Home » Language IDEs » C / C++ IDE (CDT) » Incorrect FAQ? CDT does not recognize C++11 features
Incorrect FAQ? CDT does not recognize C++11 features [message #908917] Thu, 06 September 2012 04:21 Go to next message
The FAQ states:
"- Source navigation and symbol resolving
You should add the option -std=c++0x to the scanner discovery in Project
Properties->C/C++ Build ->discovery Options in the field "compiler
invocation arguments"."
However there is no such path in the CDT version 8.1. What is the
correct solution for this problem in 8.1?
Groeten,
Joost Kraaijeveld
Askesis B.V.
Molukkenstraat 14
6524NB Nijmegen
tel: 024-3888063 / 06-51855277
fax: 024-3608416
web: www.askesis.nl
Re: Incorrect FAQ? CDT does not recognize C++11 features [message #909014 is a reply to message #908917] Thu, 06 September 2012 08:22 Go to previous messageGo to next message
I had posted the same earlier under topic of ide unable to recognize certain symbols. I couldnt find anyplace to add options to the compiler. Looked through a bunch of menus.
Although from what I can tell, its not the build itself. That seems to work.
Its the indexing of all the symbols that eclipse uses, which I think is broken out of the box. There has to be a place to specify to the ide that we need c++0x.
My symbols are that I get a bunch of undefined symbol errors in the ide, and content assist and code completion is now broken.
I imagine you are seeing the same. Its back to good old emacs until this gets resolved.
Re: Incorrect FAQ? CDT does not recognize C++11 features [message #909018 is a reply to message #908917] Thu, 06 September 2012 08:32 Go to previous messageGo to next message
Project Properties->C/C++ General->Preprocessor Include Paths, Macros->[Providers] tab->your Built-in Compiler Settings provider (toolchain dependent).
Click on "Workspace Settings" link which gets you to "Settings" property page, select [Discovery] tab and your provider again. There is "Command to get compiler specs", add "-std=c++0x" in there.
I suppose there is some room for improvement on CDT side to make it easier.
Andrew
Re: Incorrect FAQ? CDT does not recognize C++11 features [message #909226 is a reply to message #909018] Thu, 06 September 2012 15:00 Go to previous messageGo to next message
Thanks, although it does solve all problems. The example program from
http://en.cppreference.com/w/cpp/thread/thread/thread gives problems at
the lines 37/38:
std::thread t3(f2, std::ref(n));
std::thread t4(std::move(t3));
Checkboxes for the compiler, like warning levels maybe? . And don't
forget other
things from the standard that requires flaggs, e.g. threads....
Groeten,
Joost Kraaijeveld
Askesis B.V.
Molukkenstraat 14
6524NB Nijmegen
fax: 024-3608416
web: www.askesis.nl
Re: Incorrect FAQ? CDT does not recognize C++11 features [message #909228 is a reply to message #909018] Thu, 06 September 2012 15:02 Go to previous messageGo to next message
Oh, and it also still does not find std::shared_ptr ....
Groeten,
Joost Kraaijeveld
Askesis B.V.
Molukkenstraat 14
6524NB Nijmegen
fax: 024-3608416
web: www.askesis.nl
Re: Incorrect FAQ? CDT does not recognize C++11 features [message #909739 is a reply to message #909228] Fri, 07 September 2012 13:19 Go to previous messageGo to next message
omg ... that is so unintuitive !!! This is an ide, we need to change the config management.
Anyway, Joost: Rebuild your index. That should solve some of the problems. It did for me. However new problems arose.
Now I cannot find certain stl algorithms (only in the ide). The compiler is able to find them and all other references to compile/link and produce a good executable.
Re: Incorrect FAQ? CDT does not recognize C++11 features [message #909741 is a reply to message #909018] Fri, 07 September 2012 13:21 Go to previous messageGo to next message
Thanks for this Andrewn !
I tried this and *some* of the problems were resolved.
I still get some references that are marked as "undefined" in the ide, even though build is still successful.
Re: Incorrect FAQ? CDT does not recognize C++11 features [message #990423 is a reply to message #909018] Wed, 12 December 2012 07:55 Go to previous messageGo to next message
Thanks Andrew Gvozdev !!
It worked after refreshing project.
Re: Incorrect FAQ? CDT does not recognize C++11 features [message #1105885 is a reply to message #908917] Tue, 10 September 2013 07:54 Go to previous messageGo to next message
So there is no way to set this globally? It seams very counter intuitive that i should have to set such a basic option on every project. Can't I even create some sort of template for it?
Re: Incorrect FAQ? CDT does not recognize C++11 features [message #1112464 is a reply to message #1105885] Thu, 19 September 2013 14:56 Go to previous messageGo to next message
If you followed the directions above, your change will persist for any other project in the same workspace using the same toolchain.
Which is still annoying, but is better than needing to set it per project.
You can export the workspace settings and re-import them for a new project to pass it along. Or you could keep a copy the languages.settings.xml file from $workspace/.metadata.plugins/org.eclipse.cdt.core and merge it into new workspaces.
(To restate the aforementioned instructions in a more step by step/verbose manner:
Open project properties.
Select the 'C/C++ General' subtree, then Preprocessor Include Paths branch.
Select the Providers tab. Then Built-in Compiler Settings provider. (The name of this weill be toolchain dependent. My usual option is "CDT GCC Built-in Compiler Settings" )
In the Language Settings Provider box, select the "Workspace Settings" hyperlink.
In the new settings window, change to the Discovery tab (if you're not already on it, but on Error Parsers).
Again, select the tool-chain dependent Built-in Compiler Settings.
In this window's Language Settings Provider Options window, add "-std=c++11" or -"std=c++0x" (without then quotes) to the command line somewhere before the '"${INPUTS}"' option (and make sure there are spaces on either side of the new parameter). )
(There are simpler ways, IMO, to get to that correct tab, but I'm just copying from above.)
Although, given that the C++11 standard is now over 2 years old (not to mention that first Technical Report was in 2007, and the '11 standard didn't add anything, IIRC), I'm really surprised that it isn't the default by now.
(This isn't to say that I've got indexing working right. std::[foo]_ptr, std::unordered_[map/set] and others are still failing to parse correctly. I'm very close to the point where I'm going to implement thin wrapper classes, just so the indexer issues stop.)
Re: Incorrect FAQ? CDT does not recognize C++11 features [message #1131375 is a reply to message #909018] Thu, 10 October 2013 09:13 Go to previous message
Andrew Gvozdev wrote on Thu, 06 September 2012 08:32
Andrew
This is great! Indexer finally fixed
Previous Topic:No Console Output in Eclipse CDT Kepler
Next Topic:Autoconf Library setting soname
Current Time: Thu Jul 24 22:10:54 EDT 2025
Powered by FUDForum. Page generated in 0.09279 seconds
