Home » Modeling » TMF (Xtext) » Need assistance with formatting...
Need assistance with formatting... [message #911471] Tue, 11 September 2012 13:16 Go to next message
hello,
I'm facing a problem with formatting for days that is giving me headache Sad
Could someone, please, point me what am I missing ?
I created a simple model to easy reproduction and a simple test that shows what I want to achieve.
thanks,
Cristiano
test:
	@Test
	def void testFormatingForExampleTable() {
		val storyParsed =
		rule Test1
		rule Test2
		examples:
		|h1|h2|h3|
		|col1|col2|col3|
		'''.parse.serialize(SaveOptions::newBuilder.format().getOptions())
		val storyExpected =
		rule Test1
		rule Test2
			examples:
			|h1|h2|h3|
			|col1|col2|col3|'''.toString
		assertEquals(storyExpected, storyParsed)
test result:
org.junit.ComparisonFailure: expected:<...xamples:
	|h1|h2|h3|[]
	|col1|col2|col3|> but was:<...xamples:
	|h1|h2|h3|[ ]
	|col1|col2|col3|>
grammar:
grammar org.xtext.example.mydsl.MyDsl hidden(WS, SL_COMMENT, NEWLINE)
generate myDsl "http://www.xtext.org/example/mydsl/MyDsl"
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
Rules:
	(rules+=Rule*)
Rule:
	'rule' name=ID
		(exampleTable=Examples)? &
		(expectationTable=Expectations)?
Examples:
	'examples:'
	table=Table
Expectations:
	'expectations:'
	table=Table
Table hidden(WS, SL_COMMENT):
	{Table}
	((rows+=TableRow) (NEWLINE rows+=TableRow)*)
TableRow hidden(WS, SL_COMMENT):
	{TableRow}
	('|' (cells += TableCell ('|' cells += TableCell)*) '|')
TableCell:
	name = Content
Content returns ecore::EString:
	(STRING | ID | INT | ANY_OTHER) (STRING | ID | INT | ANY_OTHER)*;
FqnWithWildCard:
	Fqn ('.' '*')?;
Fqn:
  ValidID (=>'.' ValidID)*;
ValidID:
	ID;
terminal ID:
	'^'?('a'..'z'|'A'..'Z'|'_') ('a'..'z'|'A'..'Z'|'_'|'0'..'9')*;
terminal INT returns ecore::EDouble:
	'-'? ('0'..'9')+ ('.' ('0'..'9')+)?;
terminal PLACEHOLDER:
	'<' ('a'..'z' | 'A'..'Z') !('.' | '>' | '\n' | '\r')* '>';
terminal PATH:
	'/' ('/' | '.' | '_' | 'a'..'z' | 'A'..'Z' | '0'..'9')+;
terminal STRING:
	'"' ('\\' ('b' | 't' | 'n' | 'f' | 'r' | 'u' | '"' | "'" | '\\') | !('\\' | '"'))* '"' |
	"'" ('\\' ('b' | 't' | 'n' | 'f' | 'r' | 'u' | '"' | "'" | '\\') | !('\\' | "'"))* "'";
terminal NEWLINE:
	'\r'? '\n'?;
terminal SL_COMMENT 	: '!--' !('\n'|'\r')* ('\r'? '\n')?;
terminal WS			: (' '|'\t'|'\r'|'\n')+;
terminal ANY_OTHER:
formatter:
	protected void configureFormatting(FormattingConfig c) {
		MyDslGrammarAccess gac = (MyDslGrammarAccess) getGrammarAccess();
		// rule
		c.setLinewrap(1, 1, 2).before(gac.getRuleAccess().getRuleKeyword_0());
		// Example table
		c.setLinewrap(1, 1, 2).before(gac.getExamplesRule());
		c.setIndentationIncrement().before(gac.getExamplesAccess().getExamplesKeyword_0());
		c.setLinewrap(1, 1, 2).after(gac.getExamplesAccess().getExamplesKeyword_0());
		c.setIndentationDecrement().after(gac.getExamplesAccess().getExamplesKeyword_0());
		c.setLinewrap(1, 1, 2).after(gac.getExamplesRule());
		// Table
		c.setLinewrap(0, 1, 1).before(gac.getTableAccess().getNEWLINETerminalRuleCall_1_1_0());
		c.setIndentationIncrement().before(gac.getTableAccess().getGroup());
		c.setNoSpace().around(gac.getTableCellRule());
		c.setIndentationDecrement().after(gac.getTableRule());
[Updated on: Tue, 11 September 2012 14:14] by Moderator
Re: Need assistance with formatting... [message #911486 is a reply to message #911471] Tue, 11 September 2012 14:02 Go to previous messageGo to next message
can you share your formatter too?
~Christian
Re: Need assistance with formatting... [message #911491 is a reply to message #911486] Tue, 11 September 2012 14:15 Go to previous messageGo to next message
Hi Christian,
without formatter is a kind difficult, no ? Smile
I've edited the main question..
thanks
Re: Need assistance with formatting... [message #911492 is a reply to message #911486] Tue, 11 September 2012 14:17 Go to previous messageGo to next message
Here is my solution
// Table
		c.setNoSpace().after(gac.getTableRowAccess().getVerticalLineKeyword_1_0());
		c.setNoSpace().after(gac.getTableRowAccess().getVerticalLineKeyword_1_1_1_0());
		c.setNoSpace().after(gac.getTableRowAccess().getVerticalLineKeyword_1_2());
		c.setNoSpace().before(gac.getTableRowAccess().getVerticalLineKeyword_1_1_1_0());
		c.setNoSpace().before(gac.getTableRowAccess().getVerticalLineKeyword_1_2());
Re: Need assistance with formatting... [message #911497 is a reply to message #911492] Tue, 11 September 2012 14:31 Go to previous messageGo to next message
Hi Christian,
what a h.., I have to remove the keyword spaces, too !!!
Man, I owned you a box of beers !!!
thank you very very much !! Very Happy
Re: Need assistance with formatting... [message #911509 is a reply to message #911492] Tue, 11 September 2012 14:57 Go to previous messageGo to next message
Christian,
There is a problem.
Using the setNoSpace have a not good consequence. It doesn't let you include a NewLine.
If you include one more rule after the table then test will fail again:
org.junit.ComparisonFailure: expected:<...3|
	|col1|col2|col3|[
rule Test3
]> but was:<...3|
	|col1|col2|col3|[rule Test3]>
	@Test
		val storyParsed =
		rule Test1
		rule Test2
		examples:
		|h1|h2|h3|
		|col1|col2|col3|
		rule Test3
		val storyExpected =
		rule Test1
		rule Test2
			examples:
			|h1|h2|h3|
			|col1|col2|col3|
		rule Test3
			'''.toString
Re: Need assistance with formatting... [message #911513 is a reply to message #911509] Tue, 11 September 2012 15:08 Go to previous messageGo to next message
c.setNoSpace().between(gac.getTableRowAccess().getVerticalLineKeyword_1_2(), gac.getTableAccess().getNEWLINETerminalRuleCall_1_1_0());
Re: Need assistance with formatting... [message #911563 is a reply to message #911513] Tue, 11 September 2012 17:41 Go to previous messageGo to next message
Well, I walked, walked and comeback to same point than last week Sad. running editor behaves different from what I achieve in tests.
Could you please run the example model, putting the text that we use in the test and call format action ?
here, using this text:
rule Test1
rule Test2
examples:
|h1|h2|h3|
|col1|col2|col3|
rule Test3
after first calling of format action, I got this message error at row 2: missing EOF at '|':
rule Test1
rule Test2
	examples:
	|h1|h2|h3|
	|col1|col2|col3|
rule Test3
calling again, without change the text, I got this:
rule Test1
rule Test2
	examples:
	|h1|h2|h3| | col1 | col2 | col3 | rule Test3
[Updated on: Tue, 11 September 2012 17:42] by Moderator
Re: Need assistance with formatting... [message #911590 is a reply to message #911513] Tue, 11 September 2012 19:14 Go to previous message
Investigation is over !!! Smile
I discovered that the grammar was not supporting the formatted text and unfortunately tests was not capturing that...
Thank you Christian again for the time dispensed !
For people that could be interested following is the solution.
New grammar. Note that I'm not using NEWLINE anymore:
grammar org.xtext.example.mydsl.MyDsl hidden(WS, SL_COMMENT)
Rules:
	(rules+=Rule*)
Rule:
	'rule' name=ID
Examples:
	'examples:'
	table=Table
Expectations:
	'expectations:'
	table=Table
Table:
	{Table}
	((rows+=TableRow) (rows+=TableRow)*)
TableRow:
	{TableRow}
TableCell:
	name = Content
FqnWithWildCard:
	Fqn ('.' '*')?;
Fqn:
ValidID:
	ID;
terminal ID:
terminal PATH:
terminal STRING:
//terminal NEWLINE:
//	'\r'? '\n'?;
terminal ANY_OTHER:
The changed formatting code:
		// rule
		// Example table
		// Table
		c.setLinewrap(1, 1, 1).bounds(gac.getTableRowAccess().getVerticalLineKeyword_1_2(), gac.getTableRowAccess().getVerticalLineKeyword_1_0());
and new tests:
	@Test
	def void testFormatingForExampleTable2() {
		val storyParsed =
		rule Test1
		rule Test2
		examples:
		|h1|h2|h3||col1|col2|col3|
		rule Test3
		val storyExpected =
		rule Test1
		rule Test2
			examples:
			|h1|h2|h3|
			|col1|col2|col3|
		rule Test3'''.toString
Previous Topic:How to iterate in a collection using Xtend?
Next Topic:XtextStyledTextCellEditor
Current Time: Wed Jul 23 09:29:54 EDT 2025
Powered by FUDForum. Page generated in 0.08575 seconds
