Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Texo] Programmatically generate POJOs in a standalone project
[Texo] Programmatically generate POJOs in a standalone project [message #908786] Wed, 05 September 2012 22:05 Go to next message
Hello everyone,
First of all I know that there are already some threads handling this topic:
http://www.eclipse.org/forums/index.php/t/351255/
and
http://www.eclipse.org/forums/index.php/t/169019/
Since they're from 2009 I'm not sure if they're up-to-date.
Following scenario:
My goal is to create a standalone project, which accepts models (ecore, XMI, whatever) and generate the (hibernate) persistence artifacts programmatically. The only problem I can see is generating the POJOs out of the eclipse IDE. Is this somehow possible? If yes, how?
I appreciate any help.
Thank you,
Benjamin
Re: [Texo] Programmatically generate POJOs in a standalone project [message #909026 is a reply to message #908786] Thu, 06 September 2012 08:35 Go to previous messageGo to next message
Hi Benjamin,
Yes these threads are still up-to-date. So you still need eclipse running and a workspace/dev project to generate pojos
(with annotations).
I wonder, how do you see your standalone project work, how will a user use your project? It would need the emf jars and
other jars probably.
gr. Martin
On 09/06/2012 04:05 AM, Benjamin M. wrote:
> Hello everyone,
> and
> Following scenario:
> Thank you,
> Benjamin
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Texo] Programmatically generate POJOs in a standalone project [message #909331 is a reply to message #909026] Thu, 06 September 2012 20:52 Go to previous messageGo to next message
Hello Martin,
First of all thanks for the reply. Shouldn't it be possible to do this as a RCP?
The project would have an interface to accept models and generate automatically at runtime the persistence artifacts for the given models. Actually it's supposed to be only one step of a bigger use case.
That's why I'm actually trying to merge your RCP example project together with the org.eclipse.emf.texo.modelgenerator.test project and making it run outside of eclipse.
Kind Regards,
Benjamin
[Updated on: Thu, 06 September 2012 22:59] by Moderator
Re: [Texo] Programmatically generate POJOs in a standalone project [message #909397 is a reply to message #909331] Fri, 07 September 2012 00:47 Go to previous messageGo to next message
Hi Benjamin,
Yes that's for sure possible, with a rcp you can have a workspace and a dev project available. So indeed your approach
looks quite achievable to me.
gr. Martin
On 09/07/2012 02:52 AM, Benjamin M. wrote:
> Hello Martin,
> The standalone project would have an interface to accept models and generate automatically the persistence artifacts for
> Kind Regards,
> Benjamin
The Netherlands
Re: [Texo] Programmatically generate POJOs in a standalone project [message #909461 is a reply to message #909397] Fri, 07 September 2012 03:20 Go to previous messageGo to next message
Hi Benjamin,
And as a extra remark :-), I am interested to see/follow what you are doing/trying to accomplish. So feel free to
share/update me on your results, also if I need/can test something or answer other questions let me know.
gr. Martin
On 09/07/2012 06:47 AM, Martin Taal wrote:
> Hi Benjamin,
> gr. Martin
>> Hello Martin,
>> Kind Regards,
>> Benjamin
The Netherlands
Re: [Texo] Programmatically generate POJOs in a standalone project [message #909536 is a reply to message #909461] Fri, 07 September 2012 05:41 Go to previous message
Hi Martin,
As you mentioned it should have worked that way, but actually Teneor + Hibernate Tools seems to be an (better/)easier approach here.
Your example projects helped a lot to achieve that goal. With Teneor and Hibernate it is pretty simple to create a runnable java application (outside the eclipse IDE) which reads an Ecore Model and generates persistence artifacts out of it.
Actually I prefer Texo over Teneor, but doing the same thing with Texo seems to be a bit more complicated right now. Wink
Thanks for the help!
Benjamin
Previous Topic:[EEF] Errors in the generated code.
Next Topic:SWTBot & EEF generated Forms
Current Time: Sat Jul 26 10:57:42 EDT 2025
Powered by FUDForum. Page generated in 0.28195 seconds
