Home » Archived » Jubula » html AUT start error: Class path contains multiple SLF4J bindings(autagent fails to start browser (firefox) due to StaticLoggerBinder.class being twice on classpath)
icon5.gif  html AUT start error: Class path contains multiple SLF4J bindings [message #905865] Fri, 31 August 2012 04:17 Go to next message
Hi Jubula Fans,
when starting my HTML AUT, the autagent creates the file C:/Users/rob/AppData/Local/Temp/ch.qos.logback.slf4j4932080699372293698.jar containing the class org/slf4j/impl/StaticLoggerBinder.class. This class is also present in D:/Reik/dev/jubula_6.0.01011/server/plugins/ch.qos.logback.slf4j_1.0.0.v20120123-1500.jar resulting in the following autagent error log:
AUT:SLF4J: Class path contains multiple SLF4J bindings.
AUT:SLF4J: Found binding in [jar:file:/C:/Users/rob/AppData/Local/Temp/ch.qos.lo
gback.slf4j4932080699372293698.jar!/org/slf4j/impl/StaticLoggerBinder.class]
AUT:SLF4J: Found binding in [jar:file:/D:/Reik/dev/jubula_6.0.01011/server/plugi
ns/ch.qos.logback.slf4j_1.0.0.v20120123-1500.jar!/org/slf4j/impl/StaticLoggerBin
der.class]
AUT:SLF4J: See www.slf4j.org/codes.html#multiple_bindings for an explanat
ion.
AUT:Exception in thread "main" java.lang.RuntimeException: Could not start Selen
ium session: Failed to start new browser session: Error while launching browser
AUT: at com.thoughtworks.selenium.DefaultSelenium.start(DefaultSelenium.java:
107)
AUT: at com.bredexsw.jubula.rc.html.WebAUTServer.start(WebAUTServer.java:158)
AUT: at com.bredexsw.jubula.rc.html.WebAUTServer.main(WebAUTServer.java:120)
AUT:Caused by: com.thoughtworks.selenium.SeleniumException: Failed to start new
AUT: at com.thoughtworks.selenium.HttpCommandProcessor.throwAssertionFailureE
xceptionOrError(HttpCommandProcessor.java:112)
I use jubula_6.0.01011 as standalone application, downloaded and installed this week. Is this a bug? Can I configure the class path of the autagent? Or what else can I do? A tutorial for html AUTs is highly desirable!
I appreciate any help very much,
Reik
Re: html AUT start error: Class path contains multiple SLF4J bindings [message #907191 is a reply to message #905865] Mon, 03 September 2012 09:38 Go to previous messageGo to next message
This is a known issue that doesn't actually seem to cause any problems, if it's the same one I've encountered. If you can work normally, I'd ignore it Smile
Alex
Re: html AUT start error: Class path contains multiple SLF4J bindings [message #907529 is a reply to message #907191] Tue, 04 September 2012 03:09 Go to previous message
Thanks for answering,
unfortunately my html aut does not come up with firefox configurated as browser. If this class path problem is not the cause, there is no information what's wrong.
Using IE my aut does start and appears to work fine.
Any idea?
Reik
Previous Topic:What happens on java.lang.OutOfMemoryError: PermGen space
Next Topic:selenium webdriver version integration into Jubula
Current Time: Sun Jul 27 09:22:18 EDT 2025
Powered by FUDForum. Page generated in 0.05226 seconds
