Home » Eclipse Projects » Memory Analyzer » How to open previous results of analyze?
How to open previous results of analyze? [message #906467] Sat, 01 September 2012 11:24 Go to next message
Sometimes analyze of heap dump is very long. I see many files with results of analyze but it seems to me that MAT cannot use them if I reopen previous
dump file.
I don't see any action like "Open results".
How can I use previouse results?
Re: How to open previous results of analyze? [message #907025 is a reply to message #906467] Mon, 03 September 2012 03:09 Go to previous messageGo to next message
Use the toolbar item 'Run Expert System Test' (5th from left in toolbar), then menu item 'Open Report' to open a zipped report such as:
<dump name>_Leak_Suspects.zip
Re: How to open previous results of analyze? [message #908459 is a reply to message #907025] Wed, 05 September 2012 08:22 Go to previous messageGo to next message
Leak_Suspects.zip is a raport.
I thinking about files with previous analyse such as:
heapdump-1346397029421.a2s.index
heapdump-1346397029421.domIn.index
heapdump-1346397029421.domOut.index
heapdump-1346397029421.hprof.gz
heapdump-1346397029421.idx.index
heapdump-1346397029421.inbound.index
heapdump-1346397029421.index
heapdump-1346397029421.o2c.index
heapdump-1346397029421.o2hprof.index
heapdump-1346397029421.o2ret.index
heapdump-1346397029421.outbound.index
heapdump-1346397029421.threads
and I suppose everyone expect like MAT reuse that files again to quickly show previous results.
Now can't do taht?
Re: How to open previous results of analyze? [message #908685 is a reply to message #908459] Wed, 05 September 2012 16:02 Go to previous message
It seems to be an answer. Save and copy:index files and Leak_Suspects, System_Overview and Top_Components reports;
Below is my updated command, this will also run the Leak_Suspects, System_Overview and Top_Components reports.
<JAVA_HOME>/bin/java -XX:MaxNewSize=512m -Xmx4096m -XX:MaxPermSize=512m -XX:-UseGC
OverheadLimit -jar plugins/org.eclipse.equinox.launcher_1.1.1.R36x_v20101122_1400.jar -consoleLog -application org.eclipse.mat.api.parse <HeapFileLocation>/heap.wls1_103d121.02-15-2012.hprof org.eclipse.mat.api:suspects org.eclipse.mat.api:overview org.eclipse.mat.api:top_components
This will generate <HeapDump>_Leak_Suspects.zip, <HeapDump>_Top_Components.zip and <HeapDump>_System_Overview.zip along with the index files.
Then I have copied my heap dump, index files and zip files (reports) to my windows desktop and ran eclipse memory analyzer on windows against my heap dump. Since MAT already got index files and Leak_Suspects, System_Overview and Top_Components reports, it wont parse the heapdump again (here you can give max heap ~1GB or 512MB) and you can view all the 3 reports. I hope this will help you.
[Updated on: Wed, 05 September 2012 16:10] by Moderator
Previous Topic:Unable to Open Heap Dump
Next Topic:Error displaying Histogram
Current Time: Wed Jul 23 22:52:38 EDT 2025
Powered by FUDForum. Page generated in 0.06532 seconds
