Home » Modeling » EMF » [CDO] Performance
[CDO] Performance [message #906087] Fri, 31 August 2012 11:32 Go to next message
we are facing some performance problems with big data structures.
The objects are cached on the server side. At least we see no sql statements.
But it looks like there is a tramendeous amount of client-server-communication, when we retrieve the objects from the server cache.
I managed to get some improvement by using cdoPrefetch(1), but running through the structure is still very slow.
Prefetching on a higher level was counterproductive, because then every reference is fetched.
How can I configure to eager load only one list?
Can you point me to some documentation about cdo caching and fetch strategies?
By the way, we are using DB Store.
Thanks in advance,
Joe
Re: [CDO] Performance [message #906139 is a reply to message #906087] Fri, 31 August 2012 13:22 Go to previous messageGo to next message
Am 31.08.2012 17:32, schrieb Joe Sobeos:
> server cache.
Is this caused by the characteristics of your model, e.g., very large datatypes or lists?
You should start with http://wiki.eclipse.org/CDO/Tweaking_Performance
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Performance [message #906861 is a reply to message #906139] Sun, 02 September 2012 16:04 Go to previous messageGo to next message
> lists?
No.
I would say it is caused by the overhead of the client-server-communication.
I checked the page, but I did not find a solution to my problem.
How can I configure CDO to fetch a sublist directly with the object?
I don't want to fetch all lists referenced by the object. -> cdoPrefetch seems not to be the solution.
At the moment I iterate through a list of objects. For each object I call cdoPrefetch(1) to get at least the collection loaded at once. But it is still slow even everything is coming from the server cache.
Is there something like fetch=FetchType.EAGER in JPA?
Re: [CDO] Performance [message #906992 is a reply to message #906861] Mon, 03 September 2012 01:19 Go to previous message
Am 02.09.2012 22:04, schrieb Joe Sobeos:
> No.
I don't see how we can reduce that.
http://wiki.eclipse.org/CDO/Tweaking_Performance#Prefetching_Target_Objects_Automatically_.E2.80.93_CDORevisionPrefetchingPolicy
But that applies to all lists of an object.
Prefetching selected lists is not possible with CDO as of now.
I don't know JPA exactly but CDO doesn't support per-feature configuration of load characteristics.
Cheers
/Eike
Previous Topic:Re: [CDO] Allowing (or ignoring) duplicate objects for certain types
Next Topic:EMF generated editor and eclipse plugin projects
Current Time: Sun Jul 20 21:06:06 EDT 2025
Powered by FUDForum. Page generated in 0.03621 seconds
