java.lang.NoClassDefFoundError: Could not initialize class org.eclipse.jface.text.TextSelection [message #905418] |
Thu, 30 August 2012 06:55  |
I am learing the Jface in action.in the chapter 5,I get a mistake that annoyed me.I'm gettting the below error, please help me on this.
at org.eclipse.jface.text.TextViewer.firePostSelectionChanged(TextViewer.java:2701)
at org.eclipse.jface.text.TextViewer$5.run(TextViewer.java:2682)
at org.eclipse.swt.widgets.Display.runTimer(Unknown Source)
at org.eclipse.swt.widgets.Display.messageProc(Unknown Source)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(Unknown Source)
at org.eclipse.swt.widgets.Display.readAndDispatch(Unknown Source)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at com.swtjface.Ch2.WidgetWindow.main(WidgetWindow.java:48)
the main class CompViewer
import org.eclipse.jface.window.*;
import org.eclipse.swt.widgets.*;
public class CompViewer extends ApplicationWindow
public CompViewer()
super(null);
protected Control createContents(Composite parent)
Ch5CompletionEditor cc1 = new Ch5CompletionEditor(parent);
return parent;
public static void main(String[] args)
CompViewer cv = new CompViewer();
cv.setBlockOnOpen(true);
cv.open();
Display.getCurrent().dispose();
import java.util.StringTokenizer;
import org.eclipse.jface.text.*;
import org.eclipse.jface.text.contentassist.ContentAssistant;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.KeyAdapter;
import org.eclipse.swt.events.KeyEvent;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Composite;
public class Ch5CompletionEditor extends Composite
private TextViewer textViewer;
private WordTracker wordTracker;
private static final int MAX_QUEUE_SIZE = 200;
public Ch5CompletionEditor(Composite parent)
super(parent, SWT.NULL);
wordTracker = new WordTracker(MAX_QUEUE_SIZE);
buildControls();
private void buildControls()
setLayout(new FillLayout());
textViewer = new TextViewer(this, SWT.MULTI | SWT.V_SCROLL);
textViewer.setDocument(new Document());
final ContentAssistant assistant = new ContentAssistant();
assistant.setContentAssistProcessor(
new RecentWordContentAssistProcessor(wordTracker),
IDocument.DEFAULT_CONTENT_TYPE);
assistant.install(textViewer);
textViewer.getControl().addKeyListener(new KeyAdapter() {
public void keyPressed(KeyEvent e)
switch(e.keyCode)
case SWT.F1:
assistant.showPossibleCompletions();
break;
default:
//ignore everything else
textViewer.addTextListener(new ITextListener() {
public void textChanged(TextEvent e)
if(isWhitespaceString(e.getText()))
wordTracker.add(findMostRecentWord(e.getOffset() - 1));
protected String findMostRecentWord(int startSearchOffset)
System.out.println("findMostRecentWord()");
int currOffset = startSearchOffset;
char currChar;
String word = "";
try
while(currOffset > 0
&& !Character.isWhitespace(
currChar = textViewer.getDocument()
.getChar(currOffset)
word = currChar + word;
currOffset--;
return word;
catch (BadLocationException e)
e.printStackTrace();
return null;
protected boolean isWhitespaceString(String string)
StringTokenizer tokenizer = new StringTokenizer(string);
//if there is at least 1 token, this string is not whitespace
return !tokenizer.hasMoreTokens();
import java.util.*;
public class WordTracker
private int maxQueueSize;
private List wordBuffer;
private Map knownWords = new HashMap();
public WordTracker(int queueSize)
maxQueueSize = queueSize;
wordBuffer = new LinkedList();
public int getWordCount()
return wordBuffer.size();
public void add(String word)
if( wordIsNotKnown(word) )
flushOldestWord();
insertNewWord(word);
private void insertNewWord(String word)
wordBuffer.add(0, word);
knownWords.put(word, word);
private void flushOldestWord()
if( wordBuffer.size() == maxQueueSize )
String removedWord =
(String)wordBuffer.remove(maxQueueSize - 1);
knownWords.remove(removedWord);
private boolean wordIsNotKnown(String word)
return knownWords.get(word) == null;
public List suggest(String word)
List suggestions = new LinkedList();
for( Iterator i = wordBuffer.iterator(); i.hasNext(); )
String currWord = (String)i.next();
if( currWord.startsWith(word) )
suggestions.add(currWord);
return suggestions;
import java.util.Iterator;
import java.util.List;
import org.eclipse.jface.text.contentassist.*;
public class RecentWordContentAssistProcessor
implements IContentAssistProcessor
private String lastError = null;
private IContextInformationValidator contextInfoValidator;
public RecentWordContentAssistProcessor(WordTracker tracker)
super();
contextInfoValidator = new ContextInformationValidator(this);
wordTracker = tracker;
System.out.println("RecentWordContentAssistProcessor()");
public ICompletionProposal[] computeCompletionProposals(
ITextViewer textViewer,
int documentOffset)
System.out.println("computeCompletionProposals()");
IDocument document = textViewer.getDocument();
int currOffset = documentOffset - 1;
try
String currWord = "";
char currChar;
while( currOffset > 0
currChar = document.getChar(currOffset)) )
currWord = currChar + currWord;
currOffset--;
List suggestions = wordTracker.suggest(currWord);
ICompletionProposal[] proposals = null;
if(suggestions.size() > 0)
proposals = buildProposals(suggestions, currWord,
documentOffset - currWord.length());
lastError = null;
return proposals;
lastError = e.getMessage();
return null;
private ICompletionProposal[] buildProposals(List suggestions,
String replacedWord,
int offset)
new ICompletionProposal[suggestions.size()];
int index = 0;
for(Iterator i = suggestions.iterator(); i.hasNext();)
String currSuggestion = (String)i.next();
proposals[index] = new CompletionProposal(
currSuggestion,
offset,
replacedWord.length(),
currSuggestion.length());
index++;
return proposals;
public IContextInformation[] computeContextInformation(
int documentOffset)
lastError = "No Context Information available";
return null;
public char[] getCompletionProposalAutoActivationCharacters()
//we always wait for the user to explicitly trigger completion
return null;
public char[] getContextInformationAutoActivationCharacters()
//we have no context information
return null;
public String getErrorMessage()
return lastError;
public IContextInformationValidator getContextInformationValidator()
return contextInfoValidator;
Attachment: Ch5.rar
(Size: 3.13KB, Downloaded 313 times)
[Updated on: Thu, 30 August 2012 06:58] by Moderator
Re: java.lang.NoClassDefFoundError: Could not initialize class org.eclipse.jface.text.TextSelection [message #905475 is a reply to message #905418] |
Thu, 30 August 2012 08:51   |
Am 30.08.2012 12:55, schrieb zhang lei:
> at
> public class CompViewer extends ApplicationWindow {
> public CompViewer() {
> super(null);
> protected Control createContents(Composite parent) {
> return parent;
> public static void main(String[] args) {
> cv.open();
> buildControls();
> textViewer.setDocument(new Document()); final ContentAssistant
> switch(e.keyCode)
> case SWT.F1:
> assistant.showPossibleCompletions(); break;
> default:
> if(isWhitespaceString(e.getText())) {
> char currChar;
> String word = "";
> try
> currOffset--;
> return word;
> return null;
> import java.util.*;
> flushOldestWord();
> return suggestions;
> super();
> int documentOffset)
> try
> char currChar;
> while( currOffset > 0 && !Character.isWhitespace(
> currOffset--; }
> lastError = null;
> return proposals;
> return null;
> int offset)
> ICompletionProposal[] proposals = new
> int index = 0;
> currSuggestion,
> offset,
> index++;
> return proposals;
> int documentOffset)
> return null;
> return null;
> return null;
> return lastError;
If this is an eclipse-based application you might want to check if all
bundles can be resolved.
Another way to tackle the problem is to press Ctrl+Shift+T and enter
org.eclipse.jface.text.TextSelection to search for the class in your
target platform. Then you can find the plug-in that you are missing
FUDForum. Page generated in 0.04241 seconds
