Home » Modeling » ATL » ATL transformation from EObject
ATL transformation from EObject [message #907097] Mon, 03 September 2012 05:31 Go to next message
Hello!
First all, thank you for your help and your time!
I'm trying execute an ATL transformation from Java, I have found some information and examples here:
http://wiki.eclipse.org/ATL/Developer_Guide#Core_API
https://github.com/101companies/101repo/blob/master/contributions/atl/src/atl/RunTransfoJava.java
but I only have found examples, where the input/output models are in a file. In my case, I have the input models in EMF EObject and I would like have the output model also in a EObject.
Is there any way for to do it? Where can I see an example?
Thanks you very much!!
José Miguel.
Re: ATL transformation from EObject [message #907101 is a reply to message #907097] Mon, 03 September 2012 05:43 Go to previous messageGo to next message
When dealing with EMF, ATL makes use of the standard ways for identifying/locating resources (in this case models).
You can take a look to the Javadoc of the ATL EMFInjector.inject (or EMFExtractor.extract) method to see the different possibilities (file in the file system, EMF URI, workspace resource, plugin resource).
Note that in EMF the base container (model) is a Resource stored in a ResourceSet, and not an EObject which has to be stored in a Resource.
Hugo
Re: ATL transformation from EObject [message #907190 is a reply to message #907101] Mon, 03 September 2012 09:38 Go to previous messageGo to next message
Hello Hugo
Thanks so much for your reply and for the execution Java example. It have been very usefull.
I have been looking those method, but all of them are looking for a file. I have seen the follow form:
 public void inject(IModel targetModel,
                   java.io.InputStream source,
                   java.util.Map<java.lang.String,java.lang.Object> options)
            throws ATLCoreException
Perhaps I can get a InputStream from the Resource of my model and use it.
Thanks Very Happy
Re: ATL transformation from EObject [message #907205 is a reply to message #907190] Mon, 03 September 2012 10:18 Go to previous messageGo to next message
If you handle an EMFInjector, you have several implementations of the "inject" method, for instance:
  • inject(IModel targetModel, String source, Map<String, Object> options) - the "source" parameter can be an EMF URI (among other possible options as I told you before, cf. the Javadoc of that method)
  • inject(IModel targetModel, Resource mainResource) - the "mainResource" parameter directly corresponds to the EMF model you want to load
Hugo
Re: ATL transformation from EObject [message #908937 is a reply to message #907205] Thu, 06 September 2012 05:08 Go to previous messageGo to next message
Hello Hugo.
Thanks for your reply. I was not seen this method because I was using EMFInjector form the interface IInjector, and there, this method don't exists.
I have been trying this form of inject a model (inject(IModel targetModel, Resource mainResource)) but I don't know what happen, It's not working::
For test it, I have create a very simple metamodel, and I have instance it using EMF:
Persona p = MailFactory.eINSTANCE.createPersona();
p.setName("Jose");
p.setEmail("jose@jose.com");
Persona p2 = MailFactory.eINSTANCE.createPersona();
p2.setName("Marta");
p2.setEmail("marta@marta.com");
Mail m = MailFactory.eINSTANCE.createMail();
m.setMessage("hello, how are you?");
m.setFrom(p);
m.getTo().add(p2);
Them I create a resource, and I add this model to it.
ResourceSet resourceSet = new ResourceSetImpl();
Resource resource = resourceSet.createResource(URI.createURI("file:/home/jozemi/output.prueba"));
resource.getContents().add(m);
(I don't registry the extension and other, because I thinks it's not necessary for the example, Isn't it?)
Well, I have a very short transformation only for try:
When I use this method:
IModel mailModel = modelFactory.newModel(mailMetamodel);
injector.inject(mailModel,resource);
It's like if may model was empty, however, if I persist the model:
try {
resource.save(null);
} catch (IOException e) {
e.printStackTrace();
And I use this other form:
injector.inject(mailModel,"file:/home/jozemi/output.prueba");
It works perfectly.
I don't know if I'm forgetting something or I'm doing something wrong Sad
Thanks in advance for your time Very Happy
José Miguel.
Re: ATL transformation from EObject [message #909164 is a reply to message #908937] Thu, 06 September 2012 12:54 Go to previous messageGo to next message
Both methods should give the same behavior in theory.
Maybe there is a small bug here, could you please raise a new Bugzilla bug explaining this?
Hugo
Re: ATL transformation from EObject [message #909492 is a reply to message #909164] Fri, 07 September 2012 04:31 Go to previous message
Done.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=389028
Thanks you for all!
Previous Topic:Metamodel to metamodel transformation
Next Topic:Troubles with ATL API
Current Time: Tue Jul 22 23:03:10 EDT 2025
Powered by FUDForum. Page generated in 0.04711 seconds
