Home » Modeling » TMF (Xtext) » Unique names validation - Builder required?
Unique names validation - Builder required? [message #906769] Sun, 02 September 2012 09:49 Go to next message
i have implemented a unique name validation based on
http://www.eclipse.org/forums/index.php/mv/msg/267004/767941/#msg_767941.
Works really fine.
But i got the problem, that the error message "Duplicate entity ... in
container" does not automatically show up in document2 after editing
document1.
Example:
initial state:
doc1.entitydsl
entity Huhu {
then i add doc2:
doc2.entitydsl
entity Huhu {
The error message "Duplicate entity Huhu in container" is immediatelly
shown in doc2, but not in doc1. I have to open doc1 and save it again.
Then the error is also shown in doc1.
Question:
I think i have to invoke some kind of builder at the doc1 after
detecting the error in doc2?! Had a look at the code of xtend, but could
not find any hints about it.
Would be really nice, if someone could give me a hint about this issue.
Florian
Re: Unique names validation - Builder required? [message #907006 is a reply to message #906769] Mon, 03 September 2012 02:12 Go to previous messageGo to next message
As long as you don't save doc2 its changes shouldn't affect anything in
the "persisted world". Does it show the error in doc2 when saving a the
modified doc1?
Sven
Am 9/2/12 3:49 PM, schrieb flo:
> Works really fine.
> document1.
> Example:
> initial state:
> doc1.entitydsl
> entity Huhu {
> then i add doc2:
> doc2.entitydsl
> entity Huhu {
> Question:
> Florian
Need professional support for Xtext or other Eclipse Modeling technologies?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : http://blog.efftinge.de
Re: Unique names validation - Builder required? [message #907024 is a reply to message #907006] Mon, 03 September 2012 03:06 Go to previous messageGo to next message
No, saving a modified doc does not affect any other doc. So saving doc1 does only show the errors in doc1.
Btw:
Do i have to call the errror method for all found duplicates or just for the given one? Right now i just call it for the passed type.
Changed it to be called on all found duplicates in lTypes, but did also not change its behaviour.
	@Check(CheckType.NORMAL)
	public void checkDuplicateType_InProject(LType type) {
		List<LType> lTypes = getAllFor(type);
		if (lTypes.size() > 1) {
			error(String.format("Duplicate type %s in container", qnp
					.getFullyQualifiedName(type).toString()), type,
					EntitymodelPackage.Literals.LTYPE__NAME,
					ValidationMessageAcceptor.INSIGNIFICANT_INDEX,
					CODE__DUPLICATE_LTYPE_IN_PROJECT, (String[]) null);
Best,
Florian
Re: Unique names validation - Builder required? [message #907082 is a reply to message #907024] Mon, 03 September 2012 05:02 Go to previous messageGo to next message
Hi Florian,
please make sure that your IResourceDescription.Manager answers
#isAffected with true for changes in resources that export the same
names as the current resource. Otherwise it'll not be touched by the
builder.
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 03.09.12 09:06, schrieb Florian Pirchner:> No, saving a modified doc
> Btw: Do i have to call the errror method for all found duplicates or
> Best,
> Florian
Re: Unique names validation - Builder required? [message #907500 is a reply to message #907082] Tue, 04 September 2012 02:05 Go to previous message
Hi Sebastian,
thanks a lot for the hint. Will try to implement it that way...
Best,
Florian
Previous Topic:Inter grammar communication issue
Next Topic:Strange operation scoping for Numbers and null
Current Time: Sat Jul 19 01:39:32 EDT 2025
Powered by FUDForum. Page generated in 0.05224 seconds
