Home » Archived » BIRT » Custom server side javascript issue in Birt web viewer(Custom server side javascript issue in Birt web viewer)
Custom server side javascript issue in Birt web viewer [message #906082] Fri, 31 August 2012 11:21 Go to next message
I have created a javascript for logging. The name of the file is logging.js. Here is the code
var logFile="F:/logFile.txt";
var loggingEnabled=true;
var printWriter;
function createLogger(method,message)
if (loggingEnabled && printWriter == null)
importPackage( Packages.java.io );
fos = new java.io.FileOutputStream( logFile, true );
printWriter = new java.io.PrintWriter( fos );
if(loggingEnabled && printWriter != null)
logMessage(method,message);
function logMessage(method,message)
if (loggingEnabled && printWriter != null)
printWriter.println(method + ":" + message);
function closeLogger(method,message)
printWriter.close();
I have added this script under Resources (javascript files) section of the report. When i use these js functions in my report and run it under eclipse or report designer, no problems
But when I copy the script and the report to birt viewer, it gives me error
Wrapped org.eclipse.birt.core.exception.CoreException: There are errors evaluating script "createLogger":
ReferenceError: "createLogger" is not defined. (<inline>#1) (/report/method[@name="initialize"]#2) (Element ID:1)
I copied the script under tomcat birt folder and also copied it under webcontent folder. Not sure why it does not work under viewer. Any help would be appreciated
thanks
birt user
Re: Custom server side javascript issue in Birt web viewer [message #906126 is a reply to message #906082] Fri, 31 August 2012 12:57 Go to previous messageGo to next message
Take a look at this post:
http://birtworld.blogspot.com/2012/07/using-global-js-function-across-birt.html
Add the js file to the report and put the js file in the resource folder.
Jason
> var printWriter;
> thanks
> birt user
Re: Custom server side javascript issue in Birt web viewer [message #911010 is a reply to message #906126] Mon, 10 September 2012 16:03 Go to previous messageGo to next message
Hello Jason,
in Birt viewer web.xml the resource folder is configured like this
<!-- Resource location directory. Defaults to ${birt home} -->
<context-param>
<param-name>BIRT_RESOURCE_PATH</param-name>
<param-value></param-value>
</context-param>
Which basically is the default. I placed the script in this location which is
....../webapps/birt. This is where I have also placed my reports. I have also added the reference to the external js in my report, but problem still persists
any help
birt user
Re: Custom server side javascript issue in Birt web viewer [message #911403 is a reply to message #911010] Tue, 11 September 2012 10:29 Go to previous message
Can you post the report? Did you set a resource folder in your designer. I am wondering if the full path to the js file is in the report. It should not be. Try creating a resource folder in your project, something like resources and set this as the resource folder in your designer preferences. See the blog reference I posted earlier to see how to do this. Put the js file in the resource folder and add it to the report. Next create a folder in the webviewer named something like resources, and put the js file in this folder. Set the BIRT_RESOURCE_PATH to the value resources and try the deployed report.
Jason
Previous Topic:use BIRT within app jEE
Next Topic:how to render charts to stream or object (png, svg)
Current Time: Sun Jul 27 16:20:30 EDT 2025
Powered by FUDForum. Page generated in 0.03806 seconds
