Home » Modeling » EMF » shared EMF editor with CDO/hibernate
shared EMF editor with CDO/hibernate [message #910887] Mon, 10 September 2012 11:07 Go to next message
hello,
i am creating a shared emf editor where several clients can access a model modify it and save their modifications.
am using CDO/hibernate for data base access.
i need to know more about the relation between bussiness objects or emf objects with xmi resources and cdo resources.
and my xmi resources should be the same as the data stored in the data base.
need your help here.
thanks in advance.
HB
Re: shared EMF editor with CDO/hibernate [message #910909 is a reply to message #910887] Mon, 10 September 2012 11:48 Go to previous message
Hassan,
I can't figure out what specifically you're asking. Maybe you want to
rephrase this to use a question mark to indicate exactly which sentence
is meant to be a question. Maybe while your at it you can also locate
the shift key on your keyboard so that you can start sentences with an
upper case letter.
On 10/09/2012 5:07 PM, Hassan BAZOUN wrote:
> hello,
> base.
> thanks in advance.
> HB
Previous Topic:EMF and Model - View - Presenter - General Question
Next Topic:How to obtain the literal from a GenFeature?
Current Time: Mon Aug 11 07:14:14 EDT 2025
Powered by FUDForum. Page generated in 0.27079 seconds
