Home » Archived » BIRT » birt report(Can not load the report query)
birt report [message #908988] Thu, 06 September 2012 07:02 Go to next message
Is there any one who can help me..
Im doing project in birt report...it works well in eclipse's birt viewer..
but deploying in apache tomcat 7..its shows error...
- Can not load the report query: 183. Errors occurred when generating the report document for the report element with ID 183. (Element ID:183)
Im using birt run time 3.7.2 in apache...and i am using report parameter..if there is no report parameter it works fine ..but putting parameter it creates above error...
Im using oracle 10g database ...
if i use query --select * from m_item; ..it works fine in apache...
if there is report parameter-- select * from m_item where item_code=?;.....then ..it creates above error...but it works well in eclipse..i have also put ojdbc14_g.jar driver in .....apache-tomcat-7.0.29\webapps\birt\WEB-INF\lib ...but also i could not fix this problem....Is there any body who can help me....It will be Helpful to me.
Tilak
Error details are attached below:
Table (id = 183):
Error.ReportQueryLoadingError2 ( 1 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: Can not load the report query: 183. Errors occurred when generating the report document for the report element with ID 183. (Element ID:183)
at org.eclipse.birt.report.engine.data.dte.DataPresentationEngine.doExecuteQuery(DataPresentationEngine.java:164)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.execute(AbstractDataEngine.java:267)
at org.eclipse.birt.report.engine.executor.ExecutionContext.executeQuery(ExecutionContext.java:1939)
at org.eclipse.birt.report.engine.internal.document.v4.ReportItemExecutor.executeQuery(ReportItemExecutor.java:412)
at org.eclipse.birt.report.engine.internal.document.v4.TableItemExecutor.doExecute(TableItemExecutor.java:72)
at org.eclipse.birt.report.engine.internal.document.v4.ReportItemExecutor.execute(ReportItemExecutor.java:294)
at org.eclipse.birt.report.engine.internal.document.v4.ContainerExecutor.prepareChildExecutor(ContainerExecutor.java:226)
at org.eclipse.birt.report.engine.internal.document.v4.ContainerExecutor.hasNextChild(ContainerExecutor.java:110)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.hasNextChild(WrappedReportItemExecutor.java:86)
at org.eclipse.birt.report.engine.api.impl.RenderTask$ReportExecutorWrapper.hasNextChild(RenderTask.java:780)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM$1.hasNextChild(HTMLPageLM.java:68)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:62)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.api.impl.RenderTask$PageRangeRender.render(RenderTask.java:661)
at org.eclipse.birt.report.engine.api.impl.RenderTask.render(RenderTask.java:294)
at org.eclipse.birt.report.service.ReportEngineService.renderReport(ReportEngineService.java:1547)
at org.eclipse.birt.report.service.BirtViewerReportService.getPage(BirtViewerReportService.java:204)
at org.eclipse.birt.report.service.actionhandler.BirtChangeParameterActionHandler.doRenderPage(BirtChangeParameterActionHandler.java:82)
at org.eclipse.birt.report.service.actionhandler.AbstractChangeParameterActionHandler.__execute(AbstractChangeParameterActionHandler.java:103)
at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseDocumentProcessor.__executeAction(AbstractBaseDocumentProcessor.java:47)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.executeAction(AbstractBaseComponentProcessor.java:143)
at org.eclipse.birt.report.soapengine.processor.BirtDocumentProcessor.handleChangeParameter(BirtDocumentProcessor.java:100)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.process(AbstractBaseComponentProcessor.java:112)
at org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingImpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
at sun.reflect.GeneratedMethodAccessor109.invoke(Unknown Source)
at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)
at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:641)
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:722)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at org.eclipse.birt.report.filter.ViewerFilter.doFilter(ViewerFilter.java:68)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:225)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:168)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:927)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1001)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:585)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:310)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
at java.lang.Thread.run(Thread.java:722)
[Updated on: Thu, 06 September 2012 07:04] by Moderator
Re: birt report [message #909213 is a reply to message #908988] Thu, 06 September 2012 14:29 Go to previous messageGo to next message
Are you using the WebViewerExample deployed to tomcat or are you using the engine api? Do you bind the data set parameter to a report parameter? If you are using the viewer what url are you using?
Jason
Re: birt report [message #909450 is a reply to message #909213] Fri, 07 September 2012 02:58 Go to previous messageGo to next message
Dear Jason,
Thanks for the response,
Im using WebViewerExample deployed in apache..i put my *.rptconfig report in the WebViewerExample folder...it works well if i dont mention any parameter but..if i use report parameter it gives above error..
i have tried with and without binding dataset..both..but also i couldn't fix the problem.
i have used below url to run the report.
localhost:8081/WebViewerExample/frameset__report=trial.rptdesign&sample=my+parameter
please provide me suitable suggestion to run using report parameter.
Thank you,,
Tilak
[Updated on: Fri, 07 September 2012 03:15] by Moderator
Re: birt report [message #909724 is a reply to message #909450] Fri, 07 September 2012 12:40 Go to previous messageGo to next message
I assume you meant *.rptdesign and not *.rptconfig? rptconfig is used in designer. Do not deploy it. Can you post your report?
Jason
Re: birt report [message #910335 is a reply to message #909724] Sun, 09 September 2012 05:48 Go to previous message
thanx jason,
its working now..
Previous Topic:Question about sample data part in chart examples
Next Topic:Bug? Tooltip still shows up when series is invisible
Current Time: Sat Jul 19 01:35:46 EDT 2025
Powered by FUDForum. Page generated in 0.04001 seconds
