Home » Eclipse Projects » JFace » JFace Texteditor - Custom Undo
JFace Texteditor - Custom Undo [message #905964] Fri, 31 August 2012 07:34 Go to next message
I am currently developing a TextEditor using JFace and seeking to replace the standard Undo functionality with a custom one.
Is there a tutorial available to do this and to replicate the appearance of the standard implementation (i.e., icon in context menu, key bindings)?
So far I have tried providing my own implementation of IUndoManager in my source viewer's configuration, but while this might suffice functionality-wise, the element in the context menu does not assume the appearance of the standard implementation and I failed to reengineer how the default implementation achieves this. Also, I am unsure whether this implementation is correct and what exactly the IUndoContext's purpose is.
If someone could help me with this, I would be very much relieved Smile
Re: JFace Texteditor - Custom Undo [message #909507 is a reply to message #905964] Fri, 07 September 2012 04:56 Go to previous message
Just posting this for completeness, in case anyone runs across the same problem:
The way to go is to override createUndoRedoActions() such that the UndoActionHandler is replaced with a custom Action that contains the required implementation for Undo.
Previous Topic:java.lang.NoClassDefFoundError: Could not initialize class org.eclipse.jface.text.TextSelection
Next Topic:Customizing content assistant
Current Time: Wed Jul 23 21:08:50 EDT 2025
Powered by FUDForum. Page generated in 0.03815 seconds
