I try to generate all editors using
/org.eclipse.ocl.examples.build/src/org/eclipse/ocl/examples/build/GenerateAll.mwe2
I have this error
85854 [Thread-1] ERROR mf.mwe2.launch.runtime.Mwe2Launcher  - Problems running workflow GenerateAll: The type of the first parameter of the main template named 'generate' is a proxy.
java.lang.RuntimeException: Problems running workflow GenerateAll: The type of the first parameter of the main template named 'generate' is a proxy.
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:104)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:62)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:52)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:74)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:35)
Caused by: org.eclipse.acceleo.engine.AcceleoEvaluationException: The type of the first parameter of the main template named 'generate' is a proxy.
	at org.eclipse.acceleo.engine.service.AcceleoService.doGenerate(AcceleoService.java:566)
	at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.generate(AbstractAcceleoGenerator.java:193)
	at org.eclipse.ocl.examples.build.utilities.OCLMetaModelCodeGenerator.invokeInternal(OCLMetaModelCodeGenerator.java:131)
	at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:126)
	at org.eclipse.emf.mwe.core.lib.Mwe2Bridge.invoke(Mwe2Bridge.java:34)
	at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:201)
	at org.eclipse.emf.mwe2.runtime.workflow.AbstractCompositeWorkflowComponent.invoke(AbstractCompositeWorkflowComponent.java:35)
	at org.eclipse.emf.mwe2.runtime.workflow.Workflow.run(Workflow.java:19)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:102)
	... 4 more
Can you please help me to resolve these errors?
Thank you
Re: Using OCL MDT sources from git [message #915536 is a reply to message #915527] Mon, 17 September 2012 09:27 Go to previous messageGo to next message
The Acceleo builder is flaky, particularly on a 'clean' project. As with
many things in Eclipse, sometimes the incremental updates are outwitted
so sometimes you need to refresh and clean some/all projects. I hope
this fixes it.
--- hang on you said GenerateAll -- someone else said this doesn't work.
I never use it, since I know how to sequence the relevant sub-generators
Generate Pivot Models
Generate Xtext Models
Generate All Editors
https://bugs.eclipse.org/bugs/show_bug.cgi?id=389720 raised
Ed
On 17/09/2012 14:15, Fy Za wrote:
> Thank you Ed,
> I resolve all dependencies Now, I try to generate all editors using
> I have this error
> proxy.
> at
> at
> at
> at
> at
> proxy.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 4 more
> Thank you
Re: Using OCL MDT sources from git [message #988497 is a reply to message #915536] Fri, 30 November 2012 04:26 Go to previous messageGo to next message
After resolving all dependencies (0 errors Smile ),
I try to edit org.eclipse.ocl.examples.library/model/OCL-2.4.oclstdlib.
when I open it, 689 errors was generated:
Description: Error executing EValidator
Resource: OCL-2.4.oclstdlib
Path: /org.eclipse.ocl.examples.library/model
Location: /org.eclipse.ocl.examples.library/model/OCL-2.4.oclstdlib
Type: Xtext Check (fast)
Do you know what I should do Please?
Fy Za
Re: Using OCL MDT sources from git [message #988532 is a reply to message #988497] Fri, 30 November 2012 06:40 Go to previous message
make sure you edit OCL-2.4.oclstdlib with the workspace OCLstdlib
editor, not the Juno editor that you may have installed.
i.e. edit it in a nested workspac.
Ed Willink
On 30/11/2012 09:26, Fy Za wrote:
> After resolving all dependencies (0 errors :) ),
> Best regards,
> Fy Za
Previous Topic:def initialized with alternatives (or)
Next Topic:how to access to association end in code
Current Time: Sat Jul 26 18:42:36 EDT 2025
Powered by FUDForum. Page generated in 0.39199 seconds
