Home » Newcomers » Newcomers » VE Installation
VE Installation [message #90917] Sun, 31 July 2005 06:30 Go to next message
Originally posted by: HGSandhagen.web.de
I tried to install VE 1.1 on Eclipse 3.1. I downloaded the
VE-runtime-1.1.zip and extract it into the eclipse directory. After next
start of eclipse nothing has changed. In an other newsgroup I find the
hint to cleanup the directory "configuration" (delete all except
config.ini). With the next start I could create a "visual class" and in
the editor a tab named "Visual Editor" is displayed, but empty.
Please help.
Hans-Gerd
Re: VE Installation [message #90978 is a reply to message #90917] Sun, 31 July 2005 11:09 Go to previous messageGo to next message
Originally posted by: weconsul.ptd.net
Hans-Gerd Sandhagen wrote:
> Please help.
> Hans-Gerd
Hopefully you also installed the other required plugins that VE
requires.. They are mentioned on the download page and in numerous
references in the eclipse.tools.ve newsgroup.
Thanks in Advance...
IchBin, Pocono Lake, Pa, USA http://weconsultants.servebeer.com
____________________________________________________________ ______________
' If there is one, Knowledge is the "Fountain of Youth"'
-William E. Taylor, Regular Guy (1952-)
Re: VE Installation [message #91021 is a reply to message #90978] Sun, 31 July 2005 14:23 Go to previous messageGo to next message
>> Hi,
>> next start of eclipse nothing has changed. In an other newsgroup I
>> find the hint to cleanup the directory "configuration" (delete all
>> except config.ini). With the next start I could create a "visual
>> class" and in the editor a tab named "Visual Editor" is displayed, but
>> empty.
>> Please help.
>> Hans-Gerd
Thank you for fast response.
It works now.
Yes, I also installed the required plugins, but it works first time
after deleting and new install all. (all plugins installed by hand,
without update manager).
Hans-Gerd
Re: VE Installation / UML Installation [message #91036 is a reply to message #91021] Sun, 31 July 2005 17:21 Go to previous messageGo to next message
Originally posted by: info.ecosol24.de
So if you are lucky with your solution, perhaps you can give me a hint
so solve my prob.
I installed 3.1 SDK and it works fine.
Now I want to install the UML environment to play around with...
I downloaded the UML2 SDK and extracted all the file over my current
eclipse folder.
Now I can see the UML files in separate directories in the plugin folder...
But I do not see the plugin when I look at "Help -> Software Updates ->
Manage Configuration".
I also cannot use any UML function. I tried to use right mouse click on
a package to select the wizard...
but I cannot find any UML-entry ....
Please can anybody help me with this.
Probably I have a general understanding problem with plugins and
installing new functions.
Please help
Holger
-------- Original-Nachricht --------
>>> Hi,
>>> but empty.
>>> Please help.
>>> Hans-Gerd
> It works now.
> Hans-Gerd
Re: VE Installation / UML Installation [message #91066 is a reply to message #91036] Sun, 31 July 2005 18:25 Go to previous messageGo to next message
> so solve my prob.
> eclipse folder.
> Please help
> Holger
>>>> Hi,
>>>> but empty.
>>>> Please help.
>>>> Hans-Gerd
>> It works now.
>> Hans-Gerd
You also need the EMF runtime for UML2.
After all are install, start Eclipse with -clean option.
Sorry I have not played with UML2. There is a
"Getting Started with UML2" article at
http://dev.eclipse.org/viewcvs/indextools.cgi/%7Echeckout%7E /uml2-home/docs/articles/Getting_Started_with_UML2/article.h tml
You may want to watch the eclipse.tools.uml2 newsgroup.
Re: VE Installation / UML Installation [message #91100 is a reply to message #91066] Sun, 31 July 2005 19:27 Go to previous messageGo to next message
>> so solve my prob.
>> eclipse folder.
>> folder...
>> -> Manage Configuration".
>> on a package to select the wizard...
>> Please help
>> Holger
>>>>> Hi,
>>>>> but empty.
>>>>> Please help.
>>>>> Hans-Gerd
>>> It works now.
>>> Hans-Gerd
You may also want to download the UML2 examples.
Re: VE Installation / UML Installation [message #91132 is a reply to message #91100] Mon, 01 August 2005 03:08 Go to previous messageGo to next message
>>> hint so solve my prob.
>>> eclipse folder.
>>> folder...
>>> Please help
>>> Holger
>>>>>> Hi,
>>>>>> After next start of eclipse nothing has changed. In an other
>>>>>> newsgroup I find the hint to cleanup the directory "configuration"
>>>>>> (delete all except config.ini). With the next start I could create
>>>>>> a "visual class" and in the editor a tab named "Visual Editor" is
>>>>>> Please help.
>>>>>> Hans-Gerd
>>>> It works now.
>>>> Hans-Gerd
Thanks a lot...
I started eclipse with the -clean option an now all my installed plugins
show up...
Is there any list of all eclipse starting options available ?
Holger
Re: VE Installation / UML Installation [message #91146 is a reply to message #91132] Mon, 01 August 2005 03:57 Go to previous messageGo to next message
>>>> eclipse folder.
>>>> folder...
>>>> Please help
>>>> Holger
>>>>>>> Hi,
>>>>>>> "configuration" (delete all except config.ini). With the next
>>>>>>> start I could create a "visual class" and in the editor a tab
>>>>>>> Please help.
>>>>>>> Hans-Gerd
>>>>> It works now.
>>>>> Hans-Gerd
> Thanks a lot...
> show up...
> Holger
Sure, just do a search in the IDE help menu.
( Help menu \ Help Contents ) or ( Help menu \ Search )
Then do a search for "Eclipse runtime options".
Three items will be returned that will be of interest.
Re: VE Installation / UML Installation [message #91176 is a reply to message #91146] Mon, 01 August 2005 04:29 Go to previous message
>>>>> current eclipse folder.
>>>>> folder...
>>>>> Updates -> Manage Configuration".
>>>>> click on a package to select the wizard...
>>>>> Please help
>>>>> Holger
>>>>>>>> Hi,
>>>>>>>> Please help.
>>>>>>>> Hans-Gerd
>>>>>>> numerous references in the eclipse.tools.ve newsgroup.
>>>>>> It works now.
>>>>>> time after deleting and new install all. (all plugins installed by
>>>>>> hand, without update manager).
>>>>>> Hans-Gerd
>> Thanks a lot...
>> plugins show up...
>> Holger
Again thanks a lot...
Your answer is exactly what I needed...
Holger
Previous Topic:HELP Swing JViewport debug
Next Topic:run configuration
Current Time: Sun Nov 16 04:10:20 EST 2025
Powered by FUDForum. Page generated in 0.54897 seconds
