Home » Language IDEs » ServerTools (WTP) » WTP 3.4 XSD Schema Editor: bug report
WTP 3.4 XSD Schema Editor: bug report [message #908398] Wed, 05 September 2012 06:05 Go to next message
Hi all,
I'm using the latest Eclipse Juno dist, with WTP v3.4, and have had a couple of issues with the XSD Schema Editor:
1. Renaming Elements or Types in their properties window has no effect (when either over-typing the field, or using the wizard).
2. Editing the source code in the editor's "Source" view does not update the schema in the "Design" view. The schema must be closed and then re-opened to see any changes.
Can anyone else corroborate these problems?
I understand that this Schema Editor is new to the latest release of WTP. I may try rolling back to the previous version of WTP, if its editor allows renaming and synchronised view updates.
[Updated on: Thu, 06 September 2012 09:06] by Moderator
Re: WTP 3.4 XSD Schema Editor: bug report [message #908676 is a reply to message #908398] Wed, 05 September 2012 15:34 Go to previous messageGo to next message
*** UPDATE ***
I should state that I was using WTP 3.4 as part of the OS X Java Development package of Eclipse Juno.
After rolling back to the Eclipse Indigo Java Development package, renaming Elements in the XML Schema Editor became functional.
[Updated on: Wed, 05 September 2012 15:36] by Moderator
Re: WTP 3.4 XSD Schema Editor: bug report [message #909041 is a reply to message #908676] Thu, 06 September 2012 08:59 Go to previous messageGo to next message
*** UPDATE ***
In the OS X Indigo dist, overtyping an Element or Type name works, but the refactoring tool does not (refactoring did not work in Juno either).
Synchronisation of Source to Design view does work, unlike Juno.
Re: WTP 3.4 XSD Schema Editor: bug report [message #909115 is a reply to message #908398] Thu, 06 September 2012 11:08 Go to previous messageGo to next message
*** UPDATE ***
In rolling back to previous versions of WTP, packaged with earlier dists of OS X Eclipse, although you gain some basic functions, you lose others.
For example, I am unable to change an Element's Type, either by over-typing, or by using the drop-down menu. It must be edited in the Source view.
Unless I'm missing something, I'd say that the XML Schema Editor is a nice concept, but is not feature-complete, and is unusable as a result.
Re: WTP 3.4 XSD Schema Editor: bug report [message #910622 is a reply to message #909115] Mon, 10 September 2012 01:47 Go to previous message
The best thing to do is to open a bug report:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=WTP%20Source%20Editing&component=wst.xsd
Previous Topic:deploy ear glassfish
Next Topic:Windows 7 related???
Current Time: Sat Jul 26 19:16:07 EDT 2025
Powered by FUDForum. Page generated in 0.05956 seconds
