Problem with TableViewer setAlignment on column [message #522986] |
Wed, 24 March 2010 12:47  |
There is a problem with the TableViewer.
I set the alignment of a TableColumn (column.setAlignment( SWT.CENTER );)
This works when put some text in the cell. (cell.setText( "someText" );)
But I put an image it the cell (cell.setImage( image );), the image will
always displayed left.
Is this a bug???
to reproduce see rap.demo #controls #Table-Tab
Roland
Re: Problem with TableViewer setAlignment on column [message #522988 is a reply to message #522986] |
Wed, 24 March 2010 12:55   |
Roland,
if I'm not entirely mistaken, this behaviour is intended. The rule of
thumb is, if it works in SWT/RCP, it should work the same in RWT/RAP.
Hence, if you can prove that SWT behaves differently, then please file a
bugzilla.
HTH
Rüdiger
Rüdiger Herrmann
http://eclipsesource.com
On 24.03.2010 17:47, Roland wrote:
> Is this a bug???
> Roland
Re: Problem with TableViewer setAlignment on column [message #523114 is a reply to message #522988] |
Thu, 25 March 2010 03:49   |
I have tested it in SWT and you're right. It shows the same behavior as
in RAP.
But the JavaDoc says:
Controls how text and *images* will be displayed in the receiver. The
argument should be one of LEFT, RIGHT or CENTER.
Strange.
Roland
Am 24.03.2010 17:55, schrieb Rüdiger Herrmann:
> Roland,
> bugzilla.
> HTH
> Rüdiger
Re: Problem with TableViewer setAlignment on column [message #523116 is a reply to message #523114] |
Thu, 25 March 2010 04:14   |
On 25.03.2010 08:49, Roland wrote:
> in RAP.
> Strange.
It may be that SWT behaves differently on different platforms. However,
it could also be a bug in the documentation. If you want to be sure,
search for a bug or newsgroup entry in SWT.
> Roland
>> Roland,
>> bugzilla.
>> HTH
>> Rüdiger
Rüdiger Herrmann
FUDForum. Page generated in 0.03870 seconds
