Home » Archived » BIRT » scale on Y axis
scale on Y axis [message #905156] Wed, 29 August 2012 16:17 Go to next message
index.php/fa/11323/0/
I have two charts which are almost the same.
The only difference is on the first chart, the value is 0.005.
The second chart, the value is 0.05.
The problem is that the first chart does not display the scale properly.
The second one displays correctly.
Is it a bug?
Re: scale on Y axis [message #905601 is a reply to message #905156] Thu, 30 August 2012 14:05 Go to previous messageGo to next message
Have you tried to set the scale manually in the third tab of the chart
wizard. Select the y-axis and the click on the scale button.
Jason
> Is it a bug?
Re: scale on Y axis [message #906130 is a reply to message #905601] Fri, 31 August 2012 13:03 Go to previous messageGo to next message
Yes, I did. I manually set the step to be 1, but still the same.
I uploaded the report file, you can have a try with my file.
Re: scale on Y axis [message #906209 is a reply to message #906130] Fri, 31 August 2012 17:03 Go to previous messageGo to next message
If you put a step number of 10 in the scale does it work? I modified
your example.
Jason
> Thanks
Re: scale on Y axis [message #908219 is a reply to message #906209] Tue, 04 September 2012 20:52 Go to previous messageGo to next message
Ok, setting it to 10 works. But why "auto" does not work properly?
Re: scale on Y axis [message #908600 is a reply to message #908219] Wed, 05 September 2012 12:17 Go to previous message
This may be bug with the Auto Scale.
Jason
On 9/4/2012 8:52 PM, DONG YAO wrote:
> Ok, setting it to 10 works. But why "auto" does not work properly? Thanks,
Previous Topic:Chart API - How to make legend appear on top of the chart
Next Topic:Data cubes and performance issues
Current Time: Sat Nov 08 20:17:13 EST 2025
Powered by FUDForum. Page generated in 0.05221 seconds
