Adding new Dimensions to Data Cube and Cross Tab [message #741187] |
Wed, 19 October 2011 05:14  |
I'm having problems when I add a new Dimension to an existing DataCube and Cross Tab and then trying to add a highlight according to this new Dimension.
In my example, I added a new Dimension JobTitle to Group2-Employenumber-Firstname-Lastname in my DataCube. So far everything is ok (I can see it in Data Cube).
I then added a new Bind to my existing Cross Tab called 'JOBTITLE'.
After that I added a Higlight in one of the Cross Tab cells (FIRSTNAME). In this step I could see it in a listbox Condition.
data["JOBTITLE"] Equal to 'Sales Rep'
But, when I preview the report I get an error 'The binding "JOBTITLE" refers to invalid levels.'
Can you please tell me what I'm doing wrong?
I can get the expected result when I create a new CrossTab from scratch (a new Collumn JOBTITLE appears in CrossTab which I do not want to show), but I can not afford to do it this way, because my report is changing often and is time consuming.
Could you please look at my example in the attachment.
Kindly regards,
Aleksander
Re: Adding new Dimensions to Data Cube and Cross Tab [message #906074 is a reply to message #904009] |
Fri, 31 August 2012 11:09  |
ok i was able to solve the problem by setting the width (under general properties) of jobtitle cell to zero and it worked like charm. Here are the steps that I followed similar to what had been suggested
1) After the jobtitle is there in the crosstab (it comes as a column), delete that data field. Another option is to hide it using visibility rule
2) then select the cell which had the jobtitle data field. from general properties, set the width to 0. And that did the trick
At the end BIRT rocks!!!
FUDForum. Page generated in 0.55203 seconds
