Home » Modeling » Graphiti » Editor dirty handling
Editor dirty handling [message #910964] Mon, 10 September 2012 14:01 Go to next message
why doesn't the DefaultPersistencyBehavior use the "normal" dirty handling from the basic command stack (isSaveNeeded). What is the intention of implement it on its own way?
	public boolean isDirty() {
		BasicCommandStack commandStack = (BasicCommandStack) diagramEditor.getEditingDomain().getCommandStack();
		return savedCommand != commandStack.getUndoCommand();
Re: Editor dirty handling [message #911170 is a reply to message #910964] Tue, 11 September 2012 01:57 Go to previous messageGo to next message
As far as I remember there was an issue with the command we trigger directly
on save (we update the version of the diagram file on save in case it is not
up to date). By using the default implementation this command would appear
in the undo stack, we our approach we omit that one.
Michael
Re: Editor dirty handling [message #911364 is a reply to message #911170] Tue, 11 September 2012 09:04 Go to previous messageGo to next message
First time all my Features and Commands works well. But after the first saving the dirty handling is buggy.
Steps:
1. Move a Shape
2. Saving
3. Click ContextButtonPad with follow Feature
public class OpenPropertyViewFeature extends AbstractCustomFeature
    public OpenPropertyViewFeature (IFeatureProvider fp)
        super(fp);
    public boolean canExecute(ICustomContext context)
        return true;
    public void execute(ICustomContext context)
        try
  PlatformUI.getWorkbench().getActiveWorkbenchWindow()
                    .getActivePage().showView("org.eclipse.ui.views.PropertySheet");
        catch (PartInitException e)
    public boolean hasDoneChanges()
        return false;
    public boolean canUndo(IContext context)
        return false;
The Editor is dirty, because savedCommand = Move Shape Command and commandStack.getUndoCommand() is null.
So savedCommand != commandStack.getUndoCommand() is true
And the Undo/Redo Handling (e.g Toolbar action) is buggy too.
[Updated on: Tue, 11 September 2012 09:08] by Moderator
Re: Editor dirty handling [message #911718 is a reply to message #911364] Wed, 12 September 2012 03:16 Go to previous messageGo to next message
Hm, have you tried with canUndo() returning true?
Anyhow, this appears to be a bug. Would you please file this as a bugzilla?
Michael
Re: Editor dirty handling [message #911725 is a reply to message #911718] Wed, 12 September 2012 03:33 Go to previous message
If i return canUndo() true, i will get a undoable command.
That's not desired.
I will create a Bug =), we have have more problems with the undo/redo handling
Previous Topic:Saving Editor in a AbstractCustomFeature = UI Deadlock
Next Topic:Connection Selection Tolerance, Adjusting Connection Context, Automatic Layout
Current Time: Fri Jul 25 09:53:53 EDT 2025
Powered by FUDForum. Page generated in 0.05399 seconds
