Home » Language IDEs » ServerTools (WTP) » JavaScript will not run in Eclipse(javascript file, JSDT)
JavaScript will not run in Eclipse [message #906985] Mon, 03 September 2012 00:50 Go to next message
Hello everyone:
I am trying to run a javascript file using eclipse.
Eclipse Installed: Eclipse IDE for Java Developer
Eclipse version: 1.4.2 (Indigo) install eclipse updates 3.7
JavaScrpt development tool installed: eclipse javascript development tool version 1.3.2
I created javascript project called: jscript_exer1
then I add a file called exer1 under the project
When I click on run button, it shows no lunch history, click on 'Run As' option,
it shows none applicable
The code in the file:
  <!DOCTYPE tag obmit the content due to link restriction>
<html>
  <head>
   <title>JavaScript Exercise</title>
   <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1"/>
  </head>
 <body>
   <script type="text/javascript">
    document.write("Hello JavaScript!");
   </script>
 </body>
</html>
I attached 2 pictures to show file structure in Eclipse and file structure on the local C drive. Please give me some advise on how to to make the file run in Eclipse. Thanks!
[Updated on: Mon, 03 September 2012 00:51] by Moderator
Re: JavaScript will not run in Eclipse [message #907248 is a reply to message #906985] Mon, 03 September 2012 12:00 Go to previous messageGo to next message
Hello everyone:
Here are two pictures that reveal the folder structure on Eclipse and local C drive
http colon double fowardslash jshu06 dot com fowardslash js_project_structure dot png
http colon double fowardslash jshu06 dotcom fowardslash project_file_structure dot png
Re: JavaScript will not run in Eclipse [message #908372 is a reply to message #907248] Wed, 05 September 2012 04:57 Go to previous message
Am 03.09.2012 18:00, schrieb jeff shu:> Hello everyone:
> local C drive
shouldn't the files be named "exer1.html" and "exer2.html"? Seems you
missed the extension.
Hope this helps
Wolfgang
Previous Topic:Adopter feedback!
Next Topic:deploy ear glassfish
Current Time: Tue Jul 22 20:35:34 EDT 2025
Powered by FUDForum. Page generated in 0.05059 seconds
