Home » Eclipse Projects » Gemini » Blueprint - destroy-method not being called(NullPointerException in ShutdownSorter.getBundles)
Blueprint - destroy-method not being called [message #905499] Thu, 30 August 2012 09:59 Go to next message
Hi All,
I'm using Blueprint 1.0.1 in JBoss AS 7.1.1 to deploy some services. I've notice that my bean shutdown methods as specified in the attribute "destroy-method" aren't being called. I'm seeing this trace in the console:
2.2.1
2012-08-30 14:43:57,949 ERROR [org.jboss.osgi.framework.internal.FrameworkEventsPlugin](MSC service thread 1-3) Framework ERROR: org.osgi.framework.BundleExcept
ion: Error during stop of bundle: org.eclipse.gemini.blueprint.extender:1.0.1.RELEASE
        at org.jboss.osgi.framework.internal.HostBundleState.stopInternal(HostBundleState.java:425)
        at org.jboss.osgi.framework.internal.BundleManager.uninstallBundle(BundleManager.java:446)
        at org.jboss.osgi.framework.internal.UserBundleInstalledService.stop(UserBundleInstalledService.java:88)
        at org.jboss.msc.service.ServiceControllerImpl$StopTask.stopService(ServiceControllerImpl.java:1911)
        at org.jboss.msc.service.ServiceControllerImpl$StopTask.run(ServiceControllerImpl.java:1874)
        at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
        at java.lang.Thread.run(Thread.java:662)
        at java.util.AbstractCollection.removeAll(AbstractCollection.java:336)
        at org.eclipse.gemini.blueprint.extender.internal.dependencies.shutdown.ShutdownSorter.getBundles(ShutdownSorter.java:65)
        at org.eclipse.gemini.blueprint.extender.internal.activator.LifecycleManager.destroy(LifecycleManager.java:353)
        at org.eclipse.gemini.blueprint.extender.internal.activator.ContextLoaderListener.shutdown(ContextLoaderListener.java:428)
        at org.eclipse.gemini.blueprint.extender.internal.activator.ContextLoaderListener.stop(ContextLoaderListener.java:397)
        at org.eclipse.gemini.blueprint.extender.internal.blueprint.activator.BlueprintLoaderListener.stop(BlueprintLoaderListener.java:57)
        at org.eclipse.gemini.blueprint.extender.internal.boot.ChainActivator.stop(ChainActivator.java:66)
        at org.jboss.osgi.framework.internal.HostBundleState.stopInternal(HostBundleState.java:394)
        ... 7 more
The NPE appears to be a secondary problem after an IllegalStateException is thrown in ShutdownSorter.unusedBundles. I did some debugging and it looks like the bundles it is trying to process are all in the state UNINSTALLED, so the IllegalStateException is to be expected.
The destroy-method works if I undeploy a bundle without stopping JBoss. The problem occurs when I do ctrl+c in the console. It is as though Felix is undeploying the bundles before Blueprint has a chance to do its stuff.
Is this correct behaviour?
Brad.
Re: Blueprint - destroy-method not being called [message #905546 is a reply to message #905499] Thu, 30 August 2012 11:46 Go to previous messageGo to next message
The NPE is certainly not correct. I've fixed it in commit 0d4dd25afb3de213dc023b29a2f95f58e619fc85 which will appear in 1.0.2 (which I hope to produce tomorrow).
Re: Blueprint - destroy-method not being called [message #905556 is a reply to message #905546] Thu, 30 August 2012 12:12 Go to previous messageGo to next message
Hi Glyn,
thanks for fix. I just tested against 1.0.2.BUILD-SNAPSHOT, that has moved things on to the IllegalStateException in unusedBundles:
2012-08-30 16:58:42,121 ERROR [org.jboss.osgi.framework.internal.FrameworkEventsPlugin](MSC service thread 1-4) Framework ERROR: org.osgi.framework.BundleExcept
ion: Error during stop of bundle: org.eclipse.gemini.blueprint.extender:1.0.2.BUILD-SNAPSHOT
Caused by: java.lang.IllegalStateException: Bundle uninstalled: my-test-svc:1.0.0.SNAPSHOT
        at org.jboss.osgi.framework.internal.AbstractBundleState.assertNotUninstalled(AbstractBundleState.java:577)
        at org.jboss.osgi.framework.internal.AbstractBundleState.getRegisteredServices(AbstractBundleState.java:211)
        at org.eclipse.gemini.blueprint.extender.internal.dependencies.shutdown.ShutdownSorter.unusedBundles(ShutdownSorter.java:81)
        at org.eclipse.gemini.blueprint.extender.internal.dependencies.shutdown.ShutdownSorter.getBundles(ShutdownSorter.java:57)
        ... 7 more
Re: Blueprint - destroy-method not being called [message #905857 is a reply to message #905556] Fri, 31 August 2012 04:00 Go to previous message
Thanks for that testing. I raised and fixed bug 388496.
Previous Topic:Gemini Web 2.2.0 M01 is now available
Next Topic:Gemini Blueprint 1.0.2.RELEASE
Current Time: Thu Jul 24 17:39:03 EDT 2025
Powered by FUDForum. Page generated in 1.04407 seconds
